Old 03-17-2009, 12:05 AM   #2881
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Paul,
What software were you trying to update to?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-17-2009, 06:03 AM   #2882
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can Tekin/Any Brushless Motors get hotter than usual by over reving if your pinion is way too small, like what happens too brushed motors?
Can this happen in Spec class brushless?
LOSI123 is offline   Reply With Quote
Old 03-17-2009, 06:36 AM   #2883
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default well first
they get really hot and ive seen smoke rollout of them and you cook the arm or and the wiresin the can and its history after that , just from what ive seen i personaly have not had it happen yet
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 03-17-2009, 06:22 PM   #2884
Team Tekin
Randy_Pike's Avatar
I'm sure it could happen if you wanted to. I'm not sure why you would do such a thing.
In the past if you had a mod motor and overrevved it you'd burn the brushes. Brushless is more forgiving but certainly not idiot proof.
Old 03-17-2009, 07:37 PM   #2885
JavierSpeed's Avatar
Hi.
Please advice what will be the ideal pinon gear size for a Tekin redline 10.5 running in a 1/12 (4cells) with spur size of 89t. Also what settings shall i be using in the Tekin RS pro with the 189 for the above setup on tarmac.
Cheers!
Jav
Montonica P81 RS2/RS3
Mi5/T4/A700EXL
JavierSpeed is offline   Reply With Quote
Old 03-17-2009, 08:45 PM   #2886
mazmo's Avatar
Default Setup for Trinity 10.5 Duo 1/10 TC
Just bought a Trinity Duo 10.5.
I have an RS Pro with 189 software and race 1/10 TC.
Was going to try max boost (30 deg) in the RS Pro & 0 timing on the motor.
Does that sound about right ?
Would appreciate feedback.
Alan
mazmo is offline   Reply With Quote
Old 03-17-2009, 10:58 PM   #2887
LOSI123's Avatar
Thanks guys.
I was also wanting to know the rear bearing dimensions of the redline S motors.
When i convert the Imperial decimal numbers from the website i get some wierd factions???
.125 x .375 x .15
1/8 x 3/8 x 3/20????
I my self havnt heard of 3/20ths
Old 03-18-2009, 03:34 AM   #2888
Alan
yes, watch temps and gearing though, as been tested by a chap and posted on our forum, you gain about 4-5000rpm
DA_cookie_monst is offline   Reply With Quote
Old 03-18-2009, 08:41 AM   #2889
Default Set up
Just got my RS and going to run 17.5 Foam on small track with TC5. What pinion and spur should I start with? Hot wire did not come in, settings with out that would be helpful also. Thanks
Lugnutz1 is offline   Reply With Quote
Old 03-18-2009, 09:32 AM   #2890
Ok maybe a bit off topic but for those of you out there on the fence about buying this ESC....let me tell you rocks! I normally run the KO BMC but I tried a RS Pro in my WGT car. Combo was RS Pro, Hacker 17.5 and TP 5000 40C. First time on the track with the car at our local big race here and 3 count it 3 people told me I couldn't run a 10.5 in WGT. After coming off the stand from practice I showed them all it was a 17.5 in the car. This ESC is the real deal!!! Had the boost maxed and motor timing at 0 geared 98/30 and it was a rocket. Next I'll try it in my sedans and see how it does with a heavier car.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 03-18-2009, 09:56 AM   #2891
Grenade10's Avatar
Trader Rating: 37 (100%+)
I told you that if it would make that kind of change for me .... Just think what it could do for a "Fast" Driver.
Also, remember the question on my VTA car ...... then he changed his ESC to a Nosram and was no faster! He beat me by better driving and not getting punted into the pits.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-18-2009, 10:12 AM   #2892
Team Tekin
Randy_Pike's Avatar
Guys if you're asking gearing questions it would be really helpful to get some track demensions so we can get you close. Without it we're shooting in the dark so to speak.
General setup for onroad is to run 0 motor timing and full boost with 189 software.
For 10.5 this is a bit off in my opinion and I'd like to see a setup like this one along with 15 degrees of motor timing:
Old 03-18-2009, 10:23 AM   #2893
Trader Rating: 76 (100%+)
Randy, I see that your 189 version is graphicly different from my version. Is that the only difference?
MUDVAYNE is offline   Reply With Quote
Old 03-18-2009, 02:32 PM   #2894
65x35
Old 03-18-2009, 04:29 PM   #2895
recieved today my Tekin RS Pro.
Build it in and tested it with the 189. not on the track jet but compared to a LRP TC this has a lot more power.
motor 0 timing boost 100%
I'm going to test it saterday on the track.
cant wait till than. must wait because my rear arm broke so i must wait till it arrives and that is friday
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
