Tekin RS ESC sensored >
Old 07-08-2009, 07:21 PM
  #4771
Originally Posted by Jeremy Otis
Can anyone tell me if they have tried a hobby king brand booster on their RS for single cell lipo 1/12 scale? If so how did you like it?
I used it in my 1/12, it work fine I hooked it up to the +\- post on the esc the just plugged it into the receiver.
light
light is offline
Old 07-08-2009, 08:39 PM
  #4772
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by espresso1967
Thanks for the info, now I am really not running single cell lipos. Will be running world gt mod 2 cell. Just wanted options for single cell in case I wanted to possibly run that class. That single cell thing is just turning some people off, well at least it has of for me. Anyways no single cell in my car.
Why? because you have to wire up a 30$ booster? It's painfully easy, you are 95% as fast as the 4cell crew, and it takes a bit of headache away from racing not having to worry about battery maintenance. It's a win/win no matter how you slice it.
Anyway, the 1s check box works fine in the RS, and I set my custom cutoff to 3.1 volts.
Cpt.America is offline
Old 07-08-2009, 10:12 PM
  #4773
espresso1967's Avatar
Trader Rating: 18 (100%+)
Yes, just not the best way of going about this and adding additional components to an already limited real estate on pan cars to setup your electronics.
It's not that I can't do it, just not worth it again we are being allowed to run mod in world gt and that is good enough for me. Been running 2 cell for over a year and to back track, no thanks.
espresso1967 is offline
Old 07-09-2009, 12:57 AM
  #4774
bukil's Avatar
Trader Rating: 39 (100%+)
Anyone here who is kind enough to share their 13.5 RS setup for TC using v198?
bukil is offline
Old 07-09-2009, 02:21 AM
  #4775
MoGGo's Avatar
Give it full boost, zero or very little motor timing then the rest is up to you really. I turn reverse off and have full brakes, no drag brake and as I use LIPO, set a 6.5 V cutoff. Profile is a personal thing and run sensored only. I found quite a bit of extra pace by adding a little motor timing as well as boost but that heats motor up a lot more than boost, and was very limited before pace fell off again with too much timing.
MoGGo is offline
Old 07-09-2009, 02:22 AM
  #4776
MoGGo's Avatar
Brakes seem very dependant on which brand of motor you use, my Tekin gives a great deal more than my Novak.
MoGGo is offline
Old 07-09-2009, 02:24 AM
  #4777
I found out my problem that I hat this sunday with the race.
My C Hub was broken and my spool was broken.
Fikst it and I'm using now a one way.
Tested the Tekin 10,5T motor with lipo.
The Tekin was accelerating faster than a SPX with a Orion 9,5T.
The Tekin hath the same top speed as the other car.
He was also running lipo.
The other driver was surprised to see that it was a 10,5T.
Both motors temp were 55 C.
So no temperature problems.
This Saturday I hope that I can barrow a lipo to race the Saturday evening race.
This is on a big track were I can test the Turbo again.
It's a high speed track and I belief that the Tekin motor will go great there.
I tested it already with 5 cell there and it was fast.
mikky32 is offline
Old 07-09-2009, 06:38 AM
  #4778
pakk's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Randy_Pike
We will have the public version very soon. It won't be 199 rather 200. There is a known issue with 199 that I don't want to have customers/racers deal with. It can be "worked around" but I would rather make it right.
Right not our drivers have been instructed to not share this software because of the issue. The team WILL be encouraged to share the new 200 version!
It's like a "questionable" photo of your girlfriend or wife, once it get's out you can never get it back...
I don't mean to be harsh but I feel strongly about this issue. I'd rather give you software and some known good setups that I can post with it so EVERYONE can hit the track and be close, close enough to whup some ars with the RS!
Guys run the cap that comes with the RS, it keeps the speedo cool.
The 448 is a bit much on a standard RS but I've done it. Make sure to get a 2nd cap to help and your gearing needs to be correct.
The cap is a 16v 330uf cap. The one we spec out has low ESR. I've had good luck with our G11 caps also which were 16v 1000uf standard caps.
Place them as close to the speedo for best results.
Although I do agree in not releasing a product till it is fully complete, I hate to break it to you, but your wifes photos are out. I guess the most frustrating thing is that there seems to be so many people(online and at the local tracks) that have it. While I, and others, sit here patiently watching people with 199 and the spx fly by us. I see there is a problem with it. What's the problem? Others seem to work around it, I'm pretty sure I could work around it as well. Maybe it could have been released as a beta with a strict caution. I guess I am just bitching and crying, but it just seems unfair. I think a lot more people have this 199 software than you think. And unless you are in the "loop" with them, you don't get it.
Originally Posted by svines1972
Can someone post a pic of the with the wires attached? I was wondering if it is ok to remove the 5 posts and attach the wires directly to the holes in the board? Or do the posts have a needed or practical purpose. I am not a fan of spiderweb wiring jobs and will be mounting this in an F104 and need to keep the wires inside a tight location on the side of the car.
I have an RS with two battery post's removed. I did not remove them, it was sold to me like this. I have ZERO heat issues. I have contacted tekin on this, and although they do not recommend it and as long as it is not over heating, it will and has been fine. It is really going to depend on what motor you are running. I have only hooked 17.5s to both my RS's and have yet to see more than 1 led blink temp wise.
--pakk
pakk is offline
Old 07-09-2009, 08:20 AM
  #4779
Senna Racing's Avatar
just got myself a tekin speedi and was woundering if any one has run it with a lrp 11x 17.5 and what a goo gear ratio would be
Senna Racing is offline
Old 07-09-2009, 09:12 AM
  #4780
BagofSkill's Avatar
I'm running 1/10 TC with Li-Po and the RS with v198 and a 13.5 indoors on a 60'x30' (20mx10m) carpet track.
If I run max boost like everyone seems to recomend, I have to gear down which is fine because my top speed is still good, but I have NO punch out of the corners. It makes the car smooth to drive but I'm giving away lap time I'm sure.
I haven't found the right combo yet but I'm looking at gearing up by 5 teeth (48p) and droping the boost back to zero (at first).
The question is- is this right? Everyone seems to be pushing the boost pretty hard but is that defo the wrong way to go in this application? Am I doing the right thing by dropping the boost?
Cheers, Chris.
BagofSkill is offline
Old 07-09-2009, 09:21 AM
  #4781
Cheers, Chris.
What 13.5 motor are you running?
SRW141 is offline
Old 07-09-2009, 09:35 AM
  #4782
Here more and more racers want a Tekin Redline 10,5T motor.
When they see it, they want it. LOL
A member of an other club told me that I wasn't lying about the speed of the Tekin motor. Now he want's one to and a Tekin RS Pro.
Tekin is growing out here
GM is loosing a lot of drivers
Fastest speedo is the Tekin at the moment.
GM can run the same top speed but than only for 5 laps and the motor is gone.
The Tekin runs all 5 or 6 mints and the motor temp is about 70C.
Tekin is going faster and faster.
The speedo is going better and better and that for that price.
Normally you must buy a new speedo. Tekin just updates it and that even for free.
I can't wait till the next update comes.
mikky32 is offline
Old 07-09-2009, 09:39 AM
  #4783
Actually, a voltage booster is a GREAT way of doing it. Zero maintenance, Zero setup, and they don't weigh a thing. Also... no room on a WGT chassis for electronics? There is ALL KINDS of room... I have 10x the amount of free space on my WGT than I do my sedan. I literally have room for 4 or 5 more boosters
Either way.. in the future, when you change your mind and eventually run it, you will see the RS' 1s checkbox is a nice feature to have on the speedo.
Old 07-09-2009, 09:43 AM
  #4784
MoGGo's Avatar
Bag O Skill, I am improving all my PB's at tracks this year with the RS Pro. I have gone from 3.6 to 4.8 at my home track just to give you an idea. That is full boost, no turbo
MoGGo is offline
Old 07-09-2009, 09:54 AM
  #4785
Official's Avatar
Hi,
i've recently switch from nitro to electric and gotten myself a RSPro and Hotwire.
Just wondering whats boost and turbo???
Can't seem to find it in the interface panels???
Official is offline
