Old 04-06-2009, 03:32 AM   #3166
Unspoiled's Avatar
Hi!
I am waiting for my RS-Pro/10.5 setup to show up on my door step. I am going to be running it in a XXX buggy.
Anyone have an set up tips or gearing recommendations?
Thanks!
Edit: Sorry...I didn't realize this was in the on-road thread
Unspoiled is offline   Reply With Quote
Old 04-06-2009, 12:33 PM   #3167
I have my setup for a speedpassion 10,5T
I raced yesterday. By some bad luck by the kwalification i ended up as 11th so first in the B.
Speed was super. By far the fasted in the B
i was half a lap down and last by my own mistake and i drove all the way back to the frond.
4th fastest in lap times.
incredible. never was i faster than some drivers and now i was.
Setup was
Boost 28
nutral 10
bracke 100%
drag brake 0
acceleration 5
motor temp was 160 to 165
so was good.
Power till the last lap.
now i can test further with the right settings for the tekin motor.
Coudn't test it wel so i chose to g on save and choose for the settings with the motor that i now that was good.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 04-06-2009, 01:45 PM   #3168
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by 2056dennis View Post
now correct me if im wrong but is the timeing on the duo in order to get the least amount on motor you half to turn the motor to where the screws are in the first hole to the left of them when looking at them thanks
Originally Posted by Fred_B View Post
Full clockwise when looking at the endbell is minimum timing.
I've actually run full boost and added timing on the motor but it's not recommended. I think the sensors are reading a little differently on 1 cell.
In any case you'll never get that pop that you had on 4 cell even in mod. The trick to single cell is keeping the corner speed up so you don't need all that punch.
so timing does not go 0,10,20 in that order when looking at the endbell so what you are saying the it should be the other way 20,10,0 so all the way to the right is the least amount and all the way to the left is full timeing
Originally Posted by STLNLST View Post
It goes 0, 10, 20 and if you're looking at the endbell look at the middle hole.....the 0 timing mark is the hole to the left of the middle hole and the 20 timing mark is the hole to the right of the middle hole. Take note of the direction you turn it to get to the desired set of holes and that will help you relate to others when they say clockwise or counter clockwise. I hope I explained this well enough to be of some help to you.
Good luck.
A picture is worth a thousand words (or 253, in this case. yes, I counted... no I had nothing better to do...)
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-06-2009, 01:58 PM   #3169
STLNLST's Avatar
Trader Rating: 21 (100%+)
Thanks for the pic. You're count is off though. I went and added a word to my original comment You really need a hobby
STLNLST is offline   Reply With Quote
Old 04-06-2009, 02:18 PM   #3170
TheCoolCanFanMan's Avatar
unlike rc racing i guess lol
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-06-2009, 03:00 PM   #3171
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default yes
thanks for the pic and after talking with a few people i found out i was right but that pic im sure will clear things up for others that may have that same ? thanks Trips and to all that took part
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 04-06-2009, 03:50 PM   #3172
Trips's Avatar
I do seem to have some extra time on my hands now that 360 Speedway has closed its doors. A new carpet track "Speedzone Raceway and Hobbies" is moving into the area and opening sometime in the next month from what I'm told, so I'll likely have less time for taking photos and adding arrows and counting words...
MARSHAL!!
Old 04-06-2009, 04:08 PM   #3173
2wdrive's Avatar
Setup was
Boost 28
nutral 10
bracke 100%
drag brake 0
acceleration 5
so was good.
Why didn't you use the tekin 10.5t mikkey?
I used the gm 10.5t last saterday evening. After a little playing around i had boost on 30 and motor tempature were ok. i changed to one size bigger pinion so changed my rollout to 56.5mm or something. Speed was good faster then some other 10.5t on the straight but i wasn't the fastest. Temperatures were after a 7 minute race fairly warm. i could hold my finger on it for more then 5 seconds but i could feel the motor was getting hot. i didn't change it during the second kwalification. Maybe a little less boost with a little higher rollout? I still feel a little that the motor has a good start but then after a while the acceleration is gone. I had the same with my 4.5t. Maybe my boost is to high and it needs to work harder to get that car accelarating with that high rollout ? What do you think mikkey?
2wdrive is offline   Reply With Quote
Old 04-06-2009, 08:57 PM   #3174
hey Randy,
Thanks for sendin the 194 software to me last week, It performed awesome. Wondering if you have a good baseline setup for 13.5 truck as this is the class we run during the summer and i'm preparing to switch my gear over to the truck(xxxt-cr with 13.5 duo). Thanks again, Tim Larson
shaggy1 is offline   Reply With Quote
Old 04-06-2009, 11:06 PM   #3175
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default speedo cycle
Got a quick question.
Used my RS pro for the first time this past weekend. Not sure if this is normal but when I turn on the speedo it takes about 1 minute to 1 1/2 minutes to cycle (or at least that what seems to be doing) before it sends any power to the wheels.
After that it works fine. still using the original software.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-07-2009, 04:11 AM   #3176
I will test this weekend the motor again. didn't test with good tires. I tested with old sweeps and they have no traction and grip.
I new that the settings from the speedpassion motor were good because an other Tekin driver tested it.
i gave him some setups and watched his lap times.
And to go on save, i choose for the speedpassion motor.
Now i have better tires with lap times. so next time when i go to the club, i'm going to test it.
Motor stayed cool by me.
only notist that when i go back 1 pinion and ad 5 boost that the motor stays cooler.
The Tekin must be geard very light.
I'm going to test with motor on 12 and boost on 23 and the same gear i drove with the race.
Than i'm adding some boost if the temp stays low.
if the temp is the same or higher than the speedpassion. than i go 1 pinion smaller. and test it again. and if the temp is than good, than i will ad some boost.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 04-07-2009, 04:25 AM   #3177
miller tyme's Avatar
A small hesitation (about 1-3 seconds) is normal. The RS needs to 'bind' to the receiver , add to that the time for some radio's to bind to the receiver (regardless of the ESC being used) and it can seem like a wait at times.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 04-07-2009, 04:42 AM   #3178
2wdrive's Avatar
alright, i will decreas the rollout and will put boost on 23 next time. Could indeed be that the motor just has to work too hard with that rollout and boost 30.
Old 04-07-2009, 08:05 AM   #3179
mo
mo's Avatar
What is your neutral width setting and have you adjusted your throttle trim since you set up the radio to the speedo? If your neutral width is too low or if you move your throttle trim, it can have a hard time finding neutral when you turn the speedo on. I suggest starting with a NW of 8-10 and reset the speedo to the radio and see if that helps.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-07-2009, 12:08 PM   #3180
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Randy_Pike View Post
Ok guys,
I've going to release 194 software on the public.
Anyone looking to get 194 can email me for it. I do request again that you tell me where you live and race so I can point out any team drivers. Not giving me that info will only delay you getting the software.
Please be patient as I know this is giong to be a lot of emailing.
email sent. thanks
over gear is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
