Old 09-20-2013, 02:29 PM   #23266
Trader Rating: 60 (100%+)
As long as there is absolutely zero way to change timing, there should be no reason it doesn't get approved.
PROMODVETTE is offline   Reply With Quote
Old 09-21-2013, 12:19 PM   #23267
J-milz's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Randy_Pike View Post
I'm sure we'll send them something to test once they're available to the public. Note that it is ROAR VTA compliant. It may take a few of you guys to pressure them into getting the RS Spec approved.
So when does it hit the streets? What the the actual price projected to be?
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 10-06-2013, 05:04 PM   #23268
J-milz's Avatar
Any word? I'm looking to get rid of my current VTA ESC. I THINK AS SOON AS I buy another brand the new SPEC ESC will be added. 🍀Just my luck.
Old 10-06-2013, 09:15 PM   #23269
jasons56's Avatar
I have two Tekin RS speed controls that I have used in just about every class of spec racing. They have been one of the best values in RC.
When software timing was popular, they were absolutely dominant.
However, I have moved to mod and I am a little fearful that my great little RS may just not be up to it.
I am running 8.5 Novak Ballistics in a Buggy and a Truck. Speed control temps are ok.
However, I seem to get a little lag in the throttle that is making some of the more technical layouts a little tricky.
I have tried blinky mode, dual timing mode, and some modes with mild boost.
Right now I have a 22t that alternates between stock and mod depending on turnout.
I ran mod this weekend. I left it in blinky. It seemed to have an especially laggy feel, almost like it had a ton of expo in it.
I have ran into this before. Is my speedo perhaps past it's prime? Or maybe not reading the sensor correctly?
Should I step up to a Pro or Gen 2? Would that get me back the punch I seem to be missing?
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 10-06-2013, 10:05 PM   #23270
Krio's Avatar
Trader Rating: 150 (99%+)
There are several things it could be, but you should be fine using the RS as you mentioned in mod with no adverse throttle effects. First, what is your current limiter setting, then I'd check the leds to make sure the sensors are reading properly, then I'd look at the timing on the motor, and for good measure I'd check how old/worn out your packs are.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 12-12-2013, 09:29 AM   #23271
Any good ideas how to clean up the posts?
I got the ESC used and they are all covered up with solder and ugly lol.
jaank is offline   Reply With Quote
Old 12-12-2013, 09:48 AM   #23272
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
No, esc's don't get slower with age. There are no "wear" components in them.
Are you running the 223 software? If so increase your "Min throttle" setting a bit and turn off your current limiter if you have it on.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-12-2013, 09:48 AM   #23273
Team Tekin
Randy_Pike's Avatar
Pick up some of this: Solder Braid
Old 12-12-2013, 10:44 AM   #23274
YoDog's Avatar
Trader Rating: 26 (100%+)
You can also heat each post one by one and quickly wipe each one with a slightly damp sponge. Only do one at a time... Your Iron needs to be of decent wattage as well or it will take too long to heat the posts thus possibly de-soldering them from the PCB. Solder wick is good but it all depends on how much solder you wish to remove. they also leave a coating of rosin behind that can be both good and bad.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-12-2013, 08:57 PM   #23275
rc car guy's Avatar
so is there anything special i can do to my tekin i think its an rs or an rs pro in blinky to make it faster than it currently is in blinky mode? i messed with the throttle profile so that is at 5 and no current limit its for 17.5 tc blink
rc car guy is offline   Reply With Quote
Old 12-13-2013, 06:52 AM   #23276
Increase the motor's timing. Find your optimal gear ratio. And most importantly, don't hit anything.
AreCee is offline   Reply With Quote
Old 12-13-2013, 09:58 AM   #23277
rc car guy's Avatar
Ive done the gearing and timing and hitting the wall im working on just got to pull my head out of my vutt n drive
Old 12-13-2013, 10:00 AM   #23278
speedybill's Avatar
Trader Rating: 73 (100%+)
Wink
TP-5 [Throttle profile 5] is NOT Blinky!! it gives the motor 45* of timing!!!
Look here & see what is what
http://www.teamtekin.com/hotwire_RS.html
There should be a "Locked Spec Mode" ie: TP-1 =no timing
hope this helps
ROAR member #5-120259
www.speedybillsrc.com
www.ovrccc.com
Sweep Racing Tires
speedybill is offline   Reply With Quote
Old 12-13-2013, 10:11 AM   #23279
rc car guy's Avatar
It is in locked spec mode ... its only in 4 at the moment why would tekin put a setting in the locked spec mode that made it illegal you missread it or didnt read enough it says yiming profile not throttle profile throttle profile changes hiw aggressively the throttle response is
Old 12-13-2013, 10:33 AM   #23280
speedybill's Avatar
Quote from Tekins "Hotwire" setup
Timing Profile: This slider contains 5 preset Timing Profiles for your ESC. Setting any of the 5 preset profiles will automatically put your ESC into Sensored Only mode. Profiles 1-5 are as such:
TP1: Spec Stock "blink mode" 0*timing boost
TP2: 15* Timing Boost / RPM Range 5443-20,016
TP3: 25* Timing Boost / RPM Range 5443-20,016
TP4: 35* Timing Boost / RPM Range 5443-20,016
TP5: 45* Timing Boost / RPM Range 5443-20,016
*RPM Ranges are divided in half when running in 1S LiPO Mode*
www.ovrccc.com
Sweep Racing Tires
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
