Old 07-03-2009, 07:06 PM   #4666
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by mikky32 View Post
witch motor are you using?
My speedpassion doesn't brake so much but my redline an lrp brake great.
The genius 120 has also a problem with the Speedpassion motors. They burn them!! lol
Can you let me know your hotwire settings Mikky? I run the redline motors and I dont get good brakes so I reckon you might be able to help me.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 07-03-2009, 07:37 PM   #4667
Trader Rating: 76 (100%+)
Originally Posted by Krio View Post
Ah, yeah if you are on such a high traction surface gear down from my suggestion. Gear so that you come off the track after 5-6 minutes at 140 to 160 degrees
Got it. One last question. I just got done running in the street and through some neighbors grass for just over eight minutes (checking the temp every two). I had read somewhere that some guys place a sticker on the can because the chrome motor can doesn't let the temp guns read correctly. Now, on the thin red sticker the temp read 180-190. On the can itself it was 150ish. So, should I gear down a tooth and maybe take a couple of numbers out of the boost? Or just gear down a tooth and see what happens? Thanks for your help Krio.
Ken
MUDVAYNE is offline   Reply With Quote
Old 07-03-2009, 09:24 PM   #4668
Krio's Avatar
Trader Rating: 150 (99%+)
Ken
The shiny can does indeed give much lower numbers using an infrared temp gun. I always temp my motor on the black sticker on the end of the can. If you were reading 190 on the red endcap you should definitely gear down when running through grass and romping around the street. That may change when you hit the track though so be sure to check when you start laying down laps.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 07-03-2009, 09:33 PM   #4669
Cool, thanks man
Old 07-04-2009, 12:07 AM   #4670
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
How does my RS pro have the V199 software? Baught it used by a pro driver... i thought the 199 wasnt available yet...
Alex
hound_dogs_01 is offline   Reply With Quote
Old 07-04-2009, 01:43 AM   #4671
U just answerd u r own question. N got a pro in trouble by posting that
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 07-04-2009, 02:53 AM   #4672
My brake is at the moment on 100.
reverse 0
But I think that you have the most problem with the EPA settings.
I have added after calibrating 20 extra epa. So from 100 to 120 fw and bw.
With the Speedpassion motor I don't have a lot of braking.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-04-2009, 06:15 AM   #4673
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Marcos.J View Post
wow just joined to make this post??
NO just feed up with the Tekin rs pro with having NO brakes no matter what and the same with other racers i put up with it for to long and put a spx in and same with others no problem with brakes.Hopefully something harder is done to find out what is the problem as i still have my rs pro.
regards clinton
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 07-04-2009, 06:21 AM   #4674
1M
1M's Avatar
Trader Rating: 35 (100%+)
I don't know what the problem is with guys not getting enough BREAKS. I have mine set up with only 30-40% and works good Any more than that is TOO much.
1M is offline   Reply With Quote
Old 07-04-2009, 06:32 AM   #4675
Same here. I installed a 13.5 in my T4 and had to turn the brakes down to 50% in the radio so it wouldn't spin out.
Old 07-04-2009, 06:34 AM   #4676
vazzo's Avatar
30-40% on the speedy? And what about the brakes on your tx?
Cheers
Adrian
Old 07-04-2009, 08:38 AM   #4677
I run a SP 13.5 and 10.5 and have my brakes turned down to 50 and 60% on the speedo and my KO radio is set at 150%. If I set my speedo any higher the car locks up. When I run my eXpress DUO motors I drop the speedo a little lower.
I've been running on tracks with 100'' to 250' back stretches and fast sections that require alot of breaking.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-04-2009, 09:33 AM   #4678
razzor's Avatar
There seems to be some hassles with brakes on some setups and Tekin is working on it.
I have very weak brakes at speed but on slow corners its fine.
I am using drag brakes to slow the car down and adjust my driving for know.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-04-2009, 09:39 AM   #4679
1M
1M's Avatar
I use the DX3R with 100%.
I have 2 Late models and 2 sprint cars both set up with RS esc with either 13.5 or 17.5. No problem with breaks on any car.
Old 07-04-2009, 09:47 AM   #4680
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Default high speed braking issue
One more time with feeling ... ...
(1) The braking issue is specifically related to high speed braking on large tracks (eg: approaching a very tight corner, usually at the end of a high speed section of track). We are talking about modified car speeds (4T/4.5T BL speeds) with a 10.5T (or 13.5T) BL (and of course, TEKIN RS PRO with Boost).
(2) Randy is looking into this specific "high speed braking issue".
(3) Hopefully we will all hear some results soon
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
