Old 06-23-2009, 09:25 AM   #4456
razzor's Avatar
Originally Posted by mikky32 View Post
Nice track but were are you using the brakes? (Except the 180 corner)
And why drag brake?
Looks like a smooth track.
i dont use drag brake but with the weak brakes i was trying anything.
I use brakes for the cut in on the back straight and again on the hiarpin in the middle straight.
I like to run deep into the corner and use brakes at the last moment to get on the apex.
Its the 2 places a lot of guys can make mistakes and run too deep so i always keep on the inside to avoid getting tangled with them.
Also mainly if attacking or defending for position.
If not pressured by anyone i carry a wider, flowing line through those corners.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-23-2009, 09:32 AM   #4457
A lot of the tracks in the UK have hairpins at the end of very fast straights or sweepers and they provide ideal overtaking opportunites. When the guy behind you is no more than a few feet back, you cannot brake early or take a wide line if you want to be in the lead as you exit the corner.
We might not need brakes for 95% of the circuit length, but when you don't have them for the one corner you need them, you're at an instant disadvantage.
THancock is offline   Reply With Quote
Old 06-23-2009, 09:52 AM   #4458
Ok.
It's a good looking track.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-23-2009, 10:01 AM   #4459
MoGGo's Avatar
Or indeed if you want to make it round the corner at all Tim if the guy behind is gunna brake later than you no matter where you brake!!!!
MoGGo is offline   Reply With Quote
Old 06-23-2009, 10:07 AM   #4460
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by or8ital View Post
Seems like you would lose a lot of speed
Your starting to catch on ...
This is a good example where heavy braking is required.
At the local track of interest (here in Australia), I'd say cars are literally MILLI-METERS apart at the very tight "S" corner.
ALL drivers are standing on the brakes.
It's a crawl through the initial part of the "S" corner.
Unfortunately, the TEKIN RS PRO takes about TWICE the stopping space, so the result is a bunch of surprised drivers trying to avoid the rear of my car.
If I brake later, I end up a few feet past the corner.
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 06-23-2009, 10:19 AM   #4461
cosmo1974's Avatar
The 210 Foot is still a small straight out here. MACH is a lot bigger.
And we drive with 5 cell and a 10,5T almost as fast as a 13,5T Lipo.
In Australia, the "rats" are called "kangaroos" - now thats big
But seriously, the 10.5 BL guys are only a little slower than the 4.5T BL guys.
If I set the the FDR at 4.3 (& 30 boost), I'd say the car is very close to the 4.5T BL guys straight line speed.
Cheers
Old 06-23-2009, 10:23 AM   #4462
Trader Rating: 38 (100%+)
Cheers
10.5 is mod in the US. Probably where some of the confusion came from? With a 17.5 motor brakes would almost never be used.
or8ital is offline   Reply With Quote
Old 06-23-2009, 11:12 AM   #4463
John Tag's Avatar
Trader Rating: 42 (100%+)
Except me...LOL I run my RS with 17.5 motor 60-70% Drag Brakes and 100% on other brake settings. I did a few weeks ago notice some brake fade..I rebooted speedo and reset radio and all was fixed. Newer softawre is even more aggressive for braking 198 ect.......
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 06-23-2009, 11:35 AM   #4464
Wow Tag, you need to dial in some steering! . We got guys that can take a high speed sweeper at the end of a 160' straight and turn back into the boards 180 degrees full speed at about a 6' radius.
Old 06-23-2009, 11:47 AM   #4465
Remember it is Tag we are talking about.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-23-2009, 12:01 PM   #4466
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The RS and RS Pro use the same software. We're looking into the large track issues where brakes seem to be lacking.
Most turn the brakes down in the RS and RS PRo. You should be just fine with your F104.
I would still appreciate everyone having a braking issue to send me a screen shot, your radio being used, gearing, battery power, motor being used(wind and brand). We can fix anything we need to. I just need to make sure I get the same setup as you're running so I can test/verify the concern.
Thanks guys.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-23-2009, 12:21 PM   #4467
Ok here is my ? I am running vta 21.5 trinty duo what is a good setting and gearing to use 4.2-4.6 please help.
Detroitlion is offline   Reply With Quote
Old 06-23-2009, 01:13 PM   #4468
Cheers
I now. I drive some times a 10,5T Lipo.
It's on our track just like mod.
The mod lap record is 13,88
the 5 cell 10,5T lap record is 14,07
The fastest lap with a 10,5T Lipo is at the moment 14,12
I think that the Lipo will go a lot faster but the driver that set that time was driving that in teh training and not at race speed. I now he will go as fast as mod as he uses new tires.
Our rats are still small. Than they still fit in the rat traps
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 06-23-2009, 04:48 PM   #4469
cosmo1974's Avatar
If mod is 10.5, what do you call the 4.0/4.5T (or similar) class?
Cheers
Old 06-23-2009, 05:00 PM   #4470
cosmo1974's Avatar
Thanks guys.
Randy,
Good to hear that its a doable firmware fix.
Apart from the Hi-Speed braking issue, the car with RS PRO + 10.5 Redline is:
-- a bullet off the start line
-- as uncontrollably fast as I could possibly hope for
Cheers
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
