Old 03-24-2009, 05:37 PM   #2971
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by over gear View Post
yes. they have been trying to order for 2 months. the distributor is not responding.
The internet is a gateway to finding virtually anything you want. If they aren't serious about getting you one, someone else is.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 03-24-2009, 07:00 PM   #2972
Originally Posted by stocker View Post
There seem to be many figures for the min timing on a DUO, 0, 8, 9 and 12 on this thread alone. Do we have something official on this?
Would like to know for sure myself. going to the track tomorrow, hopefully I can get hold of the 1.94 software to try by then. I'm wondering if It will do the same thing. Just for the record the car seemed to run fine, just made funny noises.
spruce is offline   Reply With Quote
Old 03-24-2009, 08:42 PM   #2973
Originally Posted by sg1 View Post
In 17.5 and 13.5 1/12 we ran 40 drag break, 40 break strength, profile 3, 0 neutral width, max boost.
0 motor timing on each motor
42-88 with 1.68 tires in 13.5
46-88 with 1.72 tires in 17.5
So you're rollout was like 2.8 ish in stock??
Old 03-24-2009, 08:47 PM   #2974
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I thought the same thing. I would have expected a roll out nearer 80 -88 mm.
Old 03-25-2009, 05:08 AM   #2975
With the Tekin RS or Pro and those settings you will be rolling out in the 70's. I put the RS in my 1/12th scale 2 weeks ago and WOW. I ran the 194 software at the Nat's and it was Awesome. The rip was amazing.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 03-25-2009, 05:30 AM   #2976
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Correct, at that track. With that rollout motor temp was 140, lap times started at 10.5 and finished 10.8. I run on smaller tracks at a 2.6 rollout and larger tracks at 3.0 rollout. The amount of traction and corner speed your car will carry makes a big difference.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 03-25-2009, 07:16 AM   #2977
Trader Rating: 20 (100%+)
Hey Guys,
Any feedback on the 194 update yet? Is it a big difference from the 189?
Cheers
bee200sx is offline   Reply With Quote
Old 03-25-2009, 07:22 AM   #2978
sg1
sg1's Avatar
Originally Posted by bee200sx View Post
Hey Guys,
Cheers
It's more efficient and has better bottom end and take off.
Old 03-25-2009, 08:03 AM   #2979
Hi guys..
Just reading the last few pages of posts.... Got my first outdoor race of the year and looking for a ball park settings for 6 Cell (Lipo) for 10.5 running 189 software/
Ive got a LRP 10.5 x11, does that mean im looking at running around 20-25 of boost do you think geared at around 5.1 ish/
Picture of the track!
http://www.eecc.co.uk/gallery/eecc_2.../IMG_3816.html
What do you think guys?
Cheers!
CouldbeFaster is offline   Reply With Quote
Old 03-25-2009, 08:08 AM   #2980
Suspended
What benefits do the 194 software have for 17.5 touring car?
thank you
kyosho player is offline   Reply With Quote
Old 03-25-2009, 08:15 AM   #2981
mazmo's Avatar
Default v 194
Hey guys,
Received v194 (thanks Randy) and installed it, however software still shows
v189.
Have tried to uninstall / reinstall with same result. What can I try next? Would really like to v194 going for the weekend
Thanks in advance.
Cheers
Alan
mazmo is offline   Reply With Quote
Old 03-25-2009, 08:23 AM   #2982
Originally Posted by mazmo View Post
Hey guys,
v189.
Thanks in advance.
Cheers
Alan
i use a litle trick to get it installed. there are some hidden files that he uses again so you don't see the new update.
When you install the new software on your pc remove the old one and run then the new one.
when he asks for the location to install, i name the location after the update so in this case i put 194 behind.
after installing you must go to your shortcut on your desktop and go to the propperties bij klikking with the right mouse button on it.
Than change the location by adding 194 to both links.
Than you are ready and it works.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-25-2009, 08:39 AM   #2983
Trips's Avatar
Trader Rating: 16 (100%+)
Hey guys,
v189.
Thanks in advance.
Cheers
Alan
mazmo,
I take it you're running Vista? IF that's the cxase, follow the instructions in THIS POST and you'll be all set.
Randy... second email sent...
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-25-2009, 08:49 AM   #2984
mazmo's Avatar
mikky, still no luck. could you explain renaming of the links in more detail ... perhaps that is where I am going wrong.
Old 03-25-2009, 08:56 AM   #2985
Trader Rating: 76 (100%+)
Originally Posted by Trips View Post
mazmo,
I haven't had a chance to install mine yet, but will 1.94 install fine with XP?
MUDVAYNE is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
