Old 05-24-2009, 02:54 PM   #3901
2wdrive's Avatar
Originally Posted by timmay langdell View Post
how hot are your speedos getting mine was 75c today the motor was only 65c!! only noticed when the double sided tape holding the speedo in had stoped holding it in run a fan on it for last 2 runs and was 10c cooler.
I gues you are running mod? With mod always put a fan on the posts.
2wdrive is offline   Reply With Quote
Old 05-24-2009, 04:47 PM   #3902
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by John Tag View Post
Im thinking back shoot into sweeper wfo is 175 ft , Which is as big as any US track I have ran and I have run many..LOL Set up was with DUO based motor low timing hole(10*) and profile #3...
(1) Just to clarify, thats the Trinity DUO 17.5 and ESC Throttle Profile 3.
(2) Have you tried any other 17.5 motors (eg: the TEKIN redline), and if so, how do they compare with each other ?
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 05-24-2009, 05:22 PM   #3903
John Tag's Avatar
Trader Rating: 42 (100%+)
1) Yes DUO and ESC Profile #3
2)Only motor I have good data on is duo at moment
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 05-24-2009, 06:15 PM   #3904
vazzo's Avatar
Trader Rating: 100 (100%+)
Trinity motors aren't the best (sorry), we had a Trinity and a Tekin both geared exactly the same and the trinity smoked on the last lap and was noticeably slower throughout the race. Could have just been a bad motor I dont know but all the Tekin motors I've owned I havent had a single issue with.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 05-24-2009, 06:40 PM   #3905
hacker's Avatar
Trader Rating: 141 (100%+)
how much use did your trinity motors have?
I'm guessing the tekins were new.
Its hard to judge one motor to the next without having testing 2 brand new motors!
hacker is offline   Reply With Quote
Old 05-24-2009, 06:48 PM   #3906
tallyrc's Avatar
and all motors are geared differently..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 05-24-2009, 07:01 PM   #3907
witz_dan's Avatar
Trader Rating: 25 (100%+)
Default duo as well
john im running very similar to yours.
17.5 duo
10* on motor
20* boost
though im running profile #5
though i cant get anywhere close to 4.3 im running around 4.9 coming off the track at about 165 and im getting left on the straight.
any recommendations?
witz_dan is offline   Reply With Quote
Old 05-24-2009, 07:02 PM   #3908
Team-RTR's Avatar
Originally Posted by mikky32 View Post
Witch motor?
because els i say 23 boost. motor must be on a timing of 12.
looking at running a CO27. any help would be great
Team-RTR is offline   Reply With Quote
Old 05-24-2009, 07:14 PM   #3909
John Tag's Avatar
17.5 duo
10* on motor
20* boost
Try full boost..Im at 30 Full..Just watch temps.
Old 05-24-2009, 08:25 PM   #3910
Trader Rating: 38 (100%+)
Duo I used the following:
- Middle hole on the motor
- 22 degrees boost
- 3.76 FDR
This was for a large track but it was very fast on the straight. This particular motor always liked a lot of gearing. Unfortunately I toasted it this weekend. I meant to turn the motor timing down and for some reason I mistakenly turned it up (I may have had a gear mesh problem as well) and after about 3 minutes the motor got to 241 and melted.
or8ital is offline   Reply With Quote
Old 05-24-2009, 08:33 PM   #3911
Trader Rating: 76 (100%+)
- 22 degrees boost
- 3.76 FDR
Ah, so you're the one Randy was making fun of this weekend.
MUDVAYNE is offline   Reply With Quote
Old 05-24-2009, 09:01 PM   #3912
Yeah, not sure what I was thinking. I was rushing to fix stuff and at the last minute thought, hey Im going to turn down my timing by moving it to the first hole and for some reason moved it to the 3rd. Then when putting the motor back on didn't get the mesh right so quickly tried to fix it before the run but was running with a partially stripped spur. So between those 2 things the motor melted. The car was BALLISTIC during that run though. I guess that should have been my first clue.
It was a rough weekend for me. Bunch of weird stuff kept happening in touring car.
Old 05-24-2009, 09:15 PM   #3913
SammyZ's Avatar
Trader Rating: 138 (100%+)
will hotwire work with vista 64x?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-24-2009, 09:31 PM   #3914
Default Hotwire v3.25
this is anoying.... vista 32, never had any tekin software on it ever. So the deleteing tekin.esc procedure will have no effect before install. So after installing v3.25 straight off the tekin website, i get the values outside range error when i plug the car in.
Tekin.. please cancel your programmers rock climbing holidays and get him/her/them to write a nice version and stop using the users as a beta testing ground. I/we dont mind beta testing car related features, but when a program wont even install with out tricks and gives errors like im getting, then your just wasting our time.
Now ive had my winge, how about a pda version ???
BTW i love my rs pro, just not the software.
zharn is offline   Reply With Quote
Old 05-24-2009, 11:51 PM   #3915
vazzo's Avatar
Hey Guys
if you want really good info on Tekin gear go check their website out they have forums on there as well with a lot of info on software/settings etc http://www.teamtekin.com/forums/
Cheers
Adrian
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
