Old 06-13-2013, 11:38 PM   #23236
Geezatec's Avatar
Originally Posted by rramjet View Post
OK I've searched this thread and can't find anything describing my issue. I put an RS in my Tamiya Mini,, (brushed Silver Can motor) I know, overkill, but I wasn't using it anywhere else and it's not as bulky or heavy as the stock one. It's wired for Fwd and Brake only. I can't get it to calibrate to my DX3R. When it powers up the last 3 leds are blinking, (signal too high I think). When I push the Mode button for 3 seconds led #1 blinks for a while, no chime and then it looks like it reboots, (1st middle and end leds flash), then the last three start blinking again. Tried different receivers, switchng to the Steering port, reversing the throttle, playing with throttle EPA all without sucess. The only way I can get it to work is to power it up and move the throttle till there are no leds. It seems to reboot then it will run. I have set EPA at 150 to get full thottle. Also have to crank in about -32 throttle trim to keep it from running on it's own. Goes like hell.
I use my DX3R with S3100 receivers on three other cars, (all brushless), including one with a Tekin Pro without problems.
Now that I know how to get it started I guess I can live with it but really curious to know what might be going on.
last 3 leds are blinking, Calibration of TX and RX is off. Redo the calibration.
Geezatec is offline   Reply With Quote
Old 06-14-2013, 10:26 AM   #23237
rramjet's Avatar
Location: Everett WA in the Summer Mesa AZ in the Winter
Thanks. I've redone it many times with the same result. The RX/TX combination works fine with the original Tamiya ESC.
It definitly acts like calibration is off but I'm starting to believe it's something in the Tekin caibration circuitry.
Think I'll give them a call and see what they say.
rramjet is offline   Reply With Quote
Old 06-14-2013, 10:55 AM   #23238
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
What radio is this? Make sure your epa's are set to 100/100 and if it's a Futaba reverse the throttle channel before calibrating.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-14-2013, 11:49 AM   #23239
rramjet's Avatar
Thanks Randy. A phone call straightened me out. I feel a little stupid. I was pushing the Mode button for 3 seconds like the instructions state NOT holding it until the chime sounded.
Guess I'm just too literal.
Old 06-14-2013, 11:57 AM   #23240
YoDog's Avatar
Trader Rating: 26 (100%+)
OK, if there is no chime, the ESC is not calibrating. You can then reverse the Throttle channel on your transmitter and then try to recalibrate again. I have always held the mode button while turning on the power switch. May be an old habit... but it seems to work for me. If the ESC does not see a normal signal at neutral, it will not calibrate. Make sure your trim and sub-trim are zeroed and that the EPA is set to 100. The key is that the neutral position needs to be in the proper range to be recognized. The problem could also be that the neutral range in the ESC settings are too narrow or too wide thus causing it not to see a proper neutral signal.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 06-14-2013, 04:21 PM   #23241
Geezatec's Avatar
Press Mode Button for approximately 3 sec. RS will start chimming 2 tone per sec, Then doubles in tone, it sets neutral position. Then it'll chime 2 per sec squeeze trigger to full throttle the hold, till it doubles chime. 2 time per sec push trigger to full brake until chime double. Let trigger back to neutral the RS will set itself. Your end point adjustment(EPA) should be at 100% with all electronic RC.
Good luck!!! Once Calibration are set, the rest are easy.
Old 06-14-2013, 05:38 PM   #23242
rramjet's Avatar
Thanks everyone. All is good once I realized I needed to hold the mode button till it chimed. I was just pressing it for 3 seconds and letting go. Wonder how I ever got my RS Pro going. Must have been awake then.
Old 06-28-2013, 05:36 AM   #23243
just fitted the new rs gen2 in my MI5, I run a lrp x12/ 13.5 on carpet (high grip) track is 80' x 48' I run 7.29 fdr but have lost all my old settings for the rs, I noticed the leaflet that came with the gen 2 says dial back 25 degrees of timing ? any thoughts
nmsraider is offline   Reply With Quote
Old 07-03-2013, 05:21 PM   #23244
Jsaves's Avatar
Does the RS and Viper motors work good together? It says that the Viper motors work with most escs.
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 07-04-2013, 07:44 AM   #23245
pk4
Can someone pls help me out.... I have a RS Pro ESC along with Nosram 13.5 sensored motor and with Spektrum DX3R with SR3000 Rx. Lights 1-2 and 6-7 lights up after calibration and even with setting the ESC back to default. Do i really have to use the Tekin Hotwire to set the type of motor as the manual says? Thing is I don't have a Hotwire with me. Can anything be done without using the Hotwire?
pk4 is offline   Reply With Quote
Old 07-04-2013, 08:36 AM   #23246
Robby368's Avatar
Trader Rating: 14 (100%+)
Unfortunately bro, this means internal circuitry failure. Most common cause is from hooking up a battery backwards. The only repair is to send it back to tekin.
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Old 07-04-2013, 09:02 AM   #23247
Geezatec's Avatar
Everything could be adjusted w/o the Hotwire. Hotwire good when you're adjusting Turbo or boost.
Go into Pit Mode, Adjustment Mode or Blinky Mode. Adjustment Mode LED6, set the LED to #1(FWD/BK). Let ESC to chime. Believe you may Calibrate your Before setting to Blinky Mode.
Hotwire opens up files that the Blinky mode doesn't, Turbo and boost. Learn about RS Blinky mode first then the Hotwire. Its easier the way.
Old 07-04-2013, 10:34 AM   #23248
pk4
I did this method but still 1-2 & 6-7 lights up. Prior to this problem, everything works well. And reverse polarity upon connecting to a battery didn't happen. Anymore suggestions?
Old 07-04-2013, 11:14 AM   #23249
Robby368's Avatar
According to Tekin's Troubleshooting Page, the esc does not recognize the motor. It could be set to brushed in the esc when a brushless motor is connected. If the esc is set to brushless, then it's possible to have a defective sensor board on the motor. Make sure the esc is set to the right motor (brushed or brushless), if it is, then try wiring up another motor that you know for sure works.
Old 07-08-2013, 07:55 PM   #23250
I use an RS for 17.5 blinky and it still has version 212 software. I was on Tekin's site but didn't see where to get the newest version.Is it still possible to upgrade the old RS? Would it be worth it?
Sponsored by mooby 64
outlandr91 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
