Old 07-12-2009, 02:19 AM   #4846
MoGGo's Avatar
Jdog
Without the Hotwire, the RS is just a regular speedo, plug un the Hotwire, update to the latest software, currently 1.98 then you will be able to turn up the boost etc. That is what brings the RS to life. I went a lap quicker at my track after a few run testing settings and gearing, which you will have to completly re-think.
MoGGo is offline   Reply With Quote
Old 07-12-2009, 03:39 AM   #4847
Team-RTR's Avatar
Originally Posted by MoGGo View Post
Jdog
whats a good FDR for small to med track running the usual 198 software, 30 boost etc. running a tekin 17.5 redline.
Team-RTR is offline   Reply With Quote
Old 07-12-2009, 04:31 AM   #4848
razzor's Avatar
Originally Posted by RoyU View Post
I'm having touble with calibrating my RS to my radio, 3PK w/FASST system, 4 cell, LRP 13.5.
When turn on the RS after turning on the transmitter, the lights are very, very, very dim no chime. Press the mode button for 3 seconds, nothing, no lights, no chimes. Steering servo works fine.
What's going on?
Reverse the throttle channel and try again.
also make sure all end points are at 100% and trim is in neutral position.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-12-2009, 08:20 AM   #4849
Krio's Avatar
Trader Rating: 150 (99%+)
What's going on?
You will need to downgrade and then re-upload the latest firmware. I have seen this happen on occasion and a fresh update has fixed the continuous low lights everytime.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 07-12-2009, 08:22 AM   #4850
Krio's Avatar
Originally Posted by JdogL View Post
Steve its a tekin 10.5, 12 degrees timiing on motor, stock software, rubber tires on asphalt. 110' straight by 60'. outside temp is 80-100 degrees. track temps are 105 to 125 ish. tc5 current gearing is 34/78. this gearing is why i need help. i am an offroad guy and not sure how to gear for onroad
There's nothing you can do with gearing to make up for what the hotwire can do with sensored only mode and boost. Buy one or borrow one and be amazed.
www.kriostasis.com
Old 07-12-2009, 09:33 AM   #4851
MoGGo's Avatar
never run 17.5, sorry.
Old 07-12-2009, 09:46 AM   #4852
Senna Racing's Avatar
guys running a lrp 17.5 with my new tekin in my 416 ratio 2.055 short to medium track, austalian winter track air temp between 8-18c
Lrp recomend to run at 3.5, I have been running a little lower with my spher tc spec 48p 65s 38p with a temp of about 140f
Wahts a good starting piont with my new speedi
Thanks Senna
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-12-2009, 10:26 AM   #4853
MoGGo's Avatar
After updating and boosting, if the 17.5 is anything like 13.5, between 4 and 4.5.
Yes, really!!!!!
Old 07-12-2009, 04:23 PM   #4854
Adjusted neutral width to 10 and reversed throttle channel, that seems to work. Thanks
What is good neutral width to use in 12th scale besides 10?
RoyU is offline   Reply With Quote
Old 07-12-2009, 04:47 PM   #4855
We normally run neutral width at 10 in 12th. If the drag brakes act funny "if you run any" then you'll need to turn the NW up a little. It varies from radio to radio.
Fred_B is offline   Reply With Quote
Old 07-12-2009, 04:57 PM   #4856
Thanks Fred
Got a ? about charging 1s lipo batteries, how many amps do you charge them at?
Old 07-12-2009, 04:59 PM   #4857
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks Fred
No different than a 2s lipo. If its 4000 mah... charge at 4 amps.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-12-2009, 06:28 PM   #4858
big al's Avatar
I had put my drag brakes up to 30 but didn't feel a difference. My NW is at 10, would that have been the issue?
big al is offline   Reply With Quote
Old 07-12-2009, 08:40 PM   #4859
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
what do i set my neutral width at on a 1/10th touring car?? for 21.5?
Alex
hound_dogs_01 is offline   Reply With Quote
Old 07-12-2009, 08:47 PM   #4860
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
low, NW is 'deadband' if u will. how far u have to pull ur trigger for something/anything to happen. many times its setup far too high. so start with a small setting. especially if ur runnin my old car in VTA 1st.
good luck
R
UltegraSTI is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
