Old 02-11-2009, 05:27 AM   #2416
Originally Posted by Randy_Pike View Post
Would you have it any other way!?
Randy i now that it only gets better every time i got an update so i can't wait till the new update is there.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-11-2009, 08:10 AM   #2417
miller tyme's Avatar
Originally Posted by SPC Racer View Post
how come i cant get my rs calibrated? ill hold the mode button for three sec. and leave the trans. at neutral until it beeps then ill hold it full throttle and wait for it to beep but nothing after several sec.?
Originally Posted by TRF415boy View Post
Bet you're using a futaba radio. Try setting the throttle direction into reverse.
Also your throttle Endpoints MUST be set at 100 both forward and brake.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 02-11-2009, 08:14 AM   #2418
yes and also try to bracke if notting beeps. as it works than you must reverse your throttle.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-11-2009, 09:55 AM   #2419
Team Tekin
TY@TEAMTEKIN's Avatar
Originally Posted by Trips View Post
Best bet, take the powerbands out of the Trinity and put em in the Tekin. They fit right in. (sorry... old motocross joke, couldn't help myself)
The red powerbands give you the best response
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 02-11-2009, 10:19 AM   #2420
bsmooth's Avatar
Trader Rating: 17 (100%+)
Could anybody point me to an article or website that can explain motor timing?
Here's my situation. I have a Tekin RS speedo and Redline 17.5. I had been running it a 1/12 (4 cell car). The motor timing had been adjusted by a fellow tekin driver, so I did not know, nor did I mess with it. I went ahead and adjusted the timing via the boost mode in the software. Usually I had it cranked up and geared accordingly with no heat issues.
Fast forward- I put all my electronics into a 1/10 WGT pan car running 7.4 lipo. I didn't mess with anything except gearing. Made a few runs, temp was good, so i cranked up the boost (software). I ended up torching my 17.5 (off track at about 225 deg-F). Found out later that the combination of motor timing and boost timing was way too much.
So to be more specific with the question: I assumed that I could crank up the timing and then gear accordingly, and it should give me the most power right? Evidently that's not how it works. I'm learning that there is a fine line with this timing stuff, therefore I need to find a write up somewhere on exactly how to use motor/software timing.
Thanks again for any help.
Steve
bsmooth is offline   Reply With Quote
Old 02-11-2009, 10:24 AM   #2421
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
SPC: Flip your throttle to reverse. I always recomend the epa's be set equal to each other ie, 140 and 140 or 100 and 100.
Steve, you found out the hard way. Sorry to hear that. Timing has sweet spots for each combination. For WGT a lot of our team guys were running 0 motor timing and full boost at the birds. This setup renders 30 degrees of timing total. Not a bad place to be with a 17.5.
You don't usually want to be over 40 degrees EVER between motor timing and boost. This is where you will see too much heat and no performance gain at all.
Try the above "birds" setup. I'm sure you will like it.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-11-2009, 10:43 AM   #2422
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default 13.5
Randy were they running 13.5 in the gt class at birds so is what im asking would you run the same settings for 13.5 thanks
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 02-11-2009, 10:55 AM   #2423
When I got home from the birds I tried that same setup on my 13.5 and it has worked very well
Old 02-11-2009, 11:01 AM   #2424
2056dennis's Avatar
Default 13.5
ok are you running it in a gt car or 12th scale thanks
Old 02-11-2009, 11:02 AM   #2425
Steve
Every one's still learning about what the different timing settings do so there's no real place to find a good explanation yet.
I am finding that the voltage that you're running has a big effect on the timing needed. You can't normally use the same settings for different voltage packs with the same motor. Less voltage seems to like more timing and more voltage seems to like less timing.
I run full motor timing and full boost with single cell LiPo and you just can't do that with 4 cell or 2 cell LiPo.
Fred_B is offline   Reply With Quote
Old 02-11-2009, 11:49 AM   #2426
Team Tekin
Tekin Prez's Avatar
That should NOT be good. That is 50deg at least of outside timing.... add the timing built into the construction and you are way over 60deg total. 60deg is a physical limit because we commutate every 60deg in a 2 pole 3 slot motor. You are no longer just advanced timing, you are completely in the wrong phase and no load currents are off the chart.
The rule of 30 to 40 max total timing, boost plus motor timing, is still valid.
We are doing a lot of 1S testing on our track right now. Actually a kick to race our 2S 17.5 setups in TC with a 1S and not other changes except adding a receiver pack. Dog slow and tight wheel to wheel racing that makes you roll the corners smoothly. A real beginner stock speed. I will check this extreme setup, but working or not I doubt it is the best or a good idea. However I bet the no load wheel speed in the pits is screamin... ala spx. I am so curious now I guess I head to the scope and take a look.
Tekin Prez is offline   Reply With Quote
Old 02-11-2009, 12:08 PM   #2427
yodace's Avatar
R/C Tech Charter Subscriber
Was wondering what a good profile for 13.5 in my Tc5r? currently have a 66 tooth spur on it right now and i think a 34 tooth pinion. Will be racing on asphalt this summer. track size is 100X75 i think not for sure>
yodace is offline   Reply With Quote
Old 02-11-2009, 01:03 PM   #2428
Team Tekin
Randy_Pike's Avatar
Yodace,
Try the 0 motor timing full boost. Find the right gearing by either asking a few locals or testing and checking motor temps.
Old 02-11-2009, 01:38 PM   #2429
1/12th
Old 02-11-2009, 01:53 PM   #2430
2056dennis's Avatar
Default ok
1/12th
ok thanks im going to run the 13.5 in my gt car that is why i asked
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
