Tekin RS ESC sensored >
Old 02-26-2009, 05:41 AM
  #2641
Has 1.89 been replaced...I know there is 1.9 something but I saw on the website 2.7...I guess whats the most recent software?
NUCRPTRACER is offline
Old 02-26-2009, 05:52 AM
  #2642
HarryN's Avatar
2.7 is the new Hotwire software. As far as version 1.89 and 1.9x, that is the firmware upgrade for your ESC. But I was not aware there was a 1.9x firmware update already...
Randy?
HarryN is offline
Old 02-26-2009, 06:06 AM
  #2643
Randy?
I may be mistaken I did not have a CPU avalible at a race and used someone else's and the screen was layed out different maybe it was just different hotwire software....So 2.7 and 1.89 is what I should be using? Is 2.7 whats avalible on the website?
Old 02-26-2009, 06:12 AM
  #2644
Trader Rating: 79 (100%+)
Randy?
+1
MUDVAYNE is offline
Old 02-26-2009, 06:23 AM
  #2645
Well I would say I am wrong cause the guy's computer I was using was runnin VTA and he isnt sponsored so I bet it was just 2.7/1.89....
Old 02-26-2009, 09:40 AM
  #2646
Team Tekin
Randy_Pike's Avatar
Currently the only version that is available to the public from me is 2.9/ 189
The team is using another version that has some 4 cell improvements.
Once we're satisified that it's as solid as 189 we will let you ALL know and post it on the site.
Randy_Pike is offline
Old 02-27-2009, 08:28 AM
  #2647
John Tag's Avatar
Trader Rating: 42 (100%+)
Kenny L check your E Mails ASAP and contact me...
John Tag is offline
Old 02-27-2009, 08:55 AM
  #2648
Trips's Avatar
Trader Rating: 16 (100%+)
2.7 and 1.89 do not work together.
Trips is offline
Old 02-27-2009, 09:11 AM
  #2649
Yeah I know it was 1.89 I had not updated my esc and was using 180 thats why it looked different timing advance vs timing boost soory for stirring things up Randy...I appologize....All your midwest team guys have been a great help to me Randy.....Not to mention its a great esc.....
Old 02-27-2009, 10:33 AM
  #2650
xtrememadness's Avatar
hey randy can you give me a starting setup for 7.5 with version 189. thyis will be used in 2wd offroad buggy. thanx i appreciate it
xtrememadness is offline
Old 02-27-2009, 11:58 AM
  #2651
Team Tekin
Randy_Pike's Avatar
Sure,
Try running the 7.5 in dual mode, Timing advance at 50, Nuetral width at 10, TP 3. Motor timing set at default(12).
Old 02-27-2009, 12:51 PM
  #2652
LOSI123's Avatar
Trader Rating: 63 (100%+)
LOSI123 is offline
Old 02-28-2009, 05:08 PM
  #2653
Trader Rating: 60 (100%+)
I am need of some guidance to make my VTA 415 fast. I have the 1.89 software. tekin RS, trinity DUO(red endbell 17.5). I want run it like i do my tekin 13.5 but i dont how to zero the timing on the motor itself so I can run the full boost without burning it out.. Basically i want to set my motor to zero degrees timing on the motor, install 1.89, max out the boost, and not burn out the motor. Some help would be nice. thanks in advance
todb is offline
Old 02-28-2009, 05:25 PM
  #2654
katfish317's Avatar
I believe that the lowest advance setting on the motor is 12 degrees. I have my 17.5 duo geared at 3.87 and have 189 software lowest timing and it come off the track at 135.
katfish317 is offline
Old 02-28-2009, 05:26 PM
  #2655
Trips's Avatar
The Duo 17.5 may not get to true zero on thge timing. We back the timing off as far as possible and run full boost. To back the timing off, loook at the endbell. There are three sets of three screw holes in the endbell. Loosen the three screwws, hold the can and turn the endbell clockwise until the last set of holes line up with the screws. Tighten the screw, then you're as close to zero as it gets. Max the boost. Back off several teeth on the pinion and start running. Sneak up a tooth at a time on the pinion until you stop getting faster. Check temps to make sure you don't overheat, but in my experience you'll stop getting faster before you start overheating with a Duo 17.5 on four cells.
Trips is offline
