Tekin RS ESC sensored >
Old 05-03-2009, 06:54 PM
  #3586
Team Tekin
Randy_Pike's Avatar
YES!
Randy_Pike is offline
Old 05-03-2009, 07:36 PM
  #3587
HAVE A GENX10 CAR ALMOST BUILT WITH A PROLINE SOPHIA GT BODY,JACO SPEC TIRES FRONT AND REAR,BRAND NEW THUNDER TIGER TOOLS FOR THE CAR AND COMES WITH THE JRZ3650 SERVO. ALSO HAS A FEW PARTS WITH IT. ASKING 300.00
I HAVE A TEKIN RS REDLINE SYSTEM BRAND NEW 17.5 TURN SYSTEM
SALES FOR 300.00 I WILL SALE IT FOR $200.00
PRO MATCH BATTERIES 4 CELL 2 PACKS $40.00 FOR BOTH
EMAIL ME FOR PHOTOS!!!
[email protected]
PUDDIN is offline
Old 05-03-2009, 07:43 PM
  #3588
JimmyMac's Avatar
Originally Posted by NUCRPTRACER View Post
Any other suggestions on how or what I can do to fix this? xp,Acer netbook
Just figured it out if anyone else has this issuie go to windows help and download .netframework update....fixed immediately...
Good find. Since you mentioned it, I think netframework window popped up for a second after my install... I think something about up-to-date or something like that. I keep my netbook up-to-date with that stuff because I use it in college sometimes. So I guess if anyone else is having issues should check that out.
Anyways, today I ran the 198. No issues. Car ran pretty good in 17.5. Boost maxed out. Throttle 3. Drag brake 5. FDR 4.31 on a 009 with internal of 1.9. Express Duo with zero timing. Motor temp at 160°ish. Track temp 100°ish. Horsepower layout. Next weekend I'm gonna play with motor timing and turning the boost down. But so far so good.
JimmyMac is offline
Old 05-04-2009, 01:09 AM
  #3589
e4rs's Avatar
hi what is the best throttle profile to use is 5 the best i have always used 3.
e4rs is offline
Old 05-04-2009, 02:10 AM
  #3590
Trips's Avatar
Trader Rating: 16 (100%+)
None of the profiles are better or worse than any other. All of them give full power at full trigger, it's just the feel at part throttle that changes.
1 has the least aggressive feel at partial trigger, 5 has the most aggressive feel, 3 is linear. IT comes down to personal preference.
Trips is offline
Old 05-04-2009, 02:50 AM
  #3591
e4rs's Avatar
thanks dude.
e4rs is offline
Old 05-04-2009, 05:12 AM
  #3592
StewartFan20's Avatar
Hello,
How is everyone determining whether to changer motor or speedo timing? For example, if you have 0 motor timing and 20 speedo timing, how would you determine to use 10 motor timing and 20 speedo timing or 0 motor timing and 30 speedo timing? Is it track size, traction levels, or personal preference?
StewartFan20 is offline
Old 05-04-2009, 05:41 AM
  #3593
vazzo's Avatar
Trader Rating: 100 (100%+)
Has anyone found any advantage to using the new 194 software over 189? I currenty run 17.5 with my RS Pro with motor zero timing and rs full boost. If theres no real advantage I dont think Ill bother.
vazzo is offline
Old 05-04-2009, 09:21 AM
  #3594
2wdrive's Avatar
just a question about the redline mod motors. Are the 2.5t, 3.0t and 3.5t 6 volt or can i run it with 2S lipo? I think the 3.5 from lrp was 6 volts only that's why i ask.
2wdrive is offline
Old 05-04-2009, 01:58 PM
  #3595
Rockpyle's Avatar
Trader Rating: 23 (100%+)
Has anyone noticed if their motors don't last as long running full boost and zero motor timing?
Rockpyle is offline
Old 05-04-2009, 02:30 PM
  #3596
JimmyMac's Avatar
Just curious, what motor ya running?
JimmyMac is offline
Old 05-04-2009, 02:34 PM
  #3597
As long as you gear it correctly and don't overheat the motor there is no reason why the motor wouldn't last as long in this configuration then any other. I have been running mine like this ever since this adjustment has been available to the public and have had no issues with the motor.
InspGadgt is offline
Old 05-04-2009, 03:02 PM
  #3598
Rockpyle's Avatar
I ran a Tekin 17.5 for a while and it lost power. I bought it used and it worked great for a couple months but now power dropped off. It came off around 165 f after 6 min in a touring car on carpet.
Rockpyle is offline
Old 05-04-2009, 03:53 PM
  #3599
Hey JimmyMac,
I was wondering what your running for a pinion and spur, as I'm just setting mine up to take out to the track.
RKP3.3 is offline
Old 05-04-2009, 05:11 PM
  #3600
JimmyMac's Avatar
Originally Posted by RKP3.3 View Post
Hey JimmyMac,
Since I'm running Motor FWD option with 1.9 gearing, I'm running 102/45. When I ran the stock 1.7, I ran 104/41. But don't expect much from my gearing. It seems alot of people can't run what I run. Honestly it's the only gear I run at all the tracks I go to (outdoors). Awesome results each time. But that's just me.
JimmyMac is offline
