Old 05-08-2009, 03:10 PM   #3661
Originally Posted by timmay langdell View Post
hi what is the differances between the 189 and 194?
i runing the 189 at the min with 10.5 and must say its very good, but as i dont have a lap top i didnt want to change it as it means a journey home if its not as good and a wasted race meeting.
I seem to remember Randy saying 194 would be a bit slower for TC and thats certainly what i found. It just seems to lack top end compared to 189 and seeing as 198 and 194 dont bring any real "TC" upgrades, im sticking on 189 till the new TC firmware comes out.
Changes in gearing may fix the problem, but why change what isnt broken?
HTH
Ian
DaSloth is offline   Reply With Quote
Old 05-08-2009, 03:19 PM   #3662
ghiro's Avatar
Send a message via Skype™ to ghiro
Originally Posted by Krio View Post
The RS is perfectly fine to use with 27 and 75 mhz band radios.
ouch! . . . how about 40Mhz ? Does it have any porblem with the RS ?
I'm thinking to buy one for my Pan car. I love that dual drive feature.
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 05-08-2009, 03:54 PM   #3663
Krio's Avatar
Trader Rating: 150 (99%+)
I personally have not used it with 40 mhz, but there is absolutely no reason it wouldn't work.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 05-08-2009, 03:59 PM   #3664
The Tekin has with non of the transmitters problems.
LRP has but Tekin not.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 05-08-2009, 04:18 PM   #3665
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
HTH
Ian
How would a different version of the software make the ESC slower with ONE particular kind of car? This doesn't sound right.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-08-2009, 04:48 PM   #3666
miller tyme's Avatar
Not sure but 194 is 4cell pan car oriented, I would guess it has to do with throttle/current limiting curve. Lower voltage with lighter weight would have different needs than a 7.4 volt touring car.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 05-08-2009, 04:54 PM   #3667
hacker's Avatar
Trader Rating: 141 (100%+)
ive run mine on 40mhz and no worries.
hacker is offline   Reply With Quote
Old 05-08-2009, 05:09 PM   #3668
Super Moderator
That can't be right. Tekin guys care to chime in on this please?
- RCSpecialties -
Old 05-08-2009, 05:31 PM   #3669
Krio's Avatar
1.94 is meant for lower voltage mod applications (4-5 cell nimh) where the low voltage forces a lower turn motor and high current draws for power. It is meant to be more "efficient" so motors run cooler.
I think
www.kriostasis.com
Old 05-08-2009, 06:09 PM   #3670
e4rs's Avatar
HTH
Ian
HI glad i read this. updated to the 194 and it was bad 4 tc no top end thought i might have been the tekin 17.5 that i was running for the 1st time.Had temps about 60deg on a cold night about 17deg air temp i allways have fast motors but could not get this thing to work so i will go back to 189 there was my mate that was running the 189 same rollout but he was much faster every thing on my speey was set right and the control was calibrated right.any idea on this
=Team Gooch Racing=
e4rs is offline   Reply With Quote
Old 05-08-2009, 06:37 PM   #3671
bkspeedo's Avatar
I've ran 189 and 194 with my 7.4v 13.5 TC and have found 194 to be better overall. You just need to adjust gearing from the 189 software.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-08-2009, 06:45 PM   #3672
e4rs's Avatar
hi would you go up or down from the 189 to 194 as for temps the night was cold and the temp on the motor was 60deg and it was still slow and there was 1 guy runny 58 rollout and his temps was about mid 30deg
=Team Gooch Racing=
Old 05-08-2009, 07:46 PM   #3673
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
189 and 194 should not show any speed differences. If you have an old version of 194 or got it from someone other than myself you might not have the right setup.
198 will be back on the webpage soon. If you use the same settings on 189 and 194 the speed should be the same.
So for those that run full boost setups you should notice no difference. Team driver Jason Moberly and myself along with a few other "test subjects" ran them back to back in the same cars with very controlled conditions and they're the same. We used a radar gun to prove it along with timing and scoring software.
While 194 had mostly updates and improvements for 4 cell and low voltage applications it can be just as fast if not faster than 189. If you were running different boost and motor timing setup you will simply need to make minor adjustments to get the speed back.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-08-2009, 08:30 PM   #3674
bkspeedo's Avatar
I'm in the 35mm rollout range with 63mm rubber tires, FDR 5.7 on a average size indoor carpet track. I geared down a few teeth from where I was with 189. Although I made other changes so as Randy mentioned there probably similar. Although some people are seeing there motors run cooler when changing from 189 to 194 without changing boost or gearing. I'm currently running full boost with min timing on a Trinity Duo 13.5 in an Xray and am just as fast or faster then everyone else at our track.
On a large track try starting with a 5.5 FDR and move either direction based on motor temp. I would set your motor timing to 15deg and boost on the ESC to 25 as a starting point and adjust from there.
Brent Klingforth
5280 Raceway
Old 05-08-2009, 09:35 PM   #3675
STLNLST's Avatar
Trader Rating: 21 (100%+)
He said test subjects.....
STLNLST is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
