Old 10-30-2012, 04:30 AM   #22936
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Low_E View Post
Hence my question: does the tekin rs pro have a blinky-mode, do i need a specific update for that?
Thx in advance!
Yes, the RS Pro works nicely in blinky. One of the nice features of the Tekin is that you don't have to change firmware to switch between blinky and boost/turbo modes. The "blinky" profile has been available for several releases, but if you have access to a Hotwire unit, I'd update it to the latest.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 10-30-2012, 11:50 AM   #22937
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Got a issue. In my sons Durango dex 410 w/ LRP 6.5 on a carpet track his speedo hits 185+ and on the same settings on a clay track barely reaches 100. I got his throttle limiter set to 75 and boost at 0. Can using a lot of brakes heat up the rs pro?
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 10-30-2012, 12:49 PM   #22938
racing_jason's Avatar
The heat is from the extra traction that you get when you run on carpet.
Brakes can be an issue but its usually fade if you have a problem. Are you using one of the pre set TP? if not i would try TP2 and see what that gets you. Also Maybe gearing? where are you on that?
Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 10-30-2012, 03:24 PM   #22939
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The added temp is from the higher bite. Never use a temp gun on the RS. It won't be accurate. Use the onboard temp indicator:
6 led's and under is fine. If you're planning on more carpet running add a 2nd TT3520 power cap. It will help keep esc temps down.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-30-2012, 03:54 PM   #22940
Default Rs & gen2
Which is a better motor for RS on a TC 13.5 blinky on a small carpet track, gen2 rpm or just the regular Gen2 redline?
Thanks !
farmbridge2404 is offline   Reply With Quote
Old 10-30-2012, 05:03 PM   #22941
Team Tekin
Randy_Pike's Avatar
Small track means tight. Go Std.
Old 10-30-2012, 05:22 PM   #22942
Thumbs up
Thanks Mr. Pike!
Old 10-30-2012, 07:14 PM   #22943
Ok went to the carpet track today looks like 4 lights. Didnt have the laptop to bump up his throttle limiter. Im running a 19 pinion 87 spur. Seems fast enough dont want my son to beat me so I might just leave it.
Old 11-03-2012, 05:00 PM   #22944
jsr555's Avatar
Trader Rating: 17 (100%+)
Default Gen 2
I realise this is the speedie thread.. but just wondering what the thoughts are on the Gen 2?
I was about to get a new 17.5 for blinky and was going to get the D3.5...then I seen this one... any thoughts? Does the Gen 2 seem to match it with the current 'prefered' choices of motors going around..?
It will match my speedie if nothing else...
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
Old 11-03-2012, 08:14 PM   #22945
Nuno Gancho's Avatar
Mr. Randy Pike, I run 13.5 with trimming currently after 8 minutes the speedo indicates 3 LEDs flashing so there is no temperature issue and motor cames out at 70 deg, the speedo is with every parameter MAX is there anyway the speed may give same more punch and top speed since it is far from hot.
The RPM I have set 3000low and top 170000 but I feel lake of power on the start and top speed, do you think changing to 1500 low and 20000 top will go faster or is better to try different gears.
Nuno Gancho is offline   Reply With Quote
Old 11-05-2012, 09:52 AM   #22946
Team Tekin
Randy_Pike's Avatar
Please post your entire esc setup, gearing, car, motor, motor timing, battery,etc.
This post is far too general for me to offer accurate info.
Old 11-05-2012, 03:05 PM   #22947
theatriks's Avatar
Hey guys I can't find an rs pro thread so I figured this is the place to ask....anyways I have a tekin rs pro and I am running 17.5 boosted on a 70x50 track and need a good starting point ...I'm running a schuur speed 17.5 and need a and awesome boosted setup ....can anybody give me some settings for the speedo ...thanks!
theatriks is offline   Reply With Quote
Old 11-05-2012, 04:49 PM   #22948
Team Tekin
Randy_Pike's Avatar
Try here:
http://teamtekin.com/hotwire/ESCsetups/index.html
Old 11-05-2012, 05:26 PM   #22949
theatriks's Avatar
All I see from that link is one one road setup using a 4 turn
Old 11-05-2012, 05:42 PM   #22950
locked's Avatar
Rob, just click on the 212 setups. Try Hara's setup, but start with a little less turbo and then bump it up if needed. Check temps frequently.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
