Old 04-03-2014, 01:15 PM   #23326
Satish's Avatar
Originally Posted by rick oxley View Post
can anyone please give me a starting setup for a rs speedo/10.5gen2 motor
boosted in a touring car.for indoor carpet track,lap times around 12-14 sec
depending on layout. new to tekin products so any help would be great.
thanks rick..
I'd be interested in this one too.
Anybody????
Satish is offline   Reply With Quote
Old 04-04-2014, 11:46 AM   #23327
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by rcwck View Post
Randy,
Is it possible to install any type temp sensor so you can monitor motor temps in the data logger? None of my motors contain a temp sensor. I just purchased your new rsx and a data log for motor temps would be useful for mod sedan. Sorry it this topic has been covered.
It may be possible but I'd likely not attempt it.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-04-2014, 11:48 AM   #23328
Team Tekin
Randy_Pike's Avatar
thanks rick..
There are a lot them here to look at http://www.teamtekin.com/hotwire/esc...up-sheets.html
That's fast lap so your gearing will likely be much different. Hara's 11.5 setup was on a huge outdoor track.
Old 04-04-2014, 12:06 PM   #23329
all the setups i've seen vary so much,been new to tekin
i just wanted a safe starting point. carn't see anything for
10.5 touring car on that link.
thanks rick..
rick oxley is offline   Reply With Quote
Old 04-05-2014, 04:36 AM   #23330
rcwck's Avatar
thanks rick..
10.5 boosted is not very common for sedan carpet racing. The safest method is not to use boost or turbo. Tune with can timing and gearing. You can add turbo and boost later if needed. I would just throw some turbo at it if needed. Good fans and temps are important.
Wondering about a 14 second lap times with that type power available. That must be a very large and/or very technical carpet track. We race on a 82' x 36' Ozite rug and fast lap times for 17.5 blinky is always sub 10 seconds on several different layouts.
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
Old 04-06-2014, 01:48 PM   #23331
Suspended
Trader Rating: 4 (75%+)
how do I set reverse n tekin rs gen 2 ?
tryandfok is offline   Reply With Quote
Old 04-06-2014, 06:57 PM   #23332
rcwck's Avatar
Using the Hotwire for the ESC there's a check box to reverse motor direction.
"Team Medicare"
Old 04-06-2014, 07:13 PM   #23333
Suspended
I mean reverse of the rc car if I m stuck against the wall
Old 04-07-2014, 05:03 AM   #23334
rcwck's Avatar
That's very easy with the Hotwire.
Or by onboard tuning here:
http://www.teamtekin.com/manuals/RSG2_Manual.pdf
"Team Medicare"
Old 04-07-2014, 05:26 PM   #23335
Jsaves's Avatar
Default 1s esc?
I have not heard about a 1s esc for a while, is there still going to be one built or did I miss something?
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 04-23-2014, 10:14 AM   #23336
JourneyMan's Avatar
Trader Rating: 91 (100%+)
Tekin RS Gen 1
cuts out power when I case jumps, but a few seconds later, after rolling off the jump it comes back to life. Settings not being changed by wires making a button push.
Is this a common issue, or a bad cap, sensor board/wire, etc?
Thanks to - Jconcepts | Team Trinity/Revtech | Kal-gard
JourneyMan is offline   Reply With Quote
Old 04-23-2014, 12:35 PM   #23337
Team Tekin
Randy_Pike's Avatar
Originally Posted by JourneyMan View Post
Tekin RS Gen 1
What radio system and servo?
Old 04-23-2014, 01:41 PM   #23338
JourneyMan's Avatar
Randy, it's a DX3R/Savox setup with a Novak cap plugged into the receiver.
Have two others with the same setup. Happens when I case a large double or triple. Any hard landing, where I bottom out.
Old 04-23-2014, 02:04 PM   #23339
Team Tekin
Randy_Pike's Avatar
Ok,
Do me a favor and please on the bench car on wiggle the steering and watch the receiver led. Does it flicker at all? If so unplug the cap, retest. Worse or better?
Old 04-23-2014, 02:06 PM   #23340
YoDog's Avatar
Trader Rating: 26 (100%+)
If memory serves me correctly, this subject came up before.
Does depressing one or both of the buttons on top of the ESC cause the same symptoms?
If so, the internals of one or both of these switches may be actuating under the hard chassis slap. Use thicker servo tape (double up on what you normally use) to see if the issue goes away.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
