Old 04-05-2009, 06:42 AM   #3151
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by Krio View Post
I don't think using a y adapter will work for anyone as power will be fed to the receiver as well. I made a short extension so at least I'm not plugging it in and out of the receiver itself.
This is the one I want to use
http://www.amainhobbies.com/product_...ducts_id/14576
So it wont work if its still plugged into receiver?
Maybe I can use the above, but with a switch that will disable the tekin rs harness when I need to use the hotwire with the adapter. Its such a pita as the tekin receiver plug is in the middle of channel 1(servo) and channel 3(transponder)
hacker is offline   Reply With Quote
Old 04-05-2009, 08:30 AM   #3152
Krio's Avatar
Trader Rating: 150 (99%+)
No, but you could do what I did. I cut down a single extension:
www.kriostasis.com
Krio is online now   Reply With Quote
Old 04-05-2009, 08:38 AM   #3153
Just tried a y-harness with my KO 2.4 receiver and it doesn't work. The USB port will power up the receiver and the RS won't link up. Might work if you wire in a switch that disconnects the y-harness from the receiver.
It's easier to pull the plugs out if you put a pull tab on (just a piece of strapping tape).
Fred_B is offline   Reply With Quote
Old 04-05-2009, 09:28 AM   #3154
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-05-2009, 05:35 PM   #3155
Canuck's Avatar
Trader Rating: 25 (100%+)
Default 1/12 pan car 1S lipo Tekin RS settings
Wondering about the best setup for my Tekin RS for the following parameters:
1/12 scale 12R5
1S lipo
13.5 Trinity DUO motor
TQ Booster
Tekin RS
Hotwire with 1.94 firmware
Track is 60x28
Pinion 42
Spur 72
Rollout 3.4271
I tried this:
Timing on motor at 15 degrees (middle)
Drag brake 0
Brake strength 100%
Limiter OFF
Neutral width 10
Voltage cutoff OFF (and switch is off)
Motor type BL-FW
Throttle profile 3
Timing advance 100 (deactivated - sensor mode)
sensored X
push control off
reverse strenght off
Timing boost 15
Would it be beneficial to use the DUAL mode setting ? What about timing advance.
OK I can use a bit more power. Should I gear up the pinion of try some changes on the speed control ?
Canuck is offline   Reply With Quote
Old 04-05-2009, 05:49 PM   #3156
Trips's Avatar
Trader Rating: 16 (100%+)
Canuck,
I'd run the endbell in the least advanced position on the Duo 13.5, and run the boost at maximum. Try gearing for 3.2 or 3.25 rollout. I was running an 80*36 or so track, geared for 3.3 rollout with the endbell backed off and max boost in my 3.7 1/12 car.
I haven't run dual mode in a long time... I think I had firmware 1.80 in the RS the last time I ran dual. If you do try it, I'd be interested to hear the results...
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-05-2009, 06:11 PM   #3157
Canuck's Avatar
Originally Posted by Trips View Post
Canuck,
So you are saying to let the ESC do the max for timing and the DUO full clockwise or least amount of timing ?
What about throttle profile. Should I bring that up to 4 ?
Old 04-05-2009, 06:28 PM   #3158
Trips's Avatar
Yes. Seems to be what all the fast guys are doing around here.
Throttle profile affects the trottle response feel, it doesn't alter the power. I like the feel oif profile 3, you may like 4 better. Both will produce the same power, but 4 has a more aggressive feel... more power comes in earlier in the trigger stroke, but at full trigger, there's no difference.
MARSHAL!!
Old 04-05-2009, 06:37 PM   #3159
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default timeing
now correct me if im wrong but is the timeing on the duo in order to get the least amount on motor you half to turn the motor to where the screws are in the first hole to the left of them when looking at them thanks
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 04-05-2009, 06:40 PM   #3160
Canuck's Avatar
Ok sounds like a plan. I will try it out and let you know.
Also need to find the perfect rollout for the track. I was at 46T pinion and the car was way too fast for the track so I backed down to 42T and did a qualifier with ggod time. Then went up to 43T and my time was a bit less on the final. Could be me the driver !!! I will try 40T for that 3.25 rollout and ajust the rest of the settings.
I am amazed though on the speed we can produce out of 1 1 cell lipo !
Old 04-05-2009, 06:43 PM   #3161
Canuck's Avatar
Originally Posted by 2056dennis View Post
now correct me if im wrong but is the timeing on the duo in order to get the least amount on motor you half to turn the motor to wherethe screws on in the first hole to the left of them when looking at them thanks
You are right on that !
Old 04-05-2009, 06:59 PM   #3162
Full clockwise when looking at the endbell is minimum timing.
I've actually run full boost and added timing on the motor but it's not recommended. I think the sensors are reading a little differently on 1 cell.
In any case you'll never get that pop that you had on 4 cell even in mod. The trick to single cell is keeping the corner speed up so you don't need all that punch.
Old 04-05-2009, 07:13 PM   #3163
2056dennis's Avatar
Default timing
so timing does not go 0,10,20 in that order when looking at the endbell so what you are saying the it should be the other way 20,10,0 so all the way to the right is the least amount and all the way to the left is full timeing
Old 04-05-2009, 11:04 PM   #3164
STLNLST's Avatar
Trader Rating: 21 (100%+)
It goes 0, 10, 20 and if you're looking at the endbell look at the middle hole.....the 0 timing mark is the hole to the left of the middle hole and the 20 timing mark is the hole to the right of the middle hole. Take note of the direction you turn it to get to the desired set of holes and that will help you relate to others when they say clockwise or counter clockwise. TRIPS I hope I explained this well enough to be of some help to you .
Good luck.
STLNLST is offline   Reply With Quote
Old 04-06-2009, 03:22 AM   #3165
hacker's Avatar
as you said, I reckon just a micro switch on the ground wire will do the job.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
