Old 04-23-2014, 04:57 PM   #23341
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by YoDog View Post
If memory serves me correctly, this subject came up before.
Does depressing one or both of the buttons on top of the ESC cause the same symptoms?
If so, the internals of one or both of these switches may be actuating under the hard chassis slap. Use thicker servo tape (double up on what you normally use) to see if the issue goes away.
Anytime the buttons get pressed it can do something, at least in the right configuration. However he's stated nothing is near them. So I'm thinking it's browning out on impact.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-23-2014, 08:18 PM   #23342
Originally Posted by JourneyMan View Post
Randy, it's a DX3R/Savox setup with a Novak cap plugged into the receiver.
Have two others with the same setup. Happens when I case a large double or triple. Any hard landing, where I bottom out.
Replace the switch, i have had this happen. I replaced two tekin switches. Then bought an lrp. Now i solder the switch wire together.
capt waffles
sobiski racer is offline   Reply With Quote
Old 04-24-2014, 10:24 AM   #23343
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Randy_Pike View Post
Ok,
Do me a favor and please on the bench car on wiggle the steering and watch the receiver led. Does it flicker at all? If so unplug the cap, retest. Worse or better?
Okay, got home and powered her on. Went crazy on throttle on steering, rapid movements on the steering and the amber light on the savox stayed solid the entire time. ESC is in blinky. Did not remember to play around with the buttons. Any other thoughts?
Thanks to - Jconcepts | Team Trinity/Revtech | Kal-gard
JourneyMan is offline   Reply With Quote
Old 04-24-2014, 10:35 AM   #23344
Team Tekin
Randy_Pike's Avatar
You're referring to the light on the receiver right? Not the servo?
If you are the next step is to note all your settings, then do a factory reset on the unit. Plug your settings back in and re test.
Can you post a picture of your car so we can see the wire routing,etc?
Old 04-24-2014, 11:36 AM   #23345
YoDog's Avatar
Trader Rating: 26 (100%+)
Hi Randy, understood but even though nothing is hitting the buttons, they are tactile dome switches and can sometimes short through harsh vibration. That's the reasoning behind my suggestion. Bypassing the power switch might be a reasonable test as well.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 05-08-2014, 07:13 AM   #23346
mazmo's Avatar
Hi all.
Looking for recommended FDR and motor timing for 13.5 blinky on 13.5 Tekin Gen 2 RPM version. I race TC on small asphalt track.
Lap times bout 13.0 seconds and straight bout 25 metres.
Thanks in advance
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 05-08-2014, 07:13 AM   #23347
mazmo's Avatar
Hi all.
Thanks in advance
Old 05-15-2014, 12:38 PM   #23348
witz_dan's Avatar
Trader Rating: 25 (100%+)
Tekin RS Gen 1
cuts out power when I case jumps, but a few seconds later, after rolling off the jump it comes back to life. Settings not being changed by wires making a button push.
Is this a common issue, or a bad cap, sensor board/wire, etc?
Just wondering if you ever resolved this. I am having the same issue. Have changed the sensor wire and the power cap. Seem to recall this happening to me a few years ago with another RS. I ended up sending it in and paying for the none warranty replacement. With the Gen 2 out, is this a option with a Gen 1? are we able to send them in and pay to have them replaced with a Gen 2?
Xray T3 Stock TC
Xray T3 VTA
FT SC10
B5m
DEX410 Spec
witz_dan is offline   Reply With Quote
Old 05-15-2014, 04:25 PM   #23349
I seem to remember this issue coming up a year or more ago. One suggestion was to mount the ESC on it's side. The theory being that in a hard landing, the impact presses the 'set' button, causing it to shut off for a few seconds while it waits for the user to press more buttons.
Kevin Marcy is offline   Reply With Quote
Old 05-15-2014, 04:31 PM   #23350
Team Tekin
Tekin Prez's Avatar
The newest software posted on the website takes care of this issue. Update your unit to version 250 and you should not ever see impact button pushes.
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 05-16-2014, 08:14 AM   #23351
bluer322's Avatar
Hi i'm new to electric, I'v been running on-road nitro for about 20+ years. I have a tekin Rs and I want to run mod at a local track. I was going to pickup a 4.0 or 4.5 winding motor will that ESE (Rs) be able to withstand that and do I need a fan.
Last maybe some can point me in the right direction. I'm running Xray T3 how can I find out what gearing to run. Med size track not technical at all.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 05-16-2014, 08:40 AM   #23352
slakr's Avatar
Trader Rating: 31 (100%+)
The Tekin RS will not handle a 4.0-4.5 turn motor.
From the Tekin website: Motor Limit Brushless Mode 2S: 8.5 Turn 2-pole 36mm Can
http://www.teamtekin.com/rs.html
You will need a Tekin RSX
From the Tekin website: Motor Limit Brushless Mode 2S: 2.5 Turn 2-pole 36mm Can
http://www.teamtekin.com/rsx.html
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 05-16-2014, 08:53 AM   #23353
bluer322's Avatar
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 05-16-2014, 08:56 AM   #23354
bluer322's Avatar
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 05-22-2014, 01:04 AM   #23355
Frank Hodits's Avatar
I have an older RS gen1, original hotwire, and original redline 13.5 (all of this was purchased new in the begining of 2010). What is the newest hotwire/vegas version i can use?
Also, what was the stock endbell timing that came on my motor when new? It looks like it's adjustable from 0-24 degrees.
https://www.facebook.com/midwestrc/
Frank Hodits is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
