Old 02-13-2009, 11:43 PM   #2476
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by YmeBP View Post
That avatar is great hahahaha.
Even better. LOCATION: "Mount Holly" North Carolina
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-14-2009, 12:48 AM   #2477
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by CouldbeFaster View Post
Hi guys..
When you refer to red or Green power bands what are you refering too? (still waiting my RS, should come this weekend) Maybe it will be clear then!
I race TC Rubber 10.5... Would you guys say the 0 degree full boost is the place to start? or if anyone has a screen shot of a setup that I could start with that would be great...
Cheers
Sorry for starting that up here... it's actually an old joke from back in my Motocross days... The term "powerband" simply refers to the range of rpm where the motor is making good power and torque. Below this rpm range, the motor would feel "boggy" and above this rpm range, the motor would feel "flat". Motocross engines back then were ALL two stroke engines. Two stroke engines typically had a lot of pwoer, but a very narrow RPM range where the power was usable, or less power, but a wider, more "driveable" RPM range where the pwoer was usable. Reviewers always spoke about the wide or narrow powerband of a particular engine. Some guys would get it in their head that the "power bands" were actual parts on the engine... and thus the jokes began. I used to work as a mechanic in a bike shop, and actually had a guy bring me his disassembled engine in a cardboard box asking me where the powerband was once... Another of our regular customers had convinced himself that the piston rings were the "power bands" and every time he needed new rings he came in and asked for them as "power bands". THe boss thought it was so funny he wouldn't let any of us correct the guy...
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-14-2009, 04:59 PM   #2478
One question. Do you use on long outdoor tracks more Boost and timing on the motor or is it than still better to use boost 30 and timing on the motor on 0?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-14-2009, 07:03 PM   #2479
Default rs pro
Originally Posted by SPC Racer View Post
how come i cant get my rs calibrated? ill hold the mode button for three sec. and leave the trans. at neutral until it beeps then ill hold it full throttle and wait for it to beep but nothing after several sec.?
I have a fairly new 3pks and had to reverse throttle to make motor run correct.
Any Ideas as to why this is on the rs pro and did not happen with other ESC'S?
thanks
epa's at 100
va.racer is offline   Reply With Quote
Old 02-14-2009, 07:16 PM   #2480
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
thanks
epa's at 100
Yes this is normal with the Tekin and Futaba radios!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-14-2009, 07:53 PM   #2481
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by tomdav View Post
So this means with the boost set at 12 and the physical timing on the motor set to 12 we get to 24 degrees of timing?
I want to know where to set my timing on the endbell.
I cant wait to add the RX8 to my two RS pros. Great stuff guys keep it up.
i think randy means 24 on the motor plus 12 boost for a total of 36 degrees
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-14-2009, 08:14 PM   #2482
Vicko's Avatar
Trader Rating: 14 (100%+)
so with 189 is there any timing if the timing boost set to 0
I was told there was some timing aready with the 189 sofewear
Vicko is offline   Reply With Quote
Old 02-14-2009, 08:59 PM   #2483
avs
avs's Avatar
Originally Posted by Randy_Pike View Post
Here's a great setup for 10.5 and 13.5 Racing. This is Team driver Jason Moberly's RS setup!
Randy,
could you post a 17.5 setup too? i have read the last 20 pages of this thread multiple times and am getting more confused not less.
my preferred application would 1/12 if that matters.
also just to clarify what the current tuning priorities are with 1.89 firmware:
1) get minimum lap times by adjusting rollout and 'boost' with 0 (or minimum) physical timing on the motor, without overheating the can.
2) adjust all other parameters for personal taste.
does this sum up the situation? or is there other concerns?
thanks in advance for the help.
avs is offline   Reply With Quote
Old 02-15-2009, 01:11 AM   #2484
stiltskin's Avatar
I ordered an RS/17.5 combo from Stormer. What is the length of the sensor wire that comes with the RS and is there any benefit to a shorter wire besides mounting? Thanks.
Tony Rumple
Old 02-15-2009, 01:37 AM   #2485
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Ty, YGPM.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-15-2009, 04:02 AM   #2486
Yes about 15 degrees.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-15-2009, 04:05 AM   #2487
E-clip's Avatar
Trader Rating: 39 (100%+)
Default rs pro & 17.5 combo
Hi does anyone know of any shops that have the rs pro & 17.5 combo in stock??
E-clip is offline   Reply With Quote
Old 02-15-2009, 04:07 AM   #2488
A Ilievski's Avatar
Feral Batteries in Australia should have them in
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 02-15-2009, 04:16 AM   #2489
cannon's Avatar
Trader Rating: 35 (100%+)
Thanks Alex. Yes they arrive tomorrow
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 02-15-2009, 04:52 AM   #2490
okayplayer
Guest
Posts: n/a
Hi,
Why everyone is running 17.5 or like with T2 or TC5 onroad rubber?
this is weird ... I was planning to run a tekin 6.5T ... do you play with the spur .. pinion to have top speeds ...?
where can i find something that I could read to understand that?
CÚdric
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
