Tekin RS ESC sensored >
Old 02-24-2009, 09:01 AM
  #2581
Trader Rating: 120 (100%+)
thanks guys
Breeze is offline
Old 02-24-2009, 09:34 AM
  #2582
C5Vette's Avatar
I've got a question about the redline motor. I've been running a 13.5 redline now for a couple of months. Today, I noticed that there is an aluminum ring at the back of the motor near the endbell that is coming loose. I took the enbell off and it was tight. It seems that the only thing holding the back of the motor on is the Tekin label. I know that can't be right so something has got to have come loose. Can anyone with experience here help me? The thing seems to run fine but I know this has to be trouble brewing.
Thanks,
Ray
C5Vette is offline
Old 02-24-2009, 09:51 AM
  #2583
okayplayer
Guest
Posts: n/a
Hi,
I have received my Tekin Combo (RS PRO + Redline 6.5 + Hotwire)
Just wondering if something special has to be configured (or recommended setup) or would the default specific settings (except the lipo cutoff) fit ?
This is the track were I'm gonna use my tekin combo on my Xray T2 009 with 2S 35C lipos
http://picasaweb.google.fr/okayplaye...99672272382034
http://picasaweb.google.fr/okayplaye...99693832107954
http://picasaweb.google.fr/okayplaye...99749433590162
Do you all solder wires to the motor ?
Btw, what a top quality from Tekin products... Really impressed.
Take care,
CÚdric
Old 02-24-2009, 10:06 AM
  #2584
HarryN's Avatar
Originally Posted by okayplayer View Post
Hi,
Take care,
CÚdric
I've never played with low turn motors, but I do know that when you hook up your hotwire to your ESC, make sure your LiPo cutoff is set to 2 (6v). When I practice, I like to use all the juice my car has and this setting has saved me a few times.
As far as soldering is concerned, I solder my wires directly to my motor and use a little solder as possible to minimize resistance. Some people use pole connectors to make it eaiser to swap out motors. If you have a good soldering iron, soldering should not take too long when swapping out motors.
Hope this helps!
HarryN is offline
Old 02-24-2009, 10:07 AM
  #2585
HarryLeach's Avatar
Thanks,
Ray
Did you check the screws on the output shaft side?
HarryLeach is offline
Old 02-24-2009, 10:12 AM
  #2586
Thanks,
Ray
I've seen a couple of these locally where the can came loose from the stator. See if you can push the motor back together by hand.
If it slides back together contact Tekin and they'll hook you up. A little JB weld would fix it up but it's probably better to talk to Tekin.
Fred_B is offline
Old 02-24-2009, 10:18 AM
  #2587
okayplayer
Guest
Posts: n/a
thanks for the help Harry,
does it worth to put some heat shrink on the power capacitor ?
CÚdric
Old 02-24-2009, 10:33 AM
  #2588
C5Vette's Avatar
Yes it pushes back together by hand....but it's still loose. (The output screws are short....not like on a novak...they do NOT hold the back together)
Fred, do you know what originally holds that together? Is it just glue?
Ray
C5Vette is offline
Old 02-24-2009, 10:40 AM
  #2589
Team Tekin
Randy_Pike's Avatar
C5,
Please email me about the motor. From the sounds of it you have a seperation on the motor. It can be repaired easily.
Randy_Pike is offline
Old 02-24-2009, 12:34 PM
  #2590
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default wow
Originally Posted by Randy_Pike View Post
C5,
c5 now you cant beat that , now that is service way to go TEKIN and nice job Randy thats why i run TEKIN now, tried the rest and now im with the BEST
2056dennis is offline
Old 02-24-2009, 02:09 PM
  #2591
tomdav's Avatar
Trader Rating: 42 (100%+)
Anyone seen this before? I threaded the motor screws on first to install in a B44 and noticed my screw holes are not tapped straight. All six are like this.
I used longer screws for the visual.
tomdav is offline
Old 02-24-2009, 02:12 PM
  #2592
sportpak's Avatar
Trader Rating: 26 (100%+)
Oooo.... Something went bad in that setup. ISO would not be happy about that one. I'm not sure how they have them setup, but it looks like the rotary chuck or live tooling is knocked out.
sportpak is offline
Old 02-24-2009, 02:40 PM
  #2593
LOSI123's Avatar
Trader Rating: 63 (100%+)
My Tekin 17.5 redline is also like this (Screw holes in motor are out of alignment, mine actually seem too far apart from each other) and it tweaks my chassis and i think it may have bent my expensive brand new hot bodies cyclone brushless motor mount.
LOSI123 is offline
Old 02-24-2009, 03:24 PM
  #2594
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Thanks,
Ray
I had the same thing happen to my 17.5. I guess there is only so many times you can smack the outside of the sweeper before something comes loose! I carefully removed the ring, cleaned the mating surfaces, applied JB Weld, and re assembled. I let the JB Weld cure for 24hrs first. I have since had no problems with the motor.
SpraydbySprague is offline
Old 02-24-2009, 07:33 PM
  #2595
C5Vette's Avatar
C5,
Thanks Randy, Awesome customer service!
Ray
C5Vette is offline
