Tekin RS ESC sensored >
Old 04-16-2009, 07:14 PM
  #3316
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
I put the hotwire software in and restarted and all it does is have a pic of the hotwire and say 1 plug in esc 2 plug in usb. what else do i do to use the hotwire
20 SMOKE is offline
Old 04-16-2009, 07:19 PM
  #3317
reenmachine's Avatar
Trader Rating: 26 (100%+)
1 plug in esc
2 plug in usb
Seriously, though, is the ESC plugged to the Hotwire and the Hotwire plugged to the computer?
reenmachine is offline
Old 04-16-2009, 07:37 PM
  #3318
20 SMOKE's Avatar
yes it is and it does nothing but show the pic of what do do,the esc/hotwire light up and the only thigh that works is the update button.says searching website for up dates
the only thing i can think of is that it wasnt installed correct
20 SMOKE is offline
Old 04-16-2009, 08:41 PM
  #3319
STLNLST's Avatar
Randy- Are you coming out to Speedworld tomorrow for a little testing?
STLNLST is offline
Old 04-16-2009, 09:10 PM
  #3320
Team Tekin
Tekin Prez's Avatar
Thats work when you are a Team Manager
If the red screen is showing, the portal screen, then it is seeing the hotwire unit. If it did not see the hotwire it would say "No Hotwire Detected" and close.
When it sees the speedo it changes to the interface with sliders for that speedo. Check the plug to the speedo. '
Sometimes it thinks it is a speedo ready to drive and flashes all the lights showing no radio signal. If it knows it is plugged to the hotwire just the middle light flickers.
Any leds lit on the speedo when plugged into the hotwire? No lights says no connection.
Tekin Prez is offline
Old 04-16-2009, 09:12 PM
  #3321
Pit-racer's Avatar
It's probably been posted already, but reading over 3000 post is hard. Just installing my new tekin rs pro/ 17.5 motor, do I need to change anything on the motor timing wise? The notch is on the line just to the left of the 12 if your looking at it from the sensor wire side. Also ordered the hotwire do I need any upgrades? Thanks
Pit-racer is offline
Old 04-16-2009, 09:18 PM
  #3322
Team Tekin
Tekin Prez's Avatar
You need new software so you have the timing boost feature. Randy can send you the newest version which installs easy and quick.
Most are running the 17.5 with the motor timing and 0deg to 10 deg in sensored only mode with enough boost timing to equal 30 total for the motor setting and boost added together. Gearing depends on car and track. Always start low and work up watching motor temps.
Tekin Prez
Old 04-16-2009, 09:24 PM
  #3323
Pit-racer's Avatar
So I need to move the endbell counter-clockwise to get to the desired mark. In what increments are the lines? And yes it will be sensored. I will be using an m8 controller.
Old 04-16-2009, 10:56 PM
  #3324
Team Tekin
Randy_Pike's Avatar
Yes I will be at Speedworld working tomorrow! LOL
It's been quite some time since I raced TC on asphalt. I did a quick one hour paint job and tossed it on the car.
Most of the guys running Tc 17.5 are running the setup that the Prez mentioned.
Anyone looking to get the latest software need only email me here with the request:
[email protected]
Randy_Pike is offline
Old 04-16-2009, 11:18 PM
  #3325
witz_dan's Avatar
Trader Rating: 25 (100%+)
Default boost timing confusion
Ok first off sorry if this is a dumb question. But i have been reading through this thread (great stuff in here by the way) and im a little confused i think. A lot of people are refering to the boost on the esc. which with my hot wire i am assuming is the one marked timing advance?
so if that is correct what im a little fuzzy on is people are referring to numbers between 0 - 30 but mine goes up to 100?
I know i read a post on here the other day that touch on this but i can't seem to find it again. Sorry if this has been asked alot
Thanks for your time
Dan
oh running sensored only 189
witz_dan is offline
Old 04-16-2009, 11:33 PM
  #3326
witz_dan's Avatar
ok found that post I was talking about. And after rereading it. it has cleared up a little. but im not running in dual mode. I have a timing advance slider not a boost slider. Im thinking this is only something I can do with 1.94? cuz i dont have the option for a dual mode check box like I have seen on some of the screen shots guys have posted. but just to be sure am i on the right track here?
Originally Posted by miller tyme View Post
There is no boost 11-100, that would be timing when running in Dual mode. I have found dual mode to have less top end in any wind 10.5 and slower. If you have one of the more current versions software 189 or 194, check the box marked Sensored, the timing slider will change to Boost (0-30), if the motor is at 0, set boost to max, you should be a rocket then. Only run for a minute or so to start so to check motor temp.
witz_dan is offline
  #3327
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
In order to see the "Boost" icon, you need to run in sensored only mode.
IIGQ4U is offline
Old 04-16-2009, 11:34 PM
  #3328
303slowdown's Avatar
Trader Rating: 24 (100%+)
The new software changes it from timing to boost
303slowdown is offline
Old 04-17-2009, 12:26 AM
  #3329
witz_dan's Avatar
ok thank you that clears up a lot. So when it goes from timing to boost with the new software the range then changes from 0-100 to 0-30. Correct?
witz_dan is offline
Old 04-17-2009, 02:27 AM
  #3330
pakk's Avatar
Trader Rating: 80 (100%+)
let me give this one a shot.
You can have your esc in two different modes. They are dual mode and sensored mode. In dual mode, you can adjust the timing of your motor. This is not boost. This adjust your timing the same way you would adjust mechanical timing. This slider moves from 0-100. In sensored mode, your timing slider changes to boost. This slider will change your timing from 0(or what ever you are set to mechanically) to what ever you set it to when you reach a pre-determined rpm at full throttle. Thus giving you the boost affect. This slider goes from 0-30.
--pakk
pakk is offline
