Old 03-22-2009, 10:30 AM   #2926
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Foxx,
You can slowly go up in boost. Chances are you're going to end up around 25-30 with NO motor timing. You will have to change your gearing if you're running no boost yet.
Motor temps will tell if you're geared right.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-22-2009, 05:24 PM   #2927
anyone experience the motors making like a cogging/grinding noise until they are up to speed?
My setup is.... 4 cell 1/12th scale,Duo 17.5 set at 0degrees (according to the endbell) Tekin RS running 1.89 software with the boost maxed out. the motor sounds fine at slow speeds and at full speed but it makes almost like a "cogging" noise coming out of the corners. Motor temps were 155 F after 8 minutes.
I also had a 10.5 do somewhat the same thing but it only did it from a dead stop/ full throttle punch (had the boost set at 15 with the 10.5)
any ideas? BTW running sensor only with both motors.
spruce is offline   Reply With Quote
Old 03-22-2009, 05:34 PM   #2928
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Foxxrocket View Post
What's a good staring point for boost if there is no motor timing? I run a 17.5 and have it geared as high as it saftly can go.
If you mean that you're already geared to come off the track at roughly 165°F with no motor timing, then there's no room to add boost. When you add boost you must adjust gearing, usually significantly depending on the amount of boost added.
If you mean that the car is geared right for the stock 12-15° motor timing and you just turned that down to zero, you can probably add 12-15° of boost safely. You would still get better performance in most cases by adjusting your gearing such that you can run 25-30° of total timing between motor and boost.
For example, I did a bunch of testing today, and where I previously geared my old 17.5 to 3.5-3.6 FDR, with zero on the can (Tekin Redline) and max boost I ended up at 4.0, and may go a touch further yet.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 03-22-2009, 05:38 PM   #2929
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If I'm not mistaken, the lowest timing setting on the Duo is 9*. I'm amazed you're able to come off at 155* in a 12th scale. Carpet? Ashpalt?
Old 03-22-2009, 05:43 PM   #2930
Originally Posted by or8ital View Post
Sorry this has probably been asked a million times but I cant find it.
What is the approx FDR to run a Tekin 17.5 with v189 (using 0 motor / 30 esc timing)?
Originally Posted by reenmachine View Post
I'm going to work on this this Sunday, same conditions. I will tell you that everyone around here runs an FDR of 3.5-3.6 with a 17.5 with other brands, so no boost. I'm going to start at 3.9 and watch temp carefully. I believe I've heard others say they went above 4.0.
Yeah I was going to start at 4 if I had to find out on my own. But that means I will be buying a bunch of spur gears to be able to test. Last year with the old firmware I had the motor timing all the way up on a DUO and ran a 3.12 FDR. Took a while to wind up but once it did it was fast. There weren't any slow sections of the track b/c it was so big.
I did a bunch of testing today with the Redline 17.5 and RS (189) and ended up at 4.0 FDR. I still have top speed to spare and nearly all the punch I could want, so I may take it a bit further yet. 165°F after 7 mins.
medium-large high-grip outdoor asphalt
sensored only
drag brake 25
brake 100
tp 3
nw 10
boost 30 (max), zero on motor
no current limit
I was very impressed with the performance!
Pete Waydo
Old 03-22-2009, 05:48 PM   #2931
carpet. Not sure on the motor timing, the direction from trinity say that where I have the endbell is 0 degrees.
Old 03-22-2009, 06:14 PM   #2932
Trips's Avatar
Trader Rating: 16 (100%+)
I don't know if your having the same problem I did, but I was getting a LOT of diff slippage after I switched to brushless a few months ago. I'm running the diff tighter than I ever did with brushed motors...
It took me a while to recognize it as diff slip... with brushed motors, the sound of a slipping diff was different, like a high pitched screech, with the brushless, the sound was lower in pitch and nowhere near as loud... more like a grind or buzz kind of sound...
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-22-2009, 06:52 PM   #2933
Its definately not the diff slipping. The motor will make the noise at about 1/4 throttle with the car on the stand free wheeling. I didnt take my laptop to the track with me so i couldnt try less timing boost. I'm wondering if its a timing issue or maybe something in the 1.89 software. I know they said a few other guys cars were doing the same thing last weekend (I wasnt there) and one of the guys is a very fast(well known) stock racer.
Old 03-22-2009, 07:27 PM   #2934
Team Tekin
Randy_Pike's Avatar
Spruce,
What's the motor timing set at? What TP setting?
That sounds is generally a result of too much timing.
Old 03-22-2009, 07:30 PM   #2935
Originally Posted by Randy_Pike View Post
Spruce,
According to the trinity directions that come with the motor the motor is set to 0*. TP is set to 3
Old 03-23-2009, 05:47 AM   #2936
I drove saterday against a 9,5 lipo with my Tekin RS Pro and a 10,5 on 5 cell.
He was impressed about the power my car hath.
He was driving all day with someone els that drives a LRP TC with a 10,5 on 5 cell.
He told me that he was impressed by the acceleration and power my car has.
So iw as happy to hear that.
Also i drove against the other driver with the LRP TC. I drove to him if he was standing still
When i passed him i drove away from him.
even with old tiers.
I use his old tiers. So when he finds them not good any more, than i drive on them till they fall apart.
I have than a lot of under steer but the acceleration is so good that i go faster. On new tiers i go a lot faster, also on the straight.
Now our top speed is quit the same but i now that it will go faster with other tiers.
Now i can't wait till April 5th. Than we have the first race of the year.
Yesterday we hath a rallycup but that is with a 27T motor.
Second place and finaly i closed the gap to the nr 1.
So with the Tekin RS Pro and the Tekin redline motor i beliefe that i make a change to come on the podium one time this year.
and ma by a top 6 on the end of the year.
Thanks Randy for the setup. It works great.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-23-2009, 06:35 AM   #2937
CFR
CFR's Avatar
Originally Posted by acyrier View Post
I think a "save settings" would be an EXCELLENT feature of hotwire.
is it any nearer?
also would we be able to re apply the saved settings @ a single click?
CFR is offline   Reply With Quote
Old 03-23-2009, 07:39 AM   #2938
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default ROAR Nats
Just wanted to take a minute to say congrats to everyone at the ROAR nats! I couldn't believe how many people had the Tekin RS as the speed controller of choice!! The 189 with max boost was the hot ticket again!! I don't know how many speedoes I set up for people there. The Tekin speedo also aided in dynoing NUMEROUS motors!! I went threw a roll of paper checking motors on my CE dyno with Tekin speedcontroller integrated in.
Thanks for the support!
Wayne Gerber
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 03-23-2009, 08:28 AM   #2939
1fastdude's Avatar
Trader Rating: 15 (100%+)
Wayne hit the nail on the head. From what I seen there were about 1/4 of the pits with TEKIN speedos. I too used the 189 software and believe me WOW what power I had. Thanks TEKIN and Randy for terrific products.
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 03-23-2009, 08:30 AM   #2940
John Tag's Avatar
Trader Rating: 42 (100%+)
Congrat's Eli...
Now we can breath in stock for 5 year's..LOL
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
