Old 07-13-2009, 04:23 PM   #4876
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'd like to see Dual mode settings along with 50 on the Timing Advance to start out.
Sensored only mode isn't the answer for hot mod motors. For a 3.5T I think you're still a bit overgeared however this would depend on how much timing you've got set in the RS.
What software are you guys running?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-13-2009, 04:32 PM   #4877
Timing RS: 10
Mode RS : dual mode
Ver soft: 198
two capacitors: yes
fan towards the solder post: yes , fan 2,5X2,5 Cm high speed
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 07-13-2009, 04:45 PM   #4878
big al's Avatar
Originally Posted by big al View Post
ok guys, I need to pick your brains again.
I have a novak 13.5 orange ring with about 1/8 inch of timing and boost set to 20. I gear at 4.53 for a medium sized track. All my buddies look at me like I'm Crazy. The motor temp peaked at 145 deg. and the speed control never got higher than 2 LEDs. Does this sound whacked out or am I ok?
Thanks--Albert
3.25 hotwire, firmware 198
Anyone?
I also noticed that at the factory set timing, the motor seems to bog down. Anywhere past or behind this point sounds better. I tried the novak forum, but I guess it's not too busy these days...
Thanks in advance--Al
big al is offline   Reply With Quote
Old 07-13-2009, 07:37 PM   #4879
Team Tekin
Randy_Pike's Avatar
Originally Posted by higbo View Post
Timing RS: 10
Mode RS : dual mode
That is not enough timing for competition. Try 50 and drop a few pinions for sure. I'm thinking at least 4 in 64 pitch.
What Battery power?
Can you post a layout shot of your car?
Old 07-13-2009, 09:14 PM   #4880
bukil's Avatar
Trader Rating: 39 (100%+)
I'm a little confused between these two:
Max Boost
Full Boost (30)
I'm under the impression that when you say "full boost", you are only to set it to 30. Correct me if I'm wrong but ... By definition, Max means full?
bukil is offline   Reply With Quote
Old 07-13-2009, 09:23 PM   #4881
Tim Stamper's Avatar
Quick question Randy, wondering if you can help.
Just installed a RS and a Redline 13.5 in my 12th scale.
Wondering what timing to set the motor and see below.
In the Hotwire software I popped 198 on and the settings are:
DB - off
RS - off
BS - 80
NW - 10
MT - BL-FW
TP - 5
VC - 3
PC - off
TB - 30
CL - off
1s Lipo and Sensored mode
I am running a 1cell lipo and have the novak booster if that makes a difference.
Should I change any settings?
Thanks,
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 07-13-2009, 10:06 PM   #4882
I am new to this speedo and having some issues/questions.
I am using 198 for single cell lipo. Every time I go to set MAX boost and save my settings it looses it and drops down to 0. Meaning when I hook the hotwire back up the setting shows 0 boost. If I set it on 30 it stays like it should. What should I be running for max power MAX or 30 and is there a difference?
Also, should I be clicking on the 1 cell lipo box or leave the voltage cuttoff on off.
What is dual mode used for?
Thanks,
Travis
march to my own is offline   Reply With Quote
Old 07-13-2009, 11:35 PM   #4883
What Battery power?
Battery: Lipo intellect 30C 5000 ma
Old 07-14-2009, 04:35 AM   #4884
Max Boost
Full Boost (30)
Max and 30 boost are the same.
So when you set your boost on max it's 30.
DB - off
RS - off
BS - 80
NW - 10
MT - BL-FW
TP - 5
VC - 3
PC - off
TB - 30
CL - off
Thanks,
Tim
When you have your boost on 30. Set your motor on 0
No keep the same settings.
Thanks,
Travis
Klik on 1C lipo.
Do you click on ok when you get the popup that counts down?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-14-2009, 10:52 AM   #4885
bukil's Avatar
Thanks,
Travis
This happened to me too. When I set my speedo to Max boost and hit apply, it saved. But as soon as I unplug and plug it back in to make sure that it did save. It gave me your settings are out range ... blah blah blah.. or similar to that text. I check the boost and it is set to 0. Mind you, my settings are set to:
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
When I pulled the trigger just to test it out on MAX settings, it "sounded" it has more rpm and umph. Then I plugged it back in to check my settings again just to tinker with it, it gave me the above error. The hotwire set my speedo to 0 boost . So I got scared that I might fry my esc and just set it to 30 - "sounded" less rpmish; less umphish.
See above.
This is why I asked if "Max" and "Full (30)" boost are the same .
I'll take snapshots of my settings and the error when I get home.
Old 07-14-2009, 11:06 AM   #4886
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
See above.
Ok.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 07-14-2009, 12:04 PM   #4887
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
See above.
Set it to sensored only mode, and set your timing boost to 29, NOT 30 (i had the same issue). Later when they release version 200, you can set it 30, the max.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-14-2009, 12:21 PM   #4888
bukil's Avatar
It is on sensored only. Check my post . If you have access to your hotwire right now, you could check your boost There is a bar that you can move. It gives you different numbers. When you move it to the highest, you will see "MAX". So again, is "MAX" 30? If it is, howcome we can set that bar to 30?
Enlighten me pls.
Like I said, when I get home ... I'll take snapshots of it.
~Mark
Old 07-14-2009, 12:44 PM   #4889
Enlighten me pls.
~Mark
Did you download the 3.25 hot wire on the tekin site. Which is the new 198. About month and half ago,
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-14-2009, 12:56 PM   #4890
bukil's Avatar
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
See above.
See above post #4885 / already quoted it.
Yes.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
