Old 11-05-2012, 07:16 PM   #22951
theatriks's Avatar
Originally Posted by locked View Post
Rob, just click on the 212 setups. Try Hara's setup, but start with a little less turbo and then bump it up if needed. Check temps frequently.
Ok ya I couldn't see it on the iPhone ....thanks dude
theatriks is offline   Reply With Quote
Old 11-05-2012, 08:26 PM   #22952
locked's Avatar
No problem. Start with the 6.5 FDR he used also.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-06-2012, 05:38 AM   #22953
S_fender's Avatar
Hello,
I'm searching 223 setup for touring 13.5 boosted.
Car = Tc6.1
Packs = Reedy 6500 65C
Motor = Orion 13.5.
Speedo : Tekin RS PRO + 223 software.
Small carpet track.
Sébastien.
S_fender is offline   Reply With Quote
Old 11-06-2012, 07:29 AM   #22954
locked's Avatar
Originally Posted by S_fender View Post
Hello,
Car = Tc6.1
Motor = Orion 13.5.
Small carpet track.
Sébastien.
Start with Hara's 17.5 setup, dial back the boost and turbo a couple of notches to begin with(46-48 boost, 10-12 Turbo). Start with an FDR around 7.2 - 7.5. That should get you in the ballpark.
Dave Locke
Old 11-07-2012, 10:02 PM   #22955
zerocool77's Avatar
Send a message via Yahoo to zerocool77
Dear Randy
Can you explained to us, how this Tekin esc work. I mean, which is come 1st. Let say, we use 5k start RPM, end RPM is 20k, its mean, after 20K the Turbo is engage..? How if we set it use motor RPM, like Tekin 10.5T is 33,300RPM on 7.4V. So we put the RPM is around 28,000. Is it need to wait 28,000RPM, then the Turbo will engaged?... Please advise, so we can use this as our setting tips...
~ Team Putra Serpent, Kch ~
zerocool77 is offline   Reply With Quote
Old 11-07-2012, 10:11 PM   #22956
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by zerocool77 View Post
Dear Randy
This may help you out.
http://www.teamtekin.com/hotwire_RS.html
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-08-2012, 09:25 AM   #22957
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Dear Randy
Turbo is not regulated by rpm, only time.
Please read the guide the other gentlemen posted. It should answer your ?'s
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-09-2012, 02:37 PM   #22958
Hey guys sorry this is off the topic, But I have a nitro road car with a fs12 sw engine in it with a tamiya chassis and i cant get the car to start ! The only way it will start is if i pull the glow plug out and put fuel down the carby then it will start first time and run for a few seconds, Would anyone be able to help me ? Thankyou!
Sambo 7 is offline   Reply With Quote
Old 11-09-2012, 02:48 PM   #22959
Regional Moderator
CarbonJoe's Avatar
Try the Nitro On-Road forum. This thread is about Tekin RS electronic speed controls.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-10-2012, 06:26 AM   #22960
zerocool77's Avatar
Hi Randy, so its useless if we set the end RPM higher rite? Coz somebody tell me if we set the end RPM using recommended by Team Tekin 20,000RPM its become normal motor. Coz they told me, Redline motor RPM is 33,000RPM. Set it to 30K or 28K
Old 11-10-2012, 03:38 PM   #22961
YoDog's Avatar
Trader Rating: 26 (100%+)
Talking
The RPM start and end points are mearly to set the range that the boost changes effectiveness. The bigger the difference between these two numbers, the more gradual the boost is applied. Smaller difference results in a more aggressive increase in boost. Now depending on what motor you are running and the gearing you are using will determine the proper range and aggressiveness the boost should be applied. The lower the starting RPM, the more initial rip you will experience which can be both good and bad depending on grip levels. You can either overheat the motor or loose traction if this setting is too low. End Rpm determines how quickly the motor accelerates over the usable RPM range of your motor/ gearing combination. Just because your motor is rated at 30k RPM doesn't mean that the end RPM should be the same. It's actually somewhat irrelevant. The boost is a performance enhancer and should be set according to the performance of your whole package not just your motor specs.
I hope this helps.
YoDog is offline   Reply With Quote
Old 11-11-2012, 12:24 PM   #22962
theatriks's Avatar
Is there hotwire software thats compatible with a mac...i cant find it anywhere!!
Old 11-11-2012, 01:27 PM   #22963
theatriks's Avatar
I cant figure this out ....how come when i go to update my esc it says version 180 is the latest and how come when my speedo is connected tohotwire it just shows basic settings no boost or turbo or battery type and theres no advanced button or nothing how do i program my boost and turbo?
Old 11-11-2012, 04:33 PM   #22964
theatriks's Avatar
and can someone also tell me why the hotwire software is asking for a .net framework update when i just spent 1 hour and half updating my computer....am i the only one who has this much trouble with tekin software downloads....i mean it shouldnt be this difficult!
Old 11-11-2012, 06:35 PM   #22965
StartingGrid's Avatar
hello. i am rs pro user. pls give me timing setting for 4.5t touring car. i run at TITC. thanks
timing=
boost=
end rpm=
turbo=
www.teamtekin.com
StartingGrid is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
