Tekin RS ESC sensored >
Old 04-29-2013, 10:19 AM
  #23206
theatriks's Avatar
You Da Man !
theatriks is offline
Old 04-29-2013, 10:39 AM
  #23207
TJ Bradley's Avatar
Ran my RS Gen 2 over the weekend at Village Raceway in Palm Beach back to back with my RS Pro. I was able to produce faster laps with Gen 2 and the motor ran 15 degrees cooler over a 6 minute run(13.5 blinky). In stock now at superiorhobbies.com!
TJ Bradley is offline
Old 04-29-2013, 09:51 PM
  #23208
BoneCrusher's Avatar
Default Setup help please...
Looking to step up and run Mod next indoor season with an RS Pro so hoping for some starting setup help.
Touring Mod with 5.5 Turn motor
12th Scale with 4.0 Turn motor
Looking for a mild starting setup for a medium size ozite carpet track (80x36). Iíve checked the Setups from the Tekin Website and I donít see a setup with the motors Iím planning to run.
Iím an intermediate driver with about 5-6 years RC experience looking to make it a lot more challenging for myself as I have never run lower than a 10.5 Turn motor before in either car.
Looking for any help from anyone whoís used an RS Pro before to run Mod.
Thanks,
Ivan
BoneCrusher is offline
Old 04-29-2013, 11:08 PM
  #23209
STLNLST's Avatar
Trader Rating: 31 (100%+)
Tekin has set up's on their website that should start you off on the right foot.
STLNLST is offline
Old 05-01-2013, 11:42 PM
  #23210
RacinJ's Avatar
With today's announcement of the new RX8 Gen 2, does that mean the 1s version of the RS is next???
RacinJ is offline
Old 05-06-2013, 05:10 PM
  #23211
Mugen10's Avatar
So what is the brushless motor limit for the RS gen 1?
I have a older RS and on the web site it said 7.5 brushless motor limit but in the manual it said 5T brushless motor.
Mugen10 is offline
Old 05-07-2013, 09:34 AM
  #23212
Team Tekin
Randy_Pike's Avatar
When the RS was originally released SC's didn't exist,etc. With "today's" cars and batteries the 7.5T is the limit. It's been successfully ran in other cars with lower turns but can thermal.
So what do you plan to use it in?
Randy_Pike is offline
Old 05-07-2013, 11:54 AM
  #23213
oldrcr's Avatar
Trader Rating: 46 (100%+)
Default Stk/blinky mode feel
Hi,
so, I have heard that the new RS gen2 ESC is smoother to drive and gives cooler temps at the motor too, nice. When in stk/blinky mode is it still as smooth, or can it be adjusted to be, since I have heard that the stk/blinky mode on other ESC's were not a smooth as when in adjustable timing mode.
I realize that timing ramps and turbo can cause the feel to be different, but when all those were set to zero, what should be the same as blinky mode often feels different. I noticed this in my original RS, even when I tried different throttle curves. Is this also true of the new RS gen2?
Also, I just saw the new RX8 is out. Will there be a replacement for the RS Pro? Or is the RX8 Gen 2 to be the one to use for Mod TC.
oldrcr is offline
Old 05-07-2013, 02:40 PM
  #23214
Mugen10's Avatar
I plan to run tc asphalt. 200ft. end to end.
Mugen10 is offline
Old 05-07-2013, 03:03 PM
  #23215
Team Tekin
Randy_Pike's Avatar
With a 5T motor, no that won't work long term.
Old 05-07-2013, 03:14 PM
  #23216
Mugen10's Avatar
What is the lowest motor will be the best performing? Most guys r running 4.5.
Is A ESC needed?
Mugen10 is offline
Old 05-13-2013, 03:33 AM
  #23217
Pulse_'s Avatar
hi guys, I need a replacement power cap for my tekin RS.. do you have any suggestion?
Pulse_ is offline
Old 05-13-2013, 06:54 AM
  #23218
Trader Rating: 66 (100%+)
MuffDogg Octane Power Booster! Its 3 caps in one.
http://www.tqrcracing.com/shop/produ....asp?p_id=2714
PROMODVETTE is offline
Old 05-14-2013, 03:05 AM
  #23219
Pulse_'s Avatar
thanks, in which situation are 3 caps needed?
Pulse_ is offline
Old 05-14-2013, 09:23 AM
  #23220
Team Tekin
Randy_Pike's Avatar
Rare ones if any at all. The Stock TT3520 cap is more than sufficient for 99% of situations.
