Old 03-12-2009, 11:43 AM   #2821
I have my Tekin Redline motor 10,5.
Compare to a LRP 10,5. do i need to gear it lighter or the same?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-12-2009, 11:45 AM   #2822
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by or8ital View Post
Wow, had to retrieve this thread off page 3.
Had a question. Have a RS Pro. Going to run two classes with the same car and need to switch motors quickly and don't want to solder. So I thought about possibly soldering some 3.5mm plugs on the side of the gold posts. Would that cause temp problems on the ESC? It would just be for 17.5 and 21.5. Thanks.
I would say that you'll be just fine, especially with the RS Pro and those motors. Lots of bashers (and some racers) run connectors everywhere with much faster setups.
You'll barely be exercising that RS Pro and it won't even notice.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 03-12-2009, 11:48 AM   #2823
Dragula426's Avatar
This is just my opinion, but why not just put the 4mm bannan plugs on at the end of the wires, then wire the motor with the matching opposite end. I have seen this done, and they keep the wires on the motor super short. You just match up the right wires and go. I used these connectors in the past for this, and they work very well. On mine, I had the female ends on the motor, and had heat shrink over them. They were just 1cm longer than the connector itself, and it always stayed on the motor. Made life easy when you had to switch.
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 03-12-2009, 12:03 PM   #2824
Trader Rating: 38 (100%+)
Thanks Reen, I thought it should be OK too. I don't know how I will do it yet but wondered if that was an option. It is going in Evo V so the Speedo is right next to the motor connects so that area for wires is really small.
Dragula, not sure what Im going to do yet. The motivation for the plugs on the speedo itself is that it keeps the weight lower and would be a little cleaner.
or8ital is offline   Reply With Quote
Old 03-12-2009, 12:54 PM   #2825
Team Tekin
Tekin Prez's Avatar
My concern would be stressing that solder joint plugging in and out. Should be no performance problems or heat on any spec motor with RS or RSpro. Even the RS is hardly breathing hard on a 10.5
We run about 3" of wire on the speedo with a 4mm female, and 3" of wire on the motor with a 4mm male. Longer than needed for some installs, but we are constantly switching things around. Makes is easy and we are not stressing any of the solder joints. We suggest our 4mm high power solid connectors.
Tekin Prez is offline   Reply With Quote
Old 03-12-2009, 01:18 PM   #2826
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
lighter
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 03-12-2009, 01:45 PM   #2827
This past weekend the Tekin RS esc helped me take the TQ and win in 12th scale Super Stock at our ROAR Region 11 Carpet Regional’s held at Timezone ll. With one day of set up and playing around with gearing I was able to hit the sweet spot. I have to say this is the smoothest speed’o to date and it made mad rip! Not only did I like the way it performed I loved how it mounted in the car. With its small foot print and soldering post made install a breeze.
Will be picking another one up for my other Slapmaster Tools MS3 12th scale for Carpet Nationals next week!
Here is what I was running for set up:
-189 software
-58 on drag brake
-100 on brake turned way down on radio
-3 on throttle profile
-boost all the way up
-13.5 Duo motor on 0 timing
-72mm roll out
-Timezone ll, 100x60' carpet, really open
Thanks Tekin for the great product,
Kody
Kody is offline   Reply With Quote
Old 03-12-2009, 02:30 PM   #2828
mkdut's Avatar
Trader Rating: 19 (100%+)
-189 software
-58 on dag brake
-boost all they way up
-72mm roll out
Kody
Well it's good to know my speedo settings and rollout weren't the issue. Nice run Kody, the car looked dialed and the corner speed was phenomenal. Good luck at nats.
mkdut is offline   Reply With Quote
Old 03-12-2009, 03:31 PM   #2829
Thanks Mike.
Every thing was working great last weekend. Car, esc, motor...
Old 03-12-2009, 03:39 PM   #2830
Originally Posted by sg1 View Post
lighter
Thanks.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-12-2009, 10:04 PM   #2831
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Kody
That is music to my ears. Great job by the way! The more info everyone shares with setups at different tracks the "perfect" setups will only get easier to find.
Thanks for sharing!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-12-2009, 10:38 PM   #2832
Trader Rating: 115 (100%+)
Are you able to change the bearings in the Motors? If so what size?
Also are you able to use a novak capacitor?
Breeze is offline   Reply With Quote
Old 03-13-2009, 04:15 AM   #2833
Default Capacitor
I have lost the capacitor for my spare RS.
What is the spec of the cap? is it something that will be easy to find from electronics suppliers here in the UK?
reynard55 is offline   Reply With Quote
Old 03-13-2009, 04:28 AM   #2834
The capacitor specs are: 16V 330uF
Ahmed Aman is offline   Reply With Quote
Old 03-13-2009, 09:46 AM   #2835
Team Tekin
Randy_Pike's Avatar
Tekin bearing set: TT2282
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
