Old 03-27-2009, 01:54 PM   #3031
Suspended
Originally Posted by PitNamedGordie View Post
Randy,
You mentioned that the 194 software is supposed to be more efficient, correct? I assume efficiency can be measured in what temps I see when I come off the track. I was at my track yesterday and with the same gearing and timing that I had with the 189 software I noticed much lower temps when running 194. In the past with the 189 I would reach 170 degrees after a 6 - 7 minute practice run. With the 194 I ran for 10 minutes plus and came off the track at 170-175. With that said the track layout changed since last week so I'm not sure how much that factors in. I guess a good test would be to run 189 for 6 minutes and then 194 for 6 minutes and check the temps. I was just curious if my temp change was due to the software change?
I am running an Xray 008/009 with a Speed Passion 17.5 in sensored mode and 18 boost.
What difference was there in terms of performance?
thank you
kyosho player is offline   Reply With Quote
Old 03-27-2009, 02:04 PM   #3032
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
thank you
The biggest difference I saw was the temperature differences...which makes me wonder does the ESC add less timing in sensored mode with 194?? We had a radically new track layout this week so I couldn't really get a good feel for anything else. I will do more testing this weekend and I will run a pack or two with 189 and then go back to 194 to see if I feel a difference.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 03-27-2009, 02:19 PM   #3033
thats what i'm going to do also.
as it gives less motor temp than you can gear it heavier a bit.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-27-2009, 07:12 PM   #3034
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Originally Posted by tomdav View Post
Thanks Randy...my stuff was updated by Dave Gullickson.
Your welcome, now you need to get the 1/8th ESC
dgullickson is offline   Reply With Quote
Old 03-28-2009, 01:33 AM   #3035
Hi all,
I've run 194 yesterday on a big track (Mach Heemstede with a back straight around 250ft) with 13.5 (Orion Race spec). Timing on the motor was 0, max on ESC with 5300 LiPo.
After a run of 14 minutes my motor was 47 deg celsius (116F) and my lipo was 24 (75F). Speed was not good (63-67 km/h), guys with LRP ESC (same FDR of 3.8) were 4-6 km/h faster.
I've tested FDR's of 3.6, 3.7, 3.8, 4.3.
Speed was best with 3.8 but still too slow.
Any suggestions?
Z
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Old 03-28-2009, 02:53 AM   #3036
tc3team's Avatar
rcpoint- with a back straight of 250ft, if you are looking for speed, I would be thinking of using some motor timing instead of boost on that track, or a combination of the two, maybe.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-28-2009, 03:19 AM   #3037
In 13.5 stock class here we are not allowed to use motor timing (it sucks but rules are rules).
Old 03-28-2009, 08:56 AM   #3038
Trips's Avatar
Trader Rating: 16 (100%+)
Just curious how that can be enforced. Does everyone have to use a specified motor?
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-28-2009, 09:21 AM   #3039
witch motor are you using?
put it on the standart timing.
all other motors are at least 12 degrees timed
put 23 on the boost and try again.
when it's to slow ad 5 timing.
watch the temp.
If this not works. put back the 189
it feels like it gives more rpm
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-28-2009, 10:16 AM   #3040
They mark (race director) the motor at 0 timing before a race, if mark is broken you are disqualified.
Old 03-28-2009, 10:18 AM   #3041
to all motors?
wich motor do you drive?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-28-2009, 11:44 AM   #3042
Trips's Avatar
How are they finding 0 timing? I have motors here from Trinity, LRP, Orion, and Hacker, if there is a way to find 0 timing on a motor can you explain? It would be very helpful to know... I'm not sure where 0 is on any of these motors.
MARSHAL!!
Old 03-28-2009, 11:56 AM   #3043
LRP, Speedpassion, Gm and SP have no 0 timing on the motor.
they are all 12 and not 0.
So as you have a Tekin and you put it on 0 you are always slower.
MACH does always crazy rules. just like the same end gear ratio.
Just let them follow the EFRA rules and don't make up those crazy rules.
But why do you want o drive a 13,5 on that track. I drove there last year one time with a element on 5 cell.
I will never do that again. the straight took ages. I eat, drink go to the toilet and still my car is on the straight.
I love that you can see your speed on the straight.
Buy a motor that you can't time. than you have always 12 timing at least on the motor.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-28-2009, 12:37 PM   #3044
Trips's Avatar
I don't want to drive a 13.5 on that track, I'm on the other side of the planet and I will probably never see that track. I juist wanted to know if they had a way to find 0 timing on a motor.
MARSHAL!!
Old 03-28-2009, 12:47 PM   #3045
sorry Trips i mean RC POINT.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
