Old 06-06-2008, 03:17 PM   #316
syndr0me's Avatar
Trader Rating: 32 (100%+)
/joins club
syndr0me is offline   Reply With Quote
Old 06-06-2008, 07:31 PM   #317
Trader Rating: 38 (100%+)
Originally Posted by syndr0me View Post
/joins club
welcome!
or8ital is offline   Reply With Quote
Old 06-06-2008, 08:36 PM   #318
ottoman's Avatar
R/C Tech Charter Subscriber
Originally Posted by PitNamedGordie View Post
Got mine from Nexus Racing...they're in stock.
http://www.nexusracing.com/product_i...oducts_id=1906
must have just got them back in stock as I was checking Stormer and Nexus daily last week.
Just my luck I back ordered one from Stormer... I figured because they had my RS Pro before anyone else they would get the Hotwire back in stock first
ottoman is offline   Reply With Quote
Old 06-07-2008, 06:09 AM   #319
hobbipro's Avatar
Trader Rating: 21 (100%+)
I just picked up a RS and hotwire off ebay. Axiomracing is the seller, they did have another few of the hotwires, and the pro RS in stock as well. I decided to go with just the RS since a 8.5 is probably the hottest motor my TC will ever see.
hobbipro is offline   Reply With Quote
Old 06-07-2008, 05:53 PM   #320
Yay!! I just got my RS Pro from Axiom, thanks Dave, and installed it. Sweet, set it up in no time unlike a certain orange item. Can't wait to try it with a 4.5 LRP tomorrow but it seems smooooth.
Question, how much drag brake do you use (Brian Mc)?
AreCee is offline   Reply With Quote
Old 06-07-2008, 07:16 PM   #321
I got to practice with the RS today in my sedan. Ran great all day and never got hot even when it was a few teeth overgeared. Being able to adjust the timing was a plus because you can gear down to get the car to launch off the corners and then turn up the timing so that is just winds out on the straight. I ended up gearing down 3 teeth compared to the Novak that I was running.
I really only noticed the dual mode on start up and it launched best with the motor timing at zero. Once the car was rolling i couldn't notice any switch between sensored and sensorless.
The throttle felt great but I did have to turn the deadband down some. Can't wait to go back indoors and run some 12th with it.
Fred_B is offline   Reply With Quote
Old 06-07-2008, 08:56 PM   #322
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Today was my 3rd weekend with the RS but was the first time I really played with the timing/gearing. I must say I really like being able to electronically adjust the timing. It's a much finer adjustment than gearing or motor timing, and doesn't result in as much heat. I tried Dave Arnold's theory on timing today (posted above). What I ended up doing was going down about 3 teeth (from the high 3.7's to 3.95) and have my timing at 80%. If you haven't guessed I run a 17.5 (Hacker for now). My motor temps were in the mid to high 160's after 6.5 minute runs and ESC temps barely hit 100. [I run a fan and heatsink on my motor] I felt my car was quick in the infield and had nice top end. I will play with this again next weekend.
I expect to have an Orion 17.5 to test soon if Stormer Hobbies ever decides to ship it
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 06-07-2008, 10:50 PM   #323
trailranger's Avatar
Just a few qustions...cause I really want a RS
Does the RSpro ship with the Hotwire package?
Will the firmware be upgradeable in the future with more user options to play with?
trailranger is offline   Reply With Quote
Old 06-07-2008, 11:06 PM   #324
No, the Hotwire has to be purchased seperately. But it would be a good idea to sell it as a set :-)
Yes, the firmware is upgradeable.
omoser is offline   Reply With Quote
Old 06-09-2008, 07:13 PM   #325
Im having an issue with my RS. My local team driver requested an RMA and never got it and I have as well. Is the tech support dept at Tekin staffed?
...the problem Im having is that the ESC is getting extremely hot. I had one motor where the ESC would shut down after 30 seconds. So I tried another motor and ran it around a bit and the motor was at 135 and the ESC was at 160. Im afraid if I got my motor up to 160 then the ESC would meltdown.
Old 06-09-2008, 10:21 PM   #326
Any chance of having User Supported Open-Source programming?
Old 06-10-2008, 01:53 AM   #327
well what i can say is that i'm using a high rpm 30x30mm fan that blows directly at the soldering posts, and running my 3.0T the ESC thermals after 4.20-4.30 at 230F. I was impressed that the case did not melt...
Old 06-10-2008, 01:54 AM   #328
well not being connected to team tekin other than having their RS speedo, i cannot tell you that, but i would love the idea to write a linux client for the RS. Would save me from running vmware everytime i want to change a setting :-)
Old 06-10-2008, 02:57 AM   #329
oliv996's Avatar
Hi,
I've just ordered from Axiom a RS pro ESC and I would like base settings for 4WD offroad use with 5cells and Velociti 4.5R. Thanks for your help
Olivier
www.mid44.com
oliv996 is offline   Reply With Quote
Old 06-10-2008, 05:44 AM   #330
Shoot an email to support @ teamtekin.com and to Sherri @ Teamtekin.com explaining the problem. Like most of the speedo companies out there it's a relatively small operation and if the support guy's at a race it can be a couple days before he gets back with you. Sherri may be able to help you out if the service guy's out.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
