Old 02-21-2009, 06:20 AM   #2536
Originally Posted by Ron Goetter View Post
There is 8* of timing built in a duo. Speedo has 15* built in. and boost is maxed out. So 8+15+30=53* of total timing is what I've been running in 17.5 with between a 44 to 48mm rollout.
8* of timing in built on a 17.5 or all DUOs?
stocker is offline   Reply With Quote
Old 02-21-2009, 09:09 AM   #2537
pcar951's Avatar
Trader Rating: 19 (100%+)
A little help here guys??
I have the "189" software and the Hotwire from Tekin but I can't seem to load it. How do I get the "189" zipfile into the ESC?
THX
pcar951 is offline   Reply With Quote
Old 02-21-2009, 09:13 AM   #2538
Trader Rating: 76 (100%+)
THX
I think you're going to have to unzip it with the pc, then load it.
MUDVAYNE is offline   Reply With Quote
Old 02-21-2009, 09:36 AM   #2539
pcar951's Avatar
Oh I get it, "189" isn't an update for the existing program....it IS the program.
OK, dumped the old softwire and got 189 all loaded up.
Next dumba$$ question, what's everybody running for TC 13.5 / 17.5??
What do custom profile 1 / 2 look like?
Old 02-21-2009, 10:10 AM   #2540
pcar951's Avatar
An ipod app for Hotwire would be cool. Kinda like a really high end pit wizzard!
Old 02-21-2009, 02:18 PM   #2541
all4losi's Avatar
Default Hot Wire Lipo Cutoff
I recently got a Rs Pro and a 13.5 combo. I downloaded the latest v. off teamtekin.com ran the update and all seems fine BUT. When I set the lipo cut in hotwire it reverts to default every time (no cut). All the other adjustments change to my settings no problem. I found this out the hard way. Now if I use hotwire I have to set my lipo cut after on the esc. It's easy enuff to do but it ain't right.... Any help?
all4losi is offline   Reply With Quote
Old 02-21-2009, 09:30 PM   #2542
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
They all have that built in..
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 02-21-2009, 10:20 PM   #2543
OK. Someone earlier mentioned 12*, some say 0*, so I'm kinda confused what it is...
Old 02-21-2009, 10:22 PM   #2544
Well thats directly from Chad Phillips at Trinity..
Old 02-21-2009, 11:18 PM   #2545
Tucker101's Avatar
Send a message via MSN to Tucker101
Whats a starting point in gearing for a LRP 4.5 turn brushless with a RS Pro?
Just a good starting point for intermediate tracks is all i need.
Thanks.
Tucker101 is offline   Reply With Quote
Old 02-22-2009, 10:59 AM   #2546
Trader Rating: 36 (100%+)
Does anyone have a good rollout starting number for a Duo 21.5 on a semi-technical carpet track?
I'm running the 1.89 software.
Any help is appreciated.
EVILGRAFX is offline   Reply With Quote
Old 02-22-2009, 12:39 PM   #2547
Default Braking with boost on full?
Hey all,
I purchased the RS and redline 13.5 and so far i've been happy with it. love the idea of being able to update firmware + settings through my laptop so thats all good
Personally i've found the Roche Prince 13.5 motor having the edge over the tekin so far but i need to play more to see if i can push more from the tekin
Anyway onto my question, a friend mentioned this to me and i noticed it quite a bit today running 10.5. When the speedo is on full boost (30) the breaks seem to be very weak compared to my old Nosram ISTC speedo. He said they found this was the case when they used boost on the GM speedos so i wonder if anyone else found this and if there is anything else that can be done to counter it?
Ian
DaSloth is offline   Reply With Quote
Old 02-22-2009, 07:33 PM   #2548
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by reenmachine View Post
I finally decided that I'm going to run 189 for the first time this weekend. I've been running the RS with a 17.5 for several months and I just had it so fast and dialed that I was reluctant to mess with it. Now I'm putting it in my 13.5 car so I figured I'd step up. Here's my initial setup -- let me know if you see any obvious errors:
RS v189
Sensored-only
SpeedPassion 13.5, timing fixed at 12 (per this thread), so 18 timing boost
Drag Brake 0
Brake Strength 100
Neutral Width 10
I'm leaving my FDR at the usual 4.55 (good-sized outdoor asphalt) but I have several steps of smaller pinion which I imagine I'll need (have temp gun). What are you guys gearing a 13.5 to in similar circumstances?
Originally Posted by doriftu View Post
Hows the SP motor with 18deg boost? is this the optimum setting?
I don't know yet -- I won't be doing any testing until Sunday. From everything I've read it seemed like motor timing + boost = 30 was a good place to start, and the SP motor is fixed at 12 motor timing...
With the above setup (189, SP13.5, 18 boost, 4.55FDR) I was coming off the track at 135F after a 6-minute heat. I bumped the boost to 22 and was coming off at 165-170F so I left it there for the main. I'll probably drop one tooth, which will put me at 4.65FDR and give me a touch more punch in the infield. Overall, it was a nice gain going from 180 to 189 -- I was as fast as anyone on the straight while being geared better for the infield. Others were geared more like 4.4-4.5FDR. I also added back in some drag brake (25) with the 13.5 that I didn't run with the 17.5. That little bit of weight transfer helped my high-speed turn-in considerably. I mention this because adding drag brake probably would have bumped temps up a bit on its own.
I am also not running any sort of cooling on the motor. I may add a heat sink and fan so I can get a bit more aggressive yet.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 02-22-2009, 11:01 PM   #2549
its definantly 12 degrees. the lowest setting is the same as the speed passions.
i have marked a duo to check and i got 12. though it is pretty easy to skrew up
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 02-22-2009, 11:43 PM   #2550
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
so how EXACTLY do i setup the rs to be used in 1/12 lipo situation???
i dont wanna fry anything..
chewiefttc4 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
