Tekin RS ESC sensored
#2806
Guest
THe only recommendatiopn I can make to you is to gear for lap times, look at the temperature for safety. What I mean is, if you go up and your lap times improve, go up again, just watch the temp and don't let it get over 180F or so.
I find my lap times stop improving by the time I get to 150F, the car doesn't get any faster. THis is in a 1/12 car with 4 cell NIMH battery. I also notice that even though the lap times are the same at 135F and 160F, at 160F there is a noticeable fade in speed late in the run... I believe it is because I'm using more of the batteries capacity and geting the voltage lower.
So... I gear for best lap times with no fade at the end, and look at temperature just to be sure I'm not hurting anything. For off-road, you'll probably be getting into higher temps than me, so consider 180F to be the upper limit.
When your LiPO was down to 3%, what was the voltage... for a 2 cell LiPO, anything above 6 volts should still be safe. From what I know of LiPO, you can run down to 3V per cell safely.
Thanks a LOT for the feedback. I just finish charging the lipo - I assume voltage was to 6V if I remember well. but I just put back 3750 mah average. So the lipo was close to be empty. Got another lipo, went down to 17%
I'm used to rc helis and when you have the cutoff ... you know that you have to land ! just weird I didn't notice anything... or maybe I'm going such slow that even with the cutoff I still manage to find it fast enough (really possible)
Cédric
#2807
Hi,
Cédric
Cédric
#2808
Just wanted to say Thank You to Jim,Randy and Tekin for the support with RS Speedo. This weekend was second large event new RS in my car. I was able to sucure TQ and win in 17.5 touring in the Carolina Touring Car Series first leg after being wrecked on lap 1 going to 10th and having to POWER thru the feild. Amazing speedo I used to run 3.7 ratio and now run 4.35 it has soo much power!!!
#2810
Guest
I'll just check directly at the club with my Hyperion DUO charger.
Cédric
#2812
I have a question about the rotor.
Witch of the 2 rotors has the most torck and wich one the most rpm?
Or what is the difference between them?
#TT2271 12.3mm (stock legal) BL ROTOR
#TT2272 12.5mm (stock legal) BL ROTOR
#2813
The 12.3 rotor will have more rpm since it's smaller diameter creates more air gap. It also has less magnetic mass.
The 12.5 rotor has less air gap and more mass therefore will have mor torque and less rpms.
#2814
and witch one is faster?
or is the 12,5 better for short tracks and the 12,3 for long tracks?
#2816
I am searching every online store for the RS and it seem no one has them when will they hit the stores?
#2818
#2819
Wow, had to retrieve this thread off page 3.
Had a question. Have a RS Pro. Going to run two classes with the same car and need to switch motors quickly and don't want to solder. So I thought about possibly soldering some 3.5mm plugs on the side of the gold posts. Would that cause temp problems on the ESC? It would just be for 17.5 and 21.5. Thanks.
#2820
didn't had any problems.
