Tekin RS ESC sensored >
Old 04-13-2009, 08:27 AM
  #3256
pakk's Avatar
Trader Rating: 80 (100%+)
Originally Posted by DaSloth
I'd done that quite a few times, but obviously didnt fully register it till i took Kenny's advise and changed the neutral width.
ok, do the lights light up till they all light up and blink now when you brake?
--pakk
pakk is offline
Old 04-13-2009, 08:30 AM
  #3257
--pakk
Yep
DaSloth is offline
Old 04-13-2009, 08:38 AM
  #3258
pakk's Avatar
sweet! Now be careful not to spin out.
--pakk
pakk is offline
Old 04-13-2009, 09:09 AM
  #3259
Kenny L's Avatar
Trader Rating: 16 (100%+)
Yep
Cool glad to help. If you got anymore questions or issues feel free to pm me anytime. I pop in and out of here a few times everyday.
Kenny L is offline
Old 04-13-2009, 09:26 AM
  #3260
C van der Hagen's Avatar
Today I used the Tekin RS for the first time in my touring car.
It was terrible!!
My topspeed was on the straight topspeed was about 14 km/h less then the fastest guys.
I used 1.94 and the timing boost from min. till max.
The track length is 0.278 km, 10.5T, 5 cell
Mainly used A- finalist equipment: LRP 10.5, SPX stock spec with 4.2 ratio
Is the GM and the LRP ESC the faster ESC on large tracks?
C van der Hagen is offline
Old 04-13-2009, 09:28 AM
  #3261
Kenny L's Avatar
With tc the 189 makes more rpm to start. What motor are you running?
Kenny L is offline
Old 04-13-2009, 09:40 AM
  #3262
I used the LRP 10.5 and the Corally 10.5 (used different gear ratio's)
Old 04-13-2009, 09:45 AM
  #3263
Kenny L's Avatar
Are you running can timing? what were temps? what fdr for each motor? My guess is that you should be about 3 to 4 teeth higher than spx gearing set on 8
Kenny L is offline
Old 04-13-2009, 10:02 AM
  #3264
I did not changed the motor timing. Should I?
So 1.89 is better for higher rpm? How much boost should I use?
I used 4.2 ratio with the LRP 10.5, same as the guys using a SPX with setting 8.
3 or 4 teeth higher (64 0r 48 dp)? (64 dp will result in a ratio of 3.9)
Old 04-13-2009, 11:05 AM
  #3265
Kenny L's Avatar
64p what were temps and timing should be around 0
Kenny L is offline
Old 04-13-2009, 11:31 AM
  #3266
Team Tekin
Randy_Pike's Avatar
Everyone really needs to not compare gearing between different motors and speedos.
EVERY application is different! If you're not comparing apples and apples take it with a grain of salt.
Motor temps and speed are what everyone should be using for gearing input.
Don't overlook the basics.
Randy_Pike is offline
Old 04-13-2009, 11:38 AM
  #3267
tekin 10,5T motor has the highest top speed on MACH.
77+ km/h against 72 and lower of the rest.
Tekin motors rule
mikky32 is offline
Old 04-13-2009, 12:24 PM
  #3268
Clear, but i tried every combination of ratio and timing boost. What temp is acceptable?
Old 04-13-2009, 12:27 PM
  #3269
Tekin motors rule
Could you give me the RS setting and the ratio?
Old 04-13-2009, 12:32 PM
  #3270
I generally aim for 65 degrees celcius and if it comes off at anything over 70 i'd be looking at changing it to slightly lower gearing.
DaSloth is offline
