Old 07-09-2013, 01:05 AM   #23251
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by outlandr91 View Post
I use an RS for 17.5 blinky and it still has version 212 software. I was on Tekin's site but didn't see where to get the newest version.Is it still possible to upgrade the old RS? Would it be worth it?
According to the release notes here: http://www.teamtekin.com/hotwire.html, the latest version includes 223 for the RS and RS Pro, so you should be fine with downloading that one (http://www.teamtekin.com/download/TekinHotWire.zip)
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 07-09-2013, 07:57 PM   #23252
Thanks a lot!
Phil.
Sponsored by mooby 64
outlandr91 is offline   Reply With Quote
Old 07-18-2013, 05:20 AM   #23253
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default Tekin RS setup for 13.5t open timing with tekin redline motor
Hi Guys,
New to Tekin product, looking for a setup for 13.5t open timing for a Touring Car.
Low Traction Track, smaller version of the Mach Heemstede track, main straight about 65m long.
Any Help with be good
Jamie
New Zealand
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 07-18-2013, 06:05 AM   #23254
Bishop's Avatar
Is the RS Pro specifically known for bottom end power/punch in relation to anything?
I ask because until recently I was using a 45amp HW Justock, which was doing just fine till other people starting going faster, and I seemed lacking in bottom end to mid range power, it seemed I could match anyone for speed, just not in getting up there quick enough.
There was part of me thinking it could not be the ESC, yet I messed with batteries etc, could not find any of that low end, till a friend lent me a RS Pro, and with a quick test, even with older packs it will out rip the Justock.
Maybe it's just still a bit of Newbie in me with electric, but it caught me by surprise.
I'll find out if it actually makes me any quicker tomorrow night (10.5T blinky), but either way it left me confused by how maybe the ESC's work in relation to amp draw, more so when all in blinky mode?
Secondary subject, I just used the two cap board off the HW on the Tekin, ok to do so?, and any throttle profile setting tips, or likewise how tight should I be setting the neutral band?, in default I though the neutral band felt very large.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 07-23-2013, 10:28 AM   #23255
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Quite a few esc's reduce power to control amp draw. We do not. Our esc's can run full open and this can be felt on the track compared to an esc that doesn't, as you've found.
The double cap is fine.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-23-2013, 11:21 AM   #23256
Bishop's Avatar
Thank you Randy for the response, good to know, I thought there must be a reason I and a friend have found it just punches so hard in stock racing.
While I remember, does anyone have a good sort of starting recommendation for a mod setup?, it's looking like I'll be using a 5T Nosram Pure 1 or Pure 2, and I am not sure if I should use the full sensored mode, or duel mode, and where to start with it, there seems to not be a lot of setups around anymore for mod with the Tekin?
If it helps, this is the track I'll be running at, first time in mod for me as well...
http://www.youtube.com/watch?v=NS6vXa6cnLk
QRCCRA
www.qrccra.org.au
Old 07-23-2013, 12:40 PM   #23257
Team Tekin
Randy_Pike's Avatar
Start here but geared for that layout: http://www.teamtekin.com/hotwire/ESC...h_M&M_v223.pdf
Old 07-24-2013, 01:12 AM   #23258
noyz's Avatar
I have not used my hot wire on my home computer in some time, but when i connected it , it was version 212. I then un-installed and downloaded the zip of 9.6. After connecting to the hotwire, things are still 212. The ESC unplugged from the hotwire does not show the software update box, only data logs. I followed the utube help video, but I don't have an app data, or virtual store option. My Rs, and Rs-pro had version 223 installed by a fellow racer at the track. I updated the esc in hotwire thinking that would help, only to realize they both were reset to 212. Now I'm a little lost, and have tried to find all tekin files, remove them from my drive, and have done an uninstall-download-reinstall, empty recycle bin, restart 4-5 times... I'm not sure what I'm missing. I have Vista on my HP laptop
Broke vintage Losi touring car wanna be racer.
noyz is offline   Reply With Quote
Old 07-24-2013, 02:17 AM   #23259
there was a problem uninstalling it on windows vista pcs.
there is a link in the tekin site to fix it...
now, where was it..
ed
Edwin Pibal is offline   Reply With Quote
Old 07-24-2013, 02:19 AM   #23260
here it is
http://www.youtube.com/watch?v=tTp3tUL9u8Y
ed
Old 07-24-2013, 10:39 PM   #23261
noyz's Avatar
bada bing! thanks
Old 08-25-2013, 04:07 PM   #23262
KyLayfield's Avatar
Trader Rating: 86 (99%+)
I'm replacing the receiver lead on my RS and do not remember polarity sequence. Can anyone tell me if the sequence matches the switch lead or is it reversed? I don't want to assume that it does and release the smoke.
KyLayfield is offline   Reply With Quote
Old 08-26-2013, 11:56 AM   #23263
Team Tekin
Randy_Pike's Avatar
White, Red, Black left to right.
Old 09-20-2013, 07:48 AM   #23264
J-milz's Avatar
Trader Rating: 38 (100%+)
Default Tekin rs spec
Hey Randy, I'm lookin at the RS Spec on the net and was wondering if there any plans to submit it, to make it VTA legal?
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 09-20-2013, 11:59 AM   #23265
Team Tekin
Randy_Pike's Avatar
I'm sure we'll send them something to test once they're available to the public. Note that it is ROAR VTA compliant. It may take a few of you guys to pressure them into getting the RS Spec approved.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
