Old 02-11-2013, 06:24 PM   #23116
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Adrean View Post
Guys ,
i have 2 little problems , hope you can help me with this , first i put HARA 17.5 SETUP ON my car and i run with REDLINE 13.5 MOTOR RS ESC , run with a 6.4 FDR in my car 108 spur / 32 pinion , but my motor after 10 minutes comes at 125 celsius , i know thats is too much temperature , and my motor didnt run again but i have some motor on my spares and i put a new Motor and Go for 7.1 FDR , 116 SPUR / 31 PINION on My XRAY T3 12 , it runs very strong in all 10 Minutes of The Main Final , i Win by 2 Laps , but the temperature when i finish Was 93 Celsius , so My Question is , i need To Go Higher on FDR like 8.00 , or what i need to re adjust on My ESC setup ? Thanks A lot !!!
I run with 5000 mAh 35c 2S 7.4V Lipo Battery , in an Large Asphalt Track , we need to reach 10 minutes in qualifiers and Final .
Thanks In Advance
Cheers
Considering the battery you are using and how long your heats are, you may be losing enough voltage to cause the over heating. As the voltage drops, the current goes up causing more heat. Try a better battery with your current settings and you should see an improvement in temps.
You will want at least a 50C rated battery.
YoDog is offline   Reply With Quote
Old 02-11-2013, 10:28 PM   #23117
big al's Avatar
Your problem isn't the battery, it's the 10 minute main. You need to experiment with different gear ratios that maintain good lap times and minimize heat. You also need a quality fan. Yeah racing makes some high rpm fans that will help reduce temps by 10-15 degrees fahrenheit. Good luck to you!
big al is offline   Reply With Quote
Old 02-12-2013, 10:19 AM   #23118
Adrean's Avatar
Thanks Bro .
Thanks Bro , then i should go Higher with FDR i will try with 8.00 FDR and see how the temps go ! Thanks A lot
# Team Shepherd # http://rccar24.com/ # Brilliant RC #Iealsi Tuned #HYPEX
Adrean is offline   Reply With Quote
Old 02-13-2013, 12:51 PM   #23119
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Hi, sorry for a rookie question.
I want to know, how can I "know" actual motor timing (redline 10.5 old version). How to get more timing, and what do you recommend me for 10.5T boosted class.
JQ WE - Alpha Lutz WE - Xpert Servos - AKA
Tekno EB48 - Tekin RX8 - AKA
_________________________
=> BIMA RACING TRACK <==
MiTaller-RC is offline   Reply With Quote
Old 02-14-2013, 01:00 AM   #23120
Hello.
Can someone give me a good starting point (boosted and sensored) set up with 223.
I just put on my car (hot bodies tcx) a rs pro with lrp 10.5t x12 for a small and very technical carpet track?Thanks
p.s. the motor will be cooled by a very large fan!
moraccio is offline   Reply With Quote
Old 02-14-2013, 01:40 PM   #23121
Default ESC wont beep and motor wont turn.
Hi,
I recently bought a Tekin RS Pro ESC with a 13.5 Redline Motor.
I hooked up everything up as per the manual. Yesterday I put it on
the track here in Mexico for the first time. A friend passed me his
ESC set-up through his PC using Hot-wire.
The car only advanced for 5 meters and then it stopped.
Now when I turn on the ESC it doesn't beep like before and the motor
wont turn. When I press gas or brake the lights on the ESC go on and
flash but nothing happens.
I checked all the soldering on the motor and on the ESC and it is correct.
I tried updating the software on the ESC and connected a brand new 10.5 redline motor. It still doesn't work.
When I turn it on the ESC it doesn't even beep.
What should I do?
Thanks in advance!
jherrero is offline   Reply With Quote
Old 02-14-2013, 02:34 PM   #23122
Geezatec's Avatar
Originally Posted by jherrero View Post
Hi,
What should I do?
Thanks in advance!
Redo the calibration w TX. Validate your motor type. With Hotwire do not disconnect to quickly, it take a while. Make sure when calibrating you hear beeps b/n neutral, full throttle and brakes.
Geezatec is offline   Reply With Quote
Old 02-14-2013, 05:29 PM   #23123
Thanks Geezatec, I'll try that again. How do I validate the motor type?
Old 02-14-2013, 07:15 PM   #23124
Trader Rating: 60 (100%+)
In the setup section on hotwire you chose between BR (brushed) and BL (brushless) and FW (fwd only) FR (forward reverse) and DL (delayed reverse).
PROMODVETTE is offline   Reply With Quote
Old 02-14-2013, 08:31 PM   #23125
theproffesor's Avatar
Trader Rating: 58 (100%+)
Nevermind, I figured it out.
I hooked up my new RS tonight with my tekin gen 1 17.5. WHY IS IT SLOWER THAN MY CHEAPO BRUSHLESS HOBBIES ESC? (dont et me wrong I really like the BHR esc, but wnated to upgrade). I may go back. I am running the same gear ratio as before, just changed esc.
I dont understand the hotwire interface. I need help. I will be running 17.5 tc that allows boost. and turbo. What should my max rpm be, min rpm Ect...
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-15-2013, 12:44 AM   #23126
Nobody?
Originally Posted by moraccio View Post
Hello.
Old 02-21-2013, 01:52 PM   #23127
theatriks's Avatar
Hey guys im hoping some of you can help me out....i have a kyosho tf6 sp and i have no choice but to run an fdr of 6.84....due to a modification im trying......im running the car in 17.5 boosted on a 70x30 carpet track.....im wondering what settings i should run on my rs pro to get the most out of it at that fdr.....any help would be greatly appreciated.....Thanks in advance.
theatriks is offline   Reply With Quote
Old 02-22-2013, 06:59 AM   #23128
theatriks's Avatar
Really? Zero support in this thead? ....time to buy an orca.
Old 02-22-2013, 07:04 AM   #23129
Hobbywing
Sean B. is offline   Reply With Quote
Old 02-22-2013, 09:05 AM   #23130
YoDog's Avatar
You do realize that this is a community forum...right?
Not customer support.
The responses you get here are not indicative of a particular product manufacturers customer support. Tekin products are of excellent quality and customer support has been very good in my opinion. If you can't read directions or do any of your own research, don't blame the brand or it's followers. Perhaps no one is really interested in responding to your request since it doesn't hit anyone's hot buttons. Read back to pages from a year or so ago and you might find what you are looking for since almost nobody runs 17.5 boosted anymore thus... no responses.
All the setup suggestions in the world can't replace good ol' testing. It may just help you to understand the products you are using.
The info is here as well as on the Tekin website... look for it.
The RS hardware hasn't changed in 5 years, who else can say that? over 1500 pages in this thread alone!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
