Old 03-05-2009, 09:04 PM   #2761
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Randy_Pike View Post
Try reversing your throttle channel. Ko's, Futaba's and a few others need it reversed to make our "window."
Tried that. No luck. I bound my radio to my son's RS and it works great. I think I'll try to reload version 189. Maybe I screwed it up.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-06-2009, 04:48 AM   #2762
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-06-2009, 05:59 AM   #2763
sagejyoung's Avatar
hey chaps i would like to know what motor settings i should run on my RS with a 17.5 tekin motor gearing to around 44mm rollout, foam on asphalt and locked into a corally rdx phi? is there a feature like launch control
(as found on the lrp Sphere tc spec) ??? if not could i suggest some setting like that programmed in..
sagejyoung is offline   Reply With Quote
Old 03-06-2009, 06:40 AM   #2764
Trips's Avatar
Trader Rating: 16 (100%+)
If you're running the speed control as delivered, I'd suggest that you run in dual mode (sensor mode box unchecked in hotwire) with throttle profile 3 or 4, neutral width 10, brushless forward only, no current limit, timing advance to 100 and rollout around 50mm.
If you run the 1.89 firmware in your RS, then check sensor mode, run the boost to maximum, turn the endbell timing all the way clockwise, rollout around 44-44.5mm.
Watch temps, and gear accordingly for lap time, but those will be close.
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-06-2009, 10:11 AM   #2765
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Mikky:
We take every customer seriously regardless of where you're located. However there are a lot of times where we service sent in that has nothing wrong, user error or some other issue that is esc controlled.
I know Jim is not ignoring you. However he is a very busy man and may not be the correct person to be talking to. The normal channel would have been via [email protected] or you could have delt with me [email protected] as I know we've spoke in the past.
We ship to the address we are given. If there's an error with that we cannot be held responsible for those errors.
Please forward me any emails you've gotten so I can see where we are at with your service issue: [email protected]
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-06-2009, 11:10 AM   #2766
okayplayer
Guest
Posts: n/a
Hi,
What is the recommended FDR for my tekin 6.5T brushless motor ? I will be using it with a RS PRO in 189.
I was told to gear down, but since I don't know the recommended FDR, I'm stuck.
FYI, this is the track where I'm going to practice
http://www.youtube.com/watch?v=tC6UpXcWKeA
Thanks a lot !
CÚdric
Old 03-06-2009, 11:37 AM   #2767
I removed my earlyer post because i got an explanation from Jim with what the problem was. Sorry for wath is posted.
Someting in the communication went wrong.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-06-2009, 11:38 AM   #2768
Team Tekin
TY@TEAMTEKIN's Avatar
No worries! We'll get it all sorted out in no time
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 03-06-2009, 11:41 AM   #2769
okayplayer
Guest
Posts: n/a
Originally Posted by okayplayer View Post
Hi,
Thanks a lot !
CÚdric
Maybe TeamTekin forum is better to ask for this question instead of the ESC thread ?
Old 03-06-2009, 11:56 AM   #2770
Trips's Avatar
Hi,
Thanks a lot !
CÚdric
Help us to help you... what kind of car are you asking about?
MARSHAL!!
Old 03-06-2009, 12:10 PM   #2771
okayplayer
Guest
Posts: n/a
Hi,
Sorry, here's some information on my setup that may help you to help me.
Basics & electronics
I (will on monday) run for first time my Xray T2 EU 009, on asphalt (see the youtube video with the track) with rubber tyres (Jaco Green) or RB 4xfront foam tyres (shore 35) with a Mazda 6 bodyshell.
Car is "perfectly" setup with a hudy according to the T2 manual (EU asphalt)
My electronic is : Tekin RS PRO (v189) + Tekin 6.5T (on a 21T pinion for the moment) with a 48 - 84 Spur.
Tekin RS PRO setup:
I have in stock also a 87 spur and ordered a 17 & 19T pinions
According to the manual, here're the FDRs :
Spur 84
17T:8.40
19T:7.52
21T:6.80
Spur 87
17T:8.70
19T:7.78
21T:7.04
Hope that helps,
1/ what is the FDR to go for the 6.5T motor ?
2/ any remarks ?
CÚdric
Old 03-06-2009, 12:11 PM   #2772
witz_dan's Avatar
Trader Rating: 25 (100%+)
Default Redline in a crc gen x
Has anyone tried to put a redline in a crc gen x 12? I can't figure out how to get it in there. Novak brushless motors fit. they are slightly shorter and the sensor wire is on the side of the endbell as apposed to the redline where it is at the bottom.
Any help thanks
Dan
witz_dan is offline   Reply With Quote
Old 03-06-2009, 12:18 PM   #2773
the speedo that i shiped to tekin didn't arrive. that's why i didn't get a new one.
Now i hope that i can trace the post.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-06-2009, 02:33 PM   #2774
Jsaves's Avatar
Randy,
On the set ups for RS & 17.5, I noticed that you are using the Throttle pro #3.
Would throttle #5 be better?
What are the differences besides more aggressive?
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 03-06-2009, 02:50 PM   #2775
stiltskin's Avatar
Originally Posted by stiltskin View Post
Need help!! I'm trying to calibrate my KO Helios to my RS speedo. After setting the throttle throw, I get the 1,2,3 lights blinking indicating that my radio signal is lower than expecte. I tried making different adjustments with the same result. I even tried an M8 and still have the same problem. Anyone have a clue as to what would cause this? Thanks.
Alright, here is my public apology to Tekin and my thanks to Randy Pike for dealing with me. After hours of thinking, scratching, pacing (and a little drooling on myself) I charged the battery. Apparently it is required for this thing to work. Who would have thought?
Tony Rumple
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
