Old 01-20-2013, 05:09 PM   #23071
JustWill75's Avatar
Send a message via AIM to JustWill75
I was having the same problem with my Reedy, Tekin blinky setup.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-20-2013, 05:43 PM   #23072
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
I think my hotwire just killed 2 of my rs's today :/
something happened to both rs's after the first use after i changed a few things on the settings. the first one was blinky 21.5 in a trans am, and the other one was blinky 17.5 in tc.
the trans am one worked for about 3 minutes and all the sudden shut off under hard acceleration off a hairpin. the tc didn't even make it to the loop on the warm up lap.. went about 5 feet under 25% throttle and just shut off.
the pc reconizes both esc's, but no power when battery is plugged in. i've tried new batteries/wires/caps/receiver. no luck with either..
also to note neither smell blown, neither were hot. and no smoke came out at all.
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 01-20-2013, 07:35 PM   #23073
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by JustinD413 View Post
Do Amy of u guys know if there's a way to stop the tekin rs and rs pro from making that loud noise when you hit te brakes? It's really annoying but other than that this speedo is great
No, the noise you hear is a result of the improved brake feel. Each motor sounds different brand to brand.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-20-2013, 07:50 PM   #23074
JustinD413's Avatar
ok well i guess that just trinity motors that do the because i dont hear anyone elses motors
JustinD413 is offline   Reply With Quote
Old 01-20-2013, 07:56 PM   #23075
mashimarowu's Avatar
Send a message via AIM to mashimarowu Send a message via MSN to mashimarowu Send a message via Yahoo to mashimarowu Send a message via Skype™ to mashimarowu
Well I personally lowered my brake level so I don't kill my gears and to use my brakes as a drift tool when I go around corners. That could possibly lower your brake noise if it really bothers you and assuming you don't need all that brake power.
Losi Micro VEX | Flysky GT3C
Losi Mini 8ight | Hitec 225MG | Flysky GT3C
B4.2 | Savox 1257TG | Flysky GT3C | Tekin RS | EM "Zapper" D3.5 17.5T
B44.2 | Savox 1267MG | Flysky GT3C | Tekin RSX | Reedy Sonic Mach 2 7.5T
HPI Savage Nitro | Futaba
mashimarowu is offline   Reply With Quote
Old 01-20-2013, 08:01 PM   #23076
randy. any hints to my problem?
Live, Laugh, RC
Old 01-20-2013, 09:24 PM   #23077
JustWill75's Avatar
My Reedy makes a weird electric violin noise when I hit the brakes but everything else seems to be normal. I'm pretty fast at my track and my throttle is very smooth.
Old 01-21-2013, 02:02 AM   #23078
Tradin Paint's Avatar
Just to confirm. When you plug the ESC into the HotWire it comes up as normal and changes can be made and saved however when plugged into your car as normal nothing happens. No power, no LEDs light up?
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 01-21-2013, 09:13 AM   #23079
Yes, this is correct. both normal rs's and neither have seen a motor lower then 10.5t for offroad and 17.5/21.5 for onroad
Live, Laugh, RC
Old 01-21-2013, 09:55 AM   #23080
Team Tekin
Randy_Pike's Avatar
What motors are you using?
If you unplug the esc from the receiver, unplug the sensor harness form the esc side, does it power up?
Old 01-21-2013, 12:17 PM   #23081
I was using a 21.5t D3.5 motor on one.
17.5t D3 motor on the other.
Both esc i took out of the car and motor leads and sensor wires off and plugged it in. no luck. that's when i decided to try hotwiring it again and it still shows on my pc and middle LED's flash like normal.
both cars run thunderpower batteries 65c 2s batteries with deans so i cant even reverse polarity if i try, running spektrum tc/rx with hitec servos. trans am geared 96/46 * 2.0 = 4.17
Tc geared 96/44 * 2.0 = 4.36
Running on a 60x60 ft track.
i know I'm well under from what i can push the electronics to.
Live, Laugh, RC
Old 01-22-2013, 01:58 PM   #23082
Reese Bobby's Avatar
Hi Randy,
Your expert advice is appreciated. I am running 17.5 and 13.5 Gen2 RPM (both boosted) on RS Pro ESC's and see that i have arrived at pretty much the same ESC settings for both motors. The gearing on the 17.5 is longer.
Is that in the ballpark of what you would expect? I am running the 223 software version on both ESC's.
Your input is greatly appreciated.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 01-23-2013, 09:25 PM   #23083
Sooooo i take it i'll need a rma and package a box of goodies.. well this will only be my second time and i've been running tekin indoor/outdoor all year long for 3-4years. excellent products!. plus i don't think that these 2 "burnt up" as in just something easy and stupid.
Live, Laugh, RC
Old 01-25-2013, 01:14 PM   #23084
Hello.Any good starting point of gearing and timing for a rspro with lrp 5.0 octa for a large nitro track?Thanks
chuss43 is offline   Reply With Quote
Old 01-25-2013, 03:25 PM   #23085
Team Tekin
Randy_Pike's Avatar
Originally Posted by Reese Bobby View Post
Hi Randy,
Yes,
The two winds aren't too far apart on esc setups most of the time. As you've found the gearing is usually the only difference.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
