Old 06-09-2009, 11:53 AM   #4186
timmay langdell's Avatar
ricky at the west london national i had mine geared at 5.95 with a nosram motor had max boost and motor at std timing....was mega fast.
i found that running the gearing from say 5.2 - 5.9 there was no speed differance just more acceleration and cooler speedo and motor
did a 19 in 9 the week before witch is pretty quick round there on the gp track with that gearing.
tim i think your brake issue is down to the motor mine has no brakes what so ever with my nosram but with a gm its doing endo's lol
timmay langdell is offline   Reply With Quote
Old 06-09-2009, 03:24 PM   #4187
How good is this speedo in comparison to a gm 120 or lrp spx stock spec with 9.5er motors?
And does anyone know where I can buy tekin products in germany?
Thanks for your help.
Lutz is offline   Reply With Quote
Old 06-09-2009, 04:45 PM   #4188
Trader Rating: 37 (100%+)
Hey Tekin folks, is there any hope at all for the Hotwire interface on iphone?
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 06-09-2009, 04:59 PM   #4189
stitchy's Avatar
haha, that would be sweet.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-09-2009, 05:03 PM   #4190
TheCoolCanFanMan's Avatar
Originally Posted by mikky32 View Post
Take an other line into the first corner. I do it all the time and all my start's made me win 2 to 3 places after the first corner and i never use the brake. I drive one way so i can't use it on full power.
When i drive with a spool i don't have braking problems. enough braking power for me.
And if Tim had done that, I would have gone underneathe him
Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 06-09-2009, 05:04 PM   #4191
In Reedy Race...Any participant in modified with RS-Pro?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 06-09-2009, 05:12 PM   #4192
It would be a lot easier and less costly to do one for the G1 and other upcoming Android phones given that the OS is open source.
Old 06-09-2009, 05:30 PM   #4193
MarkBrown's Avatar
I believe Jason Moberly was the top RS Pro driver in the Reedy Race.
MarkBrown is offline   Reply With Quote
Old 06-09-2009, 05:42 PM   #4194
Trader Rating: 59 (100%+)
Send a message via AIM to todb
i have moved to the far east and i am planning to keep running TC but the class for me has changed from 17.5/rubber to 10.5 rubber at this track. http://www.rctech.net/forum/electric...ned-korea.html. lucky me. i am wondering how good the tekin 10.5 is compared to duo, orion, speedpassion. most of the guys there run lrp and speed passion equip. i dont want to change cuz the support at tekin is awesone but i still want to compete. my 13.5 was wicked fast in my foam car and i would like to continue using tekin equipment. any idea's because i love the red in my serpent s400 kicking the blue guys butt's. thanks for any help.
todb is offline   Reply With Quote
Old 06-09-2009, 08:23 PM   #4195
MAD916's Avatar
I also ran the RS Pro at Reedy till Friday when Randy gave me an RX8 to put in. We did have some temp issues the the RS Pro in Mod so the quick fix was an RX8. We did a case Mod, stood it on it's side, and added a fan to the bottom of the case, and problem solved. also the new software seems to be having a side effect of a cooler motor. been running it at our track since the Reedy in Mod GT with NO Problems..... 2 led' on temp after 6 minutes, and a good bit of rip. 200' straight and big pulls in the infield.
The new software is great, and really provides control over when the second gear punch hits....... will be doing some more testing this thursday
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 06-09-2009, 09:13 PM   #4196
Team-RTR's Avatar
whats a good setup for the RS Pro(Hotwired) with the Redline 17.5 motor. have been reading boost timing is very touchy (too little not enough power, too much destroys the motor) also a starting rollout (or FDR) for a small-med sized track.
Thanks.
Team-RTR is offline   Reply With Quote
Old 06-09-2009, 11:08 PM   #4197
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Jason was running the Rs Pro in the mod class and does so regularly. 2 caps and a small fan running either a 4.5 or 5.5. He pulls off at 5 led's.
Our 10.5 is right there and better than most. We've had a lot of them tech's for good reason!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-10-2009, 01:49 AM   #4198
Default Brakes
Thanks to those responding about the brakes. I can confirm that:
1. I am running in sensored only mode.
2. The brakes are pants with Novak, Orion and Speed Passion motors.
3. I don't use drag brakes, only manual braking on the trigger set to full strength using the Hotwire software - I'll take you up on the settings check at Bashley though Ricky
4. If I'd have gone wide to take a line that didn't require brakes, Malcolm would indeed have been up the inside of me and no doubt it would have ended in tears The next track we're at has a lot of hairpin type corners and is very narrow so brakes will be an important factor there.
This is running 13.5 motors and I am geared between 4.6 and 4.9 depending on the track layout.
- Tim.
THancock is offline   Reply With Quote
Old 06-10-2009, 03:10 AM   #4199
so where can I buy the rs in germany?
The Tekin homepage doesn´t tell me...(under construction)
Old 06-10-2009, 03:38 AM   #4200
- Tim.
I have the speedpassion motor to but is is not a good motor.
braking is not good with that motor and don't get it to hot.
The motor is not from the quality as that from LRP and Tekin.
I use now a LRP motor. braking goes good with a LRP. tried it.
I hope that i can drive this Saturday. Going to drive with the Tekin.
Didn't get any top speed but with some setup changes i think it will go better.
Going to drive spool again. is better with training as there are some slower drivers on the track.
Don't want to drive them out of the track.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
