Old 05-31-2009, 09:15 PM   #4051
MAD916's Avatar
Hey Randy: Sent ya an e-mail with a weekend update. The mods and the software update we did at Reedy worked great, it was a hot weekend with 140 track temps and had only 3 to 4 LED's after 6min run in Mod GT with good rip.
Guys the wait on the software will be worth it, and the support from Tekin both at the track and in the Cyber world are first class.
Thanks again
Mark
TZR
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 06-01-2009, 02:42 AM   #4052
MoGGo's Avatar
Hey Randy, what time shall I pick you up from the airport so you can help me at West London next weekend?
MoGGo is offline   Reply With Quote
Old 06-01-2009, 03:51 AM   #4053
Con
Originally Posted by home13oy75 View Post
I'm currently running the RS PRo 17.5 on a medium sized outdoor parking lot track. My FDR is at 4.0, timing on motor = 0, and 30 of boost. I'm also running the 198 software. My temp on the motor was 195 F. I was wondering if I can get some advice on if I should lower the boost to say 20 or gear up 2 teeth on the pinion. THe top end seems decent, maybe a little sluggish on the bottom.
THanks in advance.
You better gear down 2 or more teeth,That with give you your grunt out of the corners back and get the motor temp down. With 30d boost I'll bet your top speed won't suffer any
Con is offline   Reply With Quote
Old 06-01-2009, 10:23 AM   #4054
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
THanks in advance.
Gear up two teath on the pinion??? That would only make you come off the track at 200+ degrees. It would look to me like you are geared a bit high and might need to come DOWN a couple teeth on your pinion. I too run an RSpro, 17.5 redline, on a medium/large outdoor track, 0 timing on motor, 30(max) on timing boost, and my FDR is 4.7. I have plenty of rip, and my backstraight speed is fast.
Try gearing down to 4.5 or so... and check temps. My car geared at 4.7 comes off at about 160 degrees.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-01-2009, 01:59 PM   #4055
I'll try a FDR of 4.5 ... thanks for the advice guys.
home13oy75 is offline   Reply With Quote
Old 06-01-2009, 02:16 PM   #4056
GasGod's Avatar
I just got an RS- loaded w/ 1.89 Max boost.What do you do if you cant adj. the timing back to zero?I am running a 17.5 lrp stockspec and see no timing marks on the can or endbell.Do I have to have someone lower the speedo?I am at 4.23 fdr now and the temps >3min are 160-I dont want to fry this motor as I already fried a pulse(I know but it ran good on a losi speedo b/4 for 3 wks).The pulse had 5 deg in the motor.Also after about 3 min. it seems to slow down a tad is this a thermal issue?Should I gear down more?Sorry for all the ?? but I am kinda a noob on B/L stuff. I used all tekin stuff "back in the day".
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 06-01-2009, 02:42 PM   #4057
I drive a LRP x11 10,5T
I use 18 to 23 boost
works great.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-01-2009, 02:44 PM   #4058
GasGod's Avatar
So I should have someone w/a hotwire lower the boost then?
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 06-01-2009, 04:53 PM   #4059
BagofSkill's Avatar
Guys, looking for a little reality check....
I race rubber tyres touring cars with the RS PRO (1.94) and a SP13.5 + Li-Po. The track is 20m x 10m, that's 66ft x 33ft, just smaller than a basketball court. see picture below. Lap times are 10.5 seconds.
I've been running 25 boost and 35.76mm (1.41in) rollout. It's been good but this week for the first tim I got beaten for speed by a guy with a GM 120.
I dropped the rollout and picked boost up to 30, and picked up a bit of speed but also a bit of heat. Didn't get the chance to re-gear to bring the temp down though.
But I want to check if I'm in the ballpark for this size track or should I be dropping back on timing and gearing up?
By way of comparisson I used to gear a Novak GTB and SS 13.5 at 40.87mm (
1.61in) and that always ran well.
Any one got a suggestion?
BagofSkill is offline   Reply With Quote
Old 06-02-2009, 02:58 AM   #4060
over gear's Avatar
Trader Rating: 15 (100%+)
problem with my RS. all the leds are lightly dim and the motor is not running. it's a LRP 17.5. when i removed the sensor cable, it works... i tried a brand new sensor cable... the motor will not run... all the leds stay lightly on. What's happening?
over gear is offline   Reply With Quote
Old 06-02-2009, 03:40 AM   #4061
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Hi Guys,
I am planning to run my touring car on mod class (with a 5.5 brushless) in an upcoming race. I normally run 10.5, and i love my speedo. i would like to have some clarification:
In my RS PRO should i use double capacitor and a fan on the post or is not necessary??
If the second capacitor is needed could i use only one capacitor but bigger instead, for example the TT3522, 1000 uf?
Thanks for the great products and the fantastic customer service.
Lorenzo
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 06-02-2009, 03:56 AM   #4062
Skitee's Avatar
Maybe that's a problem with the actual sensor board in the motor, do the led's go off or change at all if you change the rotor position.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-02-2009, 05:13 AM   #4063
yes lower the boost to 18 and gear heavier.
You will have more acceleration and speed.
also an other motor will give you some more speed.
Here the GM's are slower on smaller tracks. They can't keep up the pace in the infield. The Tekin is there a lot faster.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 06-02-2009, 06:50 AM   #4064
MAD916's Avatar
you will want to run a fan on the ESC if you are running MOD, also the 2 caps will help, rather than a single large one. (lower IR and faster revcovery). the fan on the post help, but the majority of te heat is from the FET which are located in the bottom of the case. I have a modified install where the speedo is on it's side.
running in Dual mode instead of sensored only will also help keep speedo temps down.
Old 06-02-2009, 07:03 AM   #4065
reenmachine's Avatar
Trader Rating: 26 (100%+)
How did you get the boost to max in the first place? Someone else do it?
Yes, you need to lower boost. It's not something just to set to "max". With that LRP's fixed 12 or so of timing you boost should be about 18 to start and watch temps. I think you'll find your FDR is about right after that.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
