Tekin RS ESC sensored > Tekin RS ESC sensored
Old 04-29-2009, 09:57 AM
  #3511
Mark you have PM!
Gray is offline
Old 04-29-2009, 10:09 AM
  #3512
MoGGo's Avatar
Thanks Randy, look forward to running the new setup. By dropping you mean a smaller pinion am I right. Just wanted to check. I run 48 dp so I quess around 3-4 pinions.
Thanks for the quick response too.......
Mark
MoGGo is offline
Old 04-29-2009, 01:38 PM
  #3513
Hi Mark,
Good to hear there will be another driver running the tekin motor n speedo at the stcc
If u fancy working on gearing and setup together a brooklands, let me know
Ian
DaSloth is offline
Old 04-29-2009, 02:18 PM
  #3514
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Randy_Pike View Post
I've seen quite a few guys on the team running a setup with 5 on the motor and 25 or so on the boost.
Funny you should say that -- I am finding this to be the case with me as well. I had to dial back the boost a bit and put a touch on the motor to get the results I wanted without getting too hot. I'm still running about a 4.2 FDR with a 17.5 vs. the 3.5-3.6 that all the Brand X guys are running. The radar puts me at 31mph on our straight just like them though.
reenmachine is offline
Old 04-30-2009, 09:32 PM
  #3515
mangoman's Avatar
Sorry in a bit of a rush at the moment.
Does anyone know an approximate rollout for a tekin 10.5 with an RS in a 12th scale. Mid/Smallish size track.
I assume boost is the go with that setup...
Thanks!
Martin
mangoman is offline
Old 05-01-2009, 03:49 AM
  #3516
miller tyme's Avatar
Thanks!
Martin
I run the Duo 10.5 with 0* motor timing, version 189/194 software, max boost and rollout about 2.40" or 61mm, that would be on roughly 90ft long straight carpet tracks with mostly flowing infield.
miller tyme is online now
Old 05-01-2009, 07:28 AM
  #3517
Bob~H's Avatar
I have ran at the Major Taylor Velodrome in Indianapolis recently and am needing some help with setup. I am running a 17.5 2s lipo setup in a pancar on a track that has an 1100 foot runline. Most people are in the 1.29 to 1.50 fdr. It is a pure speed high banked track. I am running 194 software at 9 degrees on the speedo and 12 degrees on the motor but still am considerably slower than the rest of the field.
Bob~H is offline
Old 05-01-2009, 07:54 AM
  #3518
mangoman's Avatar
Thanks miller tyme!
mangoman is offline
Old 05-01-2009, 07:59 AM
  #3519
Team Tekin
Randy_Pike's Avatar
Bob, that's only 21 degrees of timing between the motor and boost. I'd suggest bumping up to 12 on the motor and 18-20 on the boost. You're going to drop some pinions to use this setup but give it a shot.
Whos' beating you and with what?
Randy_Pike is offline
Old 05-01-2009, 09:04 AM
  #3520
Bob~H's Avatar
Thanks Randy. I was running 9 degrees on the 194 software since I had read on here that the timing boost below 10 was doubled. I had assumed 9 on 194 was like 18 on the speedo with 12 on motor for a total of 30, my bad. I will try your suggestion and drop pinions. The only setup I know is a local racer running an Orion 17.5 with I believe an LRP ESC. I have been running a 76 spur with 52 pinion, I would guess with the 18-20 on the speedo I would start around a 76/47?
Bob~H is offline
Old 05-01-2009, 11:26 AM
  #3521
JL
Over the last week I've installed my new RS Pro and Redline 10.5, installed the 194 software (Thanks Randy) and read ALL 235 pages of this thread!
This is my first brushless system and I'd like some advice please. Any advice for boost/timing set up and gearing for my home track would be very much appreciated.
It's 160 x 90ft asphalt in a TC with lipo. With a brushed 19t motor I'm generally geared between 4.8 - 5.0 if that helps.
JL is offline
Old 05-01-2009, 02:13 PM
  #3522
STLNLST's Avatar
Trader Rating: 22 (100%+)
No one likes you I think you are the first person to really test the 10.5 at SWR. Mo and been 13.5 and mod. I'm sure he may have an idea as to where to start. Randy is a cool guy. In fact I ran into him today at the shop. We was talking about a new Tekin rain proof speedo that he said can only be run this weekend (guys this is a joke so please don't email Randay or Jim looking for info)
The only advice I can give you is pull over when you see me coming.....LOL
STLNLST is offline
Old 05-01-2009, 03:15 PM
  #3523
JL
....umm, I think you must have me confused for someone else. I don't even know where or what 'SWR' is let alone have tested a 10.5 there! Looking at your location I guess it must be in or near Sacramento. About 5000 miles away from where I am across the Atlantic!
SWR must be something like the Stonehaven race track (home of the Much More UK GP) in Scotland then.
Check this clip out:
http://www.youtube.com/watch?v=OX2rgz6fB9s
Anyway, Randy if you've any gearing/timing advice I'd be grateful. Thanks!
JL is offline
Old 05-01-2009, 03:23 PM
  #3524
STLNLST's Avatar
My bad. There's another buddy on here that goes by JL but he must have lower case or something like that.
STLNLST is offline
Old 05-01-2009, 03:30 PM
  #3525
dawgmeat's Avatar
running speed passion 13.5 rubber outdoor tc weather will be around 86-92 degrees, using 194 profile, what a good FDR staring point for a mix layout with med traction, thanks in advance
dawgmeat is offline
