Old 02-15-2009, 08:41 AM   #2491
Originally Posted by okayplayer View Post
Hi,
Why everyone is running 17.5 or like with T2 or TC5 onroad rubber?
this is weird ... I was planning to run a tekin 6.5T ... do you play with the spur .. pinion to have top speeds ...?
where can i find something that I could read to understand that?
CÚdric
Novak recommended 7.5 Final Drive Ratio for a 6.5 in a TC. So with the T2 if you look on page 41 for the charts it will let you know what pinon and spur to start with. As for top speed this depends on your track and how large it is.
Here is a link to the FDR charts
http://www.teamxray.com/teamxray/sho...p?file_id=2531
-=light=-
Gorden
light is offline   Reply With Quote
Old 02-15-2009, 08:57 AM   #2492
Originally Posted by [email protected] View Post
Haha, the powerbands are a little inside joke, there isn't anything like that.
Guys,
lol Me being too gullible... Could had me going for a right while with that...
I was down the local track today and someone said about another speedo on the way? Is this true?
CouldbeFaster is offline   Reply With Quote
Old 02-15-2009, 09:55 AM   #2493
okayplayer
Guest
Posts: n/a
Hi,
What is the RPM of a Tekin sensored 6.5T; I haven't found it anywhere on Tekin website or motor specs
CÚdric
Old 02-15-2009, 05:21 PM   #2494
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by avs View Post
Randy,
could you post a 17.5 setup too? i have read the last 20 pages of this thread multiple times and am getting more confused not less.
my preferred application would 1/12 if that matters.
also just to clarify what the current tuning priorities are with 1.89 firmware:
1) get minimum lap times by adjusting rollout and 'boost' with 0 (or minimum) physical timing on the motor, without overheating the can.
2) adjust all other parameters for personal taste.
does this sum up the situation? or is there other concerns?
thanks in advance for the help.
hey avs. we run timing boost at max and 0 degrees on motor for 1/12 scale i run donny lias setup as he is a friend of mine and i race at his track regularly i can pm you with the setup if you like
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-15-2009, 05:57 PM   #2495
Bob~H's Avatar
Ran my RS Pro for the first time today. I noticed in the second qualifier that the car was a bit sluggish after a little fender bender. When I got the car off of the track I saw that the sensor wire had come unplugged. Thanks to running in the dual mode I was able to finish the race with very little difference. Thanks Tekin!
Bob~H is offline   Reply With Quote
Old 02-15-2009, 06:04 PM   #2496
reenmachine's Avatar
Trader Rating: 26 (100%+)
That's a great feature of the Tekin whether you're in dual mode or not. Even if you're running sensored only, if the sensor cable comes off or is damaged the ESC reverts to sensorless mode. It may feel a little different, but you'll finish the race instead of DNF-ing.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 02-15-2009, 07:08 PM   #2497
what is considered the boost in the hot wire software?
SPC Racer is offline   Reply With Quote
Old 02-15-2009, 07:32 PM   #2498
mojoman's Avatar
Boost is motor timing in v180. If you have v189 they call it boost. The difference in adjustment is timing goes to 100 on the dial and boost goes to 30. These are not percentages just measurement increments.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-15-2009, 07:42 PM   #2499
Well, there's more to it than that. In 180 motor timing is only applied in dual mode. The boost in 189 is used in sensored only mode.
Pete Waydo
Old 02-15-2009, 09:21 PM   #2500
bucknuts's Avatar
Originally Posted by Randy_Pike View Post
SPC: Flip your throttle to reverse. I always recomend the epa's be set equal to each other ie, 140 and 140 or 100 and 100.
Steve, you found out the hard way. Sorry to hear that. Timing has sweet spots for each combination. For WGT a lot of our team guys were running 0 motor timing and full boost at the birds. This setup renders 30 degrees of timing total. Not a bad place to be with a 17.5.
You don't usually want to be over 40 degrees EVER between motor timing and boost. This is where you will see too much heat and no performance gain at all.
Try the above "birds" setup. I'm sure you will like it.
Is this with tekin motors or all motors?
bucknuts is offline   Reply With Quote
Old 02-15-2009, 10:56 PM   #2501
snoopyrc's Avatar
Whats the lowest wind of motor that can be controlled with the RS? What do you really need the pro for? I need a 4 cell and lipo answer.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 02-16-2009, 04:49 AM   #2502
Whit the RS it's a 5T.
With the RS Pro it's no limit so a 2,5T will do.
Only till 4T with lipo and under 4T 5cell max.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-16-2009, 07:26 AM   #2503
mangoman's Avatar
My understanding is that the standard rs should be fine for 4 cell applications.
You will probably need to specify how many cell lipo you mean?
With a 2s lipo i assume its the same as 6 cell nimh, however, you need to keep in mind that with mod applications that it is recommended that you run a fan blowing over the solder posts to prevent the esc from over heating.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-16-2009, 07:38 AM   #2504
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
just picked up an RS yesterday, forgot to buy that tuner box. have to get that this wk.
gearing/programming suggestions for 10.5 2wd bug. thx
R
UltegraSTI is offline   Reply With Quote
Old 02-16-2009, 08:14 AM   #2505
Trader Rating: 76 (100%+)
R
You have a pm.
MUDVAYNE is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
