Old 02-24-2009, 08:44 PM   #2596
can someone send me version 1.89 tonight ? need it for tomorrow.
spruce is offline   Reply With Quote
Old 02-25-2009, 01:22 AM   #2597
okayplayer
Guest
Posts: n/a
Hi,
Is there an upgrade list on the 1.89 ? I mean the list of improvement implemented in it?
CÚdric
Old 02-25-2009, 02:04 AM   #2598
HarryLeach's Avatar
Send a message via AIM to HarryLeach
So this motor separation, is this a direct result of hard impacts, or a small batch issue on the redline motors? Luckily I don't have too many hard board smacks these days, but it would be nice to know the circumstances that I should inspect extra carefully after.
HarryLeach is offline   Reply With Quote
Old 02-25-2009, 02:15 AM   #2599
tc3team's Avatar
So, I collected my RS Pro combi and hotwire yesterday...
Just when you think the RS Pro is small... I then look at the hotwire! Damn, now I need a smaller reciever to match the ESC...
Can't wait to get these strapped in and rollin' !!!....
Sweet packaging too, the business!!!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-25-2009, 02:32 AM   #2600
HarryLeach's Avatar
The redline motor box makes an excellent super-cheap TC car stand for saucing tires too
Old 02-25-2009, 02:56 AM   #2601
tc3team's Avatar
There is some sticky stuff on the underneath of the Hotwire when it comes out the box too, which is useful for keeping it stuck to a laptop, table or where ever
We have more innovation than others think!
Old 02-25-2009, 03:09 AM   #2602
HarryLeach's Avatar
LOL, unfortunately for me, when I installed my RS [at the track no less], the pit table was dirtier than it looked and the sticky stuff didn't work, but I definitely tried!
Old 02-25-2009, 05:24 AM   #2603
tc3team's Avatar
Haha, finally some use for that motor spray, right there!
Also, a general tip:
I'm pretty sure it mentions it in the user guide, but make sure those solder tabs on the ESC and motor are uber clean before you solder.
It will just help things "stick" better when we are getting the solder and wires on to them. You may even want to file/scratch up the motor tabs a tiny bit (if you can), to help the solder "bite" onto it, although you probably shouldn't have to.
It's the kinda similar process to soldering cells/bars together...
Old 02-25-2009, 05:43 AM   #2604
HarryLeach's Avatar
I didn't have any problems soldering the motor leads, I did scuff them slightly and pre-tin them though. Then again, soldering is a big part of my job, and I have a selection of irons for my RC habit. I am considering re-doing the solder job on the posts though, some other guys have a lot cleaner install than I do, so I'm thinking I didn't use an iron with enough wattage. When I get home from work in 3 weeks or so I'll probably do that simply because it bothers me how ugly the posts turned out just thinking about it, lol.
Old 02-25-2009, 06:45 AM   #2605
tc3team's Avatar
Having as little exposed wire as possible is a plus too for neatness,(easily overlooked until someone points it out) but im sure you knew that already and will have it figured out quick.
I'd probably be looking about about 5-6mm max of bare wiring to get it soldered - Just enough to make it good on the tabs, but not excessive for it to look untidy.
Old 02-25-2009, 07:13 AM   #2606
HarryLeach's Avatar
Oh yeah, the motor tabs are fine, I won't be messing with those unless I need to do a motor change for some reason.
My real ugly spot was the posts, not using a high enough wattage iron to get the wire in the groove and flowed to my satisfaction. Right now it kind of looks like a butt joint goobered together Functional, and worked just fine with no hint of joint heating to indicate that I was losing any power there, just looks horrible to me. But that's ok, if I didn't leave anything to do to my cars when I go to work, I'd be totally bored when I got home sitting around a week or so until the weekend races rolled around!
I'll be in hog heaven when I get home in 3 weeks, fix my ugly RS solder job, find some more speed now that my buddy seems to be a tick faster since I put my identical setup on his FK'05 just before having to leave town, break in 2 nitro engines for outdoor season [sedan and 1/8 buggy], and then start dialing in setups for nitro sedan and the FK outdoors once I get my carpet setup nailed for next winter. Oh yes, addiction irreversible
Old 02-25-2009, 08:27 AM   #2607
tc3team's Avatar
Sure sounds like you've got your work cut out there
Yeah, won't do it any harm to resolder, and with better looks you'll be feeling happier with it on the eye
Old 02-25-2009, 08:40 AM   #2608
HarryLeach's Avatar
Lol, that's the short list
Let alone how many bodies I have to airbrush for this season for myself and deals lined up from the end of last outdoor season.
But back on topic, I love my RS Pro, rushed solder job on my part aside. It helped put me solidly in the A-main on a 3 main day at the local track on my first outing wheeling my own car in 1/10 EP sedan
There were also quite a few guys coming over after the race to get some pointers on my hotwire setup, which was the single biggest change I made that day.
Old 02-25-2009, 09:14 AM   #2609
Geezatec's Avatar
Soldering maybe a job, and more of an art. Tinning the soldering post, and wire. It should take more then a second. 36 -45 watts iron is good enough. If seems to hot for you, use a hemostat as a heat sink, os a alligator clip on the ESC soldering post. Should make it easier for you.
Geezatec is offline   Reply With Quote
Old 02-25-2009, 09:15 AM   #2610
mkdut's Avatar
Trader Rating: 19 (100%+)
OK so after getting the software up and running on my Linux based laptop all I have to say is someone needs to make a Linux port of the hotwire software.
With that said what settings should I be using for 1/12th scale using a Trinity 13.5 Duo? And should I be running the 189 software? And if so where can i get it?
Thanks for the help.
mkdut is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
