Old 05-22-2009, 02:11 PM   #3841
Skitee's Avatar
I also haven't had problems with my 2 rs pro's, I have upgraded through 4 versions now (1.80, 1.83, 1.94, 1.98) and haven't had any difficulties.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-22-2009, 02:37 PM   #3842
razzor's Avatar
same here no issues.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-22-2009, 03:01 PM   #3843
2wdrive's Avatar
I uninstalled it again. Reboot the computer. Installed it on my computer again. And got the exact same thing. Did it twice now and i get the same results. A green box with that message in it. Strange to say the least. I have the older 1.98 version still on my laptop. Will see tommorow if that still works alright.
2wdrive is offline   Reply With Quote
Old 05-22-2009, 03:16 PM   #3844
Trader Rating: 76 (100%+)
I believe you have to un-install all the versions, then install the version you want. I have been through several versions, with Vista no less, and haven't had any issues.
MUDVAYNE is offline   Reply With Quote
Old 05-22-2009, 03:19 PM   #3845
2wdrive's Avatar
i deleted the software through start/configuration/software and deleted the hotwire sofware. Normaly that did the trick. How else can i delete it?
Old 05-22-2009, 03:31 PM   #3846
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
uninstall through the control panel,thats what i did with the first version of the 198 with the 1 cell problem and didn't have any issues but now there is,but not a big deal
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-22-2009, 03:35 PM   #3847
2wdrive's Avatar
yeah i deleted it through the control panel but the problem is still there after the 5th time. I will see tommorow at the track if anything is wrong.
Old 05-22-2009, 04:06 PM   #3848
Are there already some results about the Tekin on the reedy race?
I now TOP is dominating the practice right now in mod and stock bud i don't now wo is driving with the Tekin.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 05-22-2009, 04:39 PM   #3849
Well I know first hand that a friend of mine is running the Tekin with some new software that Tekin has given to one of ther team drivers and the new software is very very very close to being right!! They were working on getting the turbo to kick in alittle earlier. The straight away speed is identical to one of the fast fast guys running for TOP in 13.5!! I am very impressed and think by the end of the Reedy this weekend I think the new software should be right were it needs to be for a big track like SWR!!
bigdog is offline   Reply With Quote
Old 05-22-2009, 04:40 PM   #3850
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
what?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-22-2009, 04:44 PM   #3851
As fast as EJ Evans with his Photon?
Can't wait till i have the software.
2WD kijk hier even. eerst is het een instructie als je een txt krijcht maar daarna word het uitgelecht hoe je de software weg haald. dus ook die hidden file. http://www.youtube.com/watch?v=tTp3tUL9u8Y
Sorrie its in dutch. easyer for me.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 05-22-2009, 08:06 PM   #3852
Super Moderator
Im having the same problem with this new error. I uninstalled the old, installed the new, and the second the program connected to my ESC, I got the incompatibility error message. So I reset the ESC back to factory defaults, then reset my custom settings. The second I update my ESC with the new settings, I get the same error message again. Then i click on "current settings"... and it shows that the settings have been reset back to the defaults....
If I unplug my esc from USB, then replug it in and relaunch my tekin hotwier... most of my settings have stayed, but "timing boost" now reads "GO". I can adjust my timing boost up and up and up and apply the settings each time. if i go to high (the max is now 45 by the way)... it will error out the program. Now that it errors out, I can't set the timing boost ANYwhere.... even down to 5 or 6 without the error.
I installed it on another machine, which has never seen tekin software, and the problem is there as well.
Tekin guys... I need a fix or something asap... got a race this weekend. Whats the delio?
- RCSpecialties -
Old 05-22-2009, 08:57 PM   #3853
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Anyone happen to know what the stock timing is set at on the Tekin 13.5 motor? I never ran 13.5 brushless yet so trying to get some final info before I hit the track tommorrow.
ST Racing Concepts (STRC)
Old 05-22-2009, 11:02 PM   #3854
mojoman's Avatar
I don't know the stock timing but, if you're running a RS at the "C" try a 4.2 or lower fdr (especially with the current layout). Check motor temps after a 6 minute run. Gear from there.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 05-22-2009, 11:23 PM   #3855
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Stock timing is 12 out of the box.
Your boost will not go to 45 even if it's showing it.
For those having install issues I'd like to know what OS you're using?
If you are running Vista you MUST delete the hidden file in the "virtual store" folder. I made a video to show you how to get to it:
We have the speed we're looking for. There is always room for improvement. We have some of our biggest sceptics running the RS against the SPX's and they too are liking it.
EJ is a super fast driver and is one to watch. But it's he's not running anything special. His car is super dialed and he's running faster than some mod guys. His car has mad corner speed and just looks to be in a different level. He does have competition and racing is racing.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
