Old 04-14-2009, 07:51 AM   #3286
myan_gsr's Avatar
Got t-boned by another racer recently and its done a number on the case of my RS pro (cracked a corner completely of the upper case). Are there replacement covers available for these?
Steve
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 04-14-2009, 08:15 AM   #3287
Krio's Avatar
Trader Rating: 150 (99%+)
Steve
Someone had a similar incident near the beginning of this thread and I think you can get them direct from tekin for like $3 plus shipping. Give tekin a call and they should be able to sort it out.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 04-14-2009, 10:26 AM   #3288
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes you can get a replacement case. Either contact [email protected] or myself [email protected]
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-14-2009, 10:27 AM   #3289
C van der Hagen's Avatar
Originally Posted by mikky32 View Post
Top speed yesterday an spx speedo en Tekin 10,5T motor was 77.1 KmH.
Same speed as a 9,5T Speedpassion motor with a GM Genius 120 speedo.
The LRP 10.5 with a GM Genius 120 was yesterday 75.6 km/h.
The highest top speed of a Tekin RS was 67.8 km/h
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 04-14-2009, 11:31 AM   #3290
Fastforward's Avatar
Default need starting set up
Can someone point me in the right direction. I need a staring set up for a Tekin RS using hotwire for Vintage Trans Am using a 21.5 (novak) burshless on a small carpet track.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 04-14-2009, 11:33 AM   #3291
Ericjooopuntnl's Avatar
Originally Posted by C van der Hagen View Post
Could you give me the RS setting and the ratio?
Chris,
I did the 77,1 km/h yesterday with an LRP SPX on setting 8 and a 4,57 ratio.
greetz,
Eric
Ericjooopuntnl is offline   Reply With Quote
Old 04-14-2009, 11:42 AM   #3292
JCarr's Avatar
What version software do you have? If you have 194 you want to turn the boost to max and 0 motor timing sensored only.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 04-14-2009, 12:06 PM   #3293
Originally Posted by Ericjooopuntnl View Post
Chris,
greetz,
Eric
Thanks, when do you going to try to reach the same topspeed with the RS?
What settings should be used?
Old 04-14-2009, 12:58 PM   #3294
Tomorrow (wednesday) i'm having an afternoon at the flowing AMCA-track, hope we can sort the RS out....i'll keep you posted
greetz,
Eric
Old 04-14-2009, 01:01 PM   #3295
bkspeedo's Avatar
ESC - 194
Sensored mode
Throttle - 3 or 4
Boost - 20 to 25
Motor Timing - min to 1/4 turn of timing ring movement.
Gear the car around 4.5 - 4.6 FDR.
ESC - 189
Sensored mode
Throttle - 3 or 4
Boost - 20 to 25
Motor Timing - 1/4 to 1/2 turn of timing ring movement.
Gear the car around 4.4 - 4.5 FDR.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-14-2009, 01:02 PM   #3296
Same gear ratio or gear it down a few teeth from the GTB setup?
Bob DeGood
AKA Big Bad Bob
AKA BBB
Old 04-14-2009, 01:11 PM   #3297
JCarr's Avatar
OOOPS I meant version 189, but I think it will work the same with 194. I would drop back a few teeth from your GTB setup and check temps and go from there.
Gorilla Size Racing
Old 04-14-2009, 07:21 PM   #3298
Team Tekin
Randy_Pike's Avatar
For the tracks that you guys are getting these "top speed" runs in on you're going to run quite a bit of boost AND some motor timing. Don't forget that getting out of the hole getting ON that long straight is often a huge factor to top end.
Try running 25 on boost and 10 on motor and go up slowly from there.
Old 04-14-2009, 11:36 PM   #3299
myan_gsr's Avatar
Thanks Randy, will get in touch soon.
www.brccc.org
Old 04-15-2009, 06:07 AM   #3300
Default Thanks
Thanks guys for the set up suggestions. I ended up taking all of the timing out of the motor and ran 20 on timing boost on version 194. WOW, this is the break-through I have been looking for. My buddy ran his RS on a 17.5 at 15 on timing boost and loved it.
I will continue to tune the RS but at the moment I am working on a new chassis set up and until that is sorted out "real data" will be hard to get.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
