Old 07-11-2009, 05:43 AM   #4831
Trader Rating: 21 (100%+)
Default Randy
You have a PM.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-11-2009, 07:46 AM   #4832
Drifting101's Avatar
Hey guys,
I just bought an RS and my first race with it is tomorrow. I will be running a trinity duo. I need a setup. It is a fairly large track, with some tight corners, medium grip and with a STD TC spec I was running about 3.21 FDR and coming off at 43*c average, so can go lower
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 07-11-2009, 09:05 AM   #4833
bkspeedo's Avatar
Originally Posted by MarkBrown View Post
If you are new to the RS and HotWire, read this post:
http://www.rctech.net/forum/5940355-post4315.html
It should save you some time sifting through old posts on the thread.
This is great document. I wish every RC company would produce real documentation like this.
I hope Tekin works with on getting rights to post this on there website and include it with the hotwire install.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-11-2009, 05:07 PM   #4834
I drove today on this track
http://www.macdebaanbrekers.nl/
Settings I used
Turbo Max
Boost 15
Timing on my redline 10,5T 13.
6,306FDR
I was faster than the LRP and GM drivers.
The GM motor was even slower than the LRP motor.
The Tekin motor was the fastest in the infield.
Just great.
The Tekin is the fastest speedo there is.
And it's going to be faster and faster.
Great work Tekin.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-11-2009, 08:45 PM   #4835
big al's Avatar
ok guys, I need to pick your brains again.
I have a novak 13.5 orange ring with about 1/8 inch of timing and boost set to 20. I gear at 4.53 for a medium sized track. All my buddies look at me like I'm Crazy. The motor temp peaked at 145 deg. and the speed control never got higher than 2 LEDs. Does this sound whacked out or am I ok?
Thanks--Albert
big al is offline   Reply With Quote
Old 07-11-2009, 08:59 PM   #4836
Can someone e-mail me software 199 or 200, Pleasae ! ! ! ! !
[email protected]
Steve Dunn
Indianapolis, IN
sdunnmcp is offline   Reply With Quote
Old 07-11-2009, 09:03 PM   #4837
ok guys please help i have the rs with a 10.5 tekin motor in my tc5 and i am getting killed on the straight by 13.5s i thought i had a good gearing combo but i guess i dont. can someone please give me a fast gearing combo to start with in 64p and 48p. help please. and i havnt got my hotwire yet its on the way. will that make a big difference
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 07-11-2009, 09:04 PM   #4838
[email protected]
Steve Dunn
Indianapolis, IN
It's not public yet.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-11-2009, 09:11 PM   #4839
corallyman's Avatar
Trader Rating: 99 (100%+)
Yes, the hotwire and also the soon to be released 200 software will be a big help. For the time being if you want help post your info. Brand of motor, physical timing on motor, what software you think is on your RS speedo, your gearing, track diminsions, outside or inside temps you race in, gearing, rubber or foam, brand of car, roll out, etc.
You can see that there is so many variables involved, the more info you give the more Randy or others will be able to help.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 07-11-2009, 09:42 PM   #4840
Steve
Steve its a tekin 10.5, 12 degrees timiing on motor, stock software, rubber tires on asphalt. 110' straight by 60'. outside temp is 80-100 degrees. track temps are 105 to 125 ish. tc5 current gearing is 34/78. this gearing is why i need help. i am an offroad guy and not sure how to gear for onroad
Old 07-11-2009, 10:26 PM   #4841
big al's Avatar
I forgot to add that I am also experiencing a slight hesitation when hitting the throttle from a dead stop.
Drag break at 15
dead band at 10
boost at 20
running in sensored mode
3.25 hot wire and198 firmware
Old 07-11-2009, 10:42 PM   #4842
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Nobody should have 199 software not on the team. Currently the team is not allowed to share it because of a known bug.
200 should be just around the corner and It CAN be shared. See your local team driver.
If you're "out of the boxing" your RS/10.5 setup you really need to get ahold of a Hotwire. That means you're running dual mode and very low timing with 180 software...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-11-2009, 11:07 PM   #4843
MaxSp97's Avatar
Randy,
YGPM
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 07-11-2009, 11:23 PM   #4844
my hotwire will be here monday so i will wait till then.
Old 07-12-2009, 01:33 AM   #4845
I'm having touble with calibrating my RS to my radio, 3PK w/FASST system, 4 cell, LRP 13.5.
When turn on the RS after turning on the transmitter, the lights are very, very, very dim no chime. Press the mode button for 3 seconds, nothing, no lights, no chimes. Steering servo works fine.
What's going on?
RoyU is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
