Old 03-15-2009, 01:43 PM   #2851
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're going to add timing to your setup you will need to drop your gearing accordingly.
In general for 64 pitch gears very 5 degrees you add of timing should be 2-4 teeth dropped on gearing. This is a "general" statement. Motor temps are the indication of your gearing. If your car is fast and motor temps are good, you're there. If you're a bit slow and motor temps are high, you're overgeared.
Anyone looking for 189 software can email me for it: [email protected]
I ask to know where you live/race so I can point out our team members for support.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-15-2009, 02:18 PM   #2852
Originally Posted by reenmachine View Post
Personally, I gear to come off the track at about 165F after a 6-minute race. A motor will pretty much last forever at those temps. I know racers that run to 185, but they also replace motors more often. You could probably add a tooth, but you're certainly safe where you are and can expect great reliability and longevity.
what about a motor cooler?
Can i gear the motor heavier when i use a motor cooler?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-15-2009, 02:45 PM   #2853
Trader Rating: 38 (100%+)
Lots of motor failures at my track from people using motor coolers. All brands. This was an outdoor track. Not sure if it was condensation or what. Best just to gear in a safe range.
or8ital is offline   Reply With Quote
Old 03-15-2009, 02:49 PM   #2854
Ok Thanks
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-15-2009, 03:36 PM   #2855
STLNLST's Avatar
Trader Rating: 21 (100%+)
YGM...............
STLNLST is offline   Reply With Quote
Old 03-15-2009, 04:44 PM   #2856
LOSI123's Avatar
Trader Rating: 63 (100%+)
What rotor sizes are available for the Tekin Redline Sensored motors?
and can some one explain them
i notice there is 2 different 13mm rotors??
Did there used to be a 13.5mm and a 14mm ??
LOSI123 is offline   Reply With Quote
Old 03-15-2009, 04:45 PM   #2857
Tekin vs SPX on dyno.
SPX was fast. Tekin blows up the dyno
Tekin beads the SPX easy!!!
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-15-2009, 07:51 PM   #2858
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default ok guys i need some help gearing a tc5r with 189
yep i have rs pro with 189 and im running rubber tire and need help gearing this here is my esc setup
db 40
rs off
bs 85
nw 10
blfw
tp 5
vc off
pc off
tb 21
cl off
sensored only and no motor timing and im running a 13.5 duo on a track that is 36/80 with 80 foot straight but pretty fast layout first run motor was 166* and i went down 5 teeth and motor was 160* and then in the main i went down 3 more teeth and it was 171 * ,and alot hotter then i like and not to mention esc was 130* in the main really need some help here and i started with 100 spur and 41 pinion then went to a 100/36 and then went to a 110 / 33 still hotter then what i want thanks for help and track was med bite on carpet
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 03-16-2009, 02:18 AM   #2859
RS Pro: I set the lipo cutoff to 6.5V... If this is reached, what happens? Does the ESC stop responding completely to throttle input, or does it limit the current heavily... but allow you to bring the car 'home' ?
thanks.
g
gortan is offline   Reply With Quote
Old 03-16-2009, 02:23 AM   #2860
Hi thanks Randy...
I'm using 48p gearing. So if I was safe using 180 in hybrid mode with everything default... so 12/100 in timing (3.6*).. then would I be safe if switch to 189 software and change to sensored only with 0* boost.
Then if safe I add boost from there...?
g
Old 03-16-2009, 02:26 AM   #2861
Maybe motor heat sinks would be better?
stocker is offline   Reply With Quote
Old 03-16-2009, 04:32 AM   #2862
I think i will use a motor head sink. I don't cool the motor before the race.
I just put a head sink on the motor with a fan so the temps will not reach the 180.
Than i can gear it a bit heavy'r.
more power
they are going to test the gm speedo to as the dyno is repaired.
Also using a heavy'r fly wheel so they can measure the Tekin RS to.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-16-2009, 04:51 AM   #2863
tc3team's Avatar
db 40
rs off
bs 85
nw 10
blfw
tp 5
vc off
pc off
tb 21
cl off
How were your laptimes when you dropped it 5 teeth?
If the grip came up for the main, maybe the agressive throttle profile, coupled with a different gear ratio didnt help?
I'm guessing you've checked for any binding in the transmission.
Just throwing ideas out there to think over.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-16-2009, 05:10 AM   #2864
thanks.
g
it reduces motor power, quite a bit, so it allows you to drive to the pits and not just stop dead on the main straight, lol.
This weekend setup. Redline 10.5, Powercel LiPo, RS Pro, Foams, 57mm
DB 1&2 LED's
NW 1&2 LED's
BS - 100
MT - Fwd/Brake
Vc - 2 LED's (6.0v)
TP - 3
Limiter - 90%
SENSORED ONLY
Boost MAX
Motor timing - 5'
ESC temp was 3-4LED's
Motor Temp 60'c (140'F)
Geared at 6.09:1
DA_cookie_monst is offline   Reply With Quote
Old 03-16-2009, 05:54 AM   #2865
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Decided to go with the RS and not the Pro. Only difference is the motor limit isnt it?
I only race spec classes 17.5 and 10.5 so no real need to fork out the extra $$ for the Pro. Ill be ordering the esc tomorrow. Looking forward to see how it compares against the tc spec.
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
