Old 02-03-2009, 11:24 AM   #2311
The Birds was wild! I went there with my RS and finally got to play around with the 189 software. Very cool stuff. What was wild to see was how people react once they start hearing one setup is faster then another. Seems like there was a run on Tekin RS's at the hobby shop as people were snatching them up as fast as they could once the hot setup was know. Apparently setting the motor to near 0 timing and maxing out the ESC timing with the 189 software was worth some time on the track. I ran that pretty early on and my car was much better. Again great stuff Tekin!
Old 02-03-2009, 12:49 PM   #2312
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by ChristopherKee View Post
I'm pretty sure the Duo timing holes are 0-10-20.
Yes that is what some of the "Labels" say, but I believe the can has 10-12 Plus what you get by moving. I'll see if I can get this confirmed.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 02-03-2009, 01:21 PM   #2313
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I agree. I ran 189 max boost no timing in the motor in 17.5 and 13.5 at the US Indoorchamps and it was rocket!
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 02-03-2009, 01:38 PM   #2314
HarryN's Avatar
Send a message via AIM to HarryN
Originally Posted by Randy_Pike View Post
Yes our drivers had a great Snowbirds! Stay posted to the updates on our site for more indepth's look at RS setups for each driver!
Hey Randy,
Quick question, does it matter what gear ratio you run with this setup? I am guessing it does, but I wanted to make sure. I am anxious to try this out on my redline motor.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 02-03-2009, 02:40 PM   #2315
I agree with Fred. I'd want to see the car on the track. If you want more top end you need more gear or more timing.
You're boosting pretty high now. Try this setup next time you're there.
Run the motor straight ut 0, boost at 30 same gearing. Running that setup offers great infield and out of the corner torque. Then the high boost timing get's you good top end rpms....
Hi Randy,
As the motor has already a timing of 12 and you cant change it, is it than better to put the boost on 18?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-03-2009, 05:59 PM   #2316
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mikky32 View Post
Hi Randy,
I think you';re making it more complex than it needs to be... just turn the endbell down as far as it goes, max the boost, then start short on the gear and sneak up a tooth at a time for best lap times. Always keeping an eye out for temperature, of course.
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-03-2009, 06:06 PM   #2317
OK, I'll try that.
stocker is offline   Reply With Quote
Old 02-03-2009, 06:11 PM   #2318
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Most motors can go down to 0. However since I don't have a duo in my hand I can't say for sure.
For the 0 motor timing full boost setup, yes gearing will most likely change a bit but not drastically. As always check laptimes, feel, and motor temps above all.
I would just also like to say thank you and Congratulations to our entire team for such a great effort they put into the Snowbirds Race.
Special thanks to Jeff Cuffs for stepping up big time and taking care of a lot more drivers than any single guy should while racing!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-03-2009, 06:24 PM   #2319
Dragula426's Avatar
-Wayne
Just curious, anyone know why its quicker set-up that way? I am gonna try it this week, but just curious why it would be so mutch quicker.
Dragula426 is offline   Reply With Quote
Old 02-03-2009, 06:45 PM   #2320
Krio's Avatar
Trader Rating: 150 (99%+)
Apparently Boost isn't active at zero/very low rpm so if you have the motor set at zero you get more torque down low and then boost kicks in and you still have the R's of high total timing for the straight.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-03-2009, 06:49 PM   #2321
I was told to drop 5 teeth from the pinion when switching to that setup...seemed about right from the motor temps I was getting.
Old 02-03-2009, 07:03 PM   #2322
sg1
sg1's Avatar
I saw more wattage produced and more RPM. I had to gear down from a 3.3-3.4 normal rollout to a 3.0 on a track 95 x 60. On a smaller track 70 x 40 I was at a 2.6-2.7 and ran times consistant for 8 minutes.
Old 02-03-2009, 07:36 PM   #2323
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
-Wayne
I bought that 17.5, it IS a rocket. Hey Wayne, you were right about the timing, I had it too high for such a tight track 50X25. Eight minutes of not blinking! Gonna see what happens when I really drop teeth and add more timing.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-03-2009, 08:01 PM   #2324
Trader Rating: 35 (100%+)
Josh Keller is offline   Reply With Quote
Old 02-03-2009, 08:05 PM   #2325
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Has anyone tried the 0 timing and max boost on the 10.5 yet? I just got mine with the hot wire. Gonna try it this weekend in the 1/12 scale.
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
