Old 02-01-2009, 12:01 PM   #2296
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by Josh Keller View Post
What is the difference between firmware versions 180 and 183?
Thanks,
Josh
The only difference is that 183 is more aggressive down low as far as the profiles go. 180 with high turn motors was pretty empty for the first 30% of trigger throw.
Originally Posted by P2 View Post
Randy, Is it safe to remove the solder posts and solder the motor wires directly to the PC board??? Old stlyle
Its safe if you do it right
www.kriostasis.com
Krio is online now   Reply With Quote
Old 02-01-2009, 02:22 PM   #2297
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It is safe? NO, chances are you're not going to get the solder to flow properly as the traces were not meant for it. I've see guys trim the posts but I don't recomend that either.
Modifying the esc in any way will void the warranty.
To view the current software level you must have access to a Hotwire.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-02-2009, 08:50 AM   #2298
Originally Posted by mxzhonkey View Post
the speed passion motors with not adjustment have 12 degrees built in, the duos with the timing holes as 12 degrees on number 0 and 10 more each form there
I have a DUO 13.5 at left hole, which means 12 deg? My boost is currently on 23 with FDR 5.63. So my total timing is 35, seems on the high side. I am temping at 150+. Should I try to reduce FDR a tooth or 2 and reduce some boost? I could do with more stright speed.
stocker is offline   Reply With Quote
Old 02-02-2009, 08:56 AM   #2299
It is than eaven higher
you forget the 15 in the speedo.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-02-2009, 09:42 AM   #2300
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default tekin
Randy Pike you have mail thanks
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 02-02-2009, 10:42 AM   #2301
If you are looking for more straight line speed it's going to take more gear or more timing. The problem is that you're starting to get close on motor temp so in order to add timing or more gear for the straight you need to get the car to go through the infield better. Once the car works better in the corners the motor temps should be lower. Then you can add more timing or gear.
It's hard to say what exactly to do without being there and seeing the car run but I've found that most of the time I end up working on getting the car better before I can add gear to make it faster on the straight.
Fred_B is offline   Reply With Quote
Old 02-02-2009, 10:54 AM   #2302
Team Tekin
Randy_Pike's Avatar
I agree with Fred. I'd want to see the car on the track. If you want more top end you need more gear or more timing.
You're boosting pretty high now. Try this setup next time you're there.
Run the motor straight ut 0, boost at 30 same gearing. Running that setup offers great infield and out of the corner torque. Then the high boost timing get's you good top end rpms....
Old 02-02-2009, 11:13 AM   #2303
Team Tekin
TY@TEAMTEKIN's Avatar
I wouldn't remove those posts, plus it is very difficult to get them out since they were installed with HMP. A regular soldering iron won't be enough to get them out without damaging something.
Plus your temps would go up quite a bit.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 02-02-2009, 02:15 PM   #2304
Kenny L's Avatar
Trader Rating: 16 (100%+)
I agree 100% with Randy you need to keep can timing down to 0 and go full boost this was the hot setup at the Birds
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 02-02-2009, 04:38 PM   #2305
jdearhart's Avatar
Trader Rating: 15 (100%+)
Randy, I sent you a PM with my email address. I need to get a copy of the 1.89 software. Thanks!
jdearhart is offline   Reply With Quote
Old 02-02-2009, 05:05 PM   #2306
AdamD's Avatar
Great job at the birds!!!!!! Congrats to all the team drivers.
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 02-02-2009, 05:13 PM   #2307
Team Tekin
Randy_Pike's Avatar
Yes our drivers had a great Snowbirds! Stay posted to the updates on our site for more indepth's look at RS setups for each driver!
Old 02-02-2009, 06:38 PM   #2308
Thanks guys. I am already on the least advanced timing position on the DUO can. According to Mxzhonkey, it's 12 deg...
Old 02-03-2009, 10:33 AM   #2309
Team Tekin
Randy_Pike's Avatar
I'd double check that. I'm sure the Duo can go straight to 0. At least pretty sure!
Old 02-03-2009, 11:24 AM   #2310
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
I'm pretty sure the Duo timing holes are 0-10-20.
ChristopherKee is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
