Old 01-31-2009, 04:37 AM   #2281
RC MARKET's Avatar
Originally Posted by TeamTekin View Post
Actually we turned on PUSH in BL mode in the newest software version coming. Many of the spec motors do have a lot of cog torque and enough drag to make some want it. It was a brushed inspired feature (Pike push actually) but also has merit in BL.
We do not like people to trim the throttle out of nuetral or we do not initialize because we do not see the nuetral we expect at turn on. Trimming the throttle or putting Nuetral Width too tight can also kill Drag Brake. Some radios are not consistent enough to always return to the same nuetral if it is set too tight. If we do not see nuetral there is no PUSH or Drag Brake activated.
Yes we are also adding the ability to save setups in the hotwire, name them and pass them around as individual files.
Tekin Prez
Which Ver. in RS Pro ?
RC MARKET is offline   Reply With Quote
Old 01-31-2009, 05:58 AM   #2282
Originally Posted by 1armed1 View Post
Here is what it looks like.
http://www.autozone.com/selectedZip,.../selectZip.htm
You can find it cheaper at Walmart and lowes.
later
Dayton
thanks dayton. 3m brand should be readily available.. I wasnt sure how easy/possible it would come off, when it needs to be changed! thanks!
gortan is offline   Reply With Quote
Old 01-31-2009, 09:12 AM   #2283
Geezatec's Avatar
Originally Posted by Trips View Post
Parma makes a GREAT servo tape that is made of silicone rubber. It sticks real well, but when you peel it it always comes off in one clean piece... noo crumbs, no residue.
Originally Posted by gortan View Post
thanks trips... always helpful.
I'm looking at it right now but cannot make out how thick it is. Is it foam type?
My only concern is, if it is too thin, then it might not take up any imperfections between the two flat surfaces, reducing adhesion strength...
g
hi...
i was wondering what would the best way to mount the esc to a 1/10th tc.
what the stuff that's used to fix the esc to the package when new in the box... look like some hot glue.
anything similar that can be used on a car without investing in hot glue gun? that would be great as it is extremely sticky and able to come off clean if necessary...
thanks
g
Go to your local Walmart, Lowes or Autozone.
Look for 3m body molding/ mounting tape.
I get the 1" wide roll, it's $6-7 depending on where you get it but the roll will last forever.
It sticks very well and when it comes time to remove it, it peels off very clean.
later
Dayton
1" Scotch Foam Mounting Squares, found at Staples or Office Depot. With Hot Glue @ 100degrees it starts to melt, coming loose. Mounting Square are cheap and easily available. I even use it an mounting lipo with no problem at all. Stay away from useing hot glue.
Geezatec is offline   Reply With Quote
Old 01-31-2009, 03:50 PM   #2284
jdearhart's Avatar
Trader Rating: 15 (100%+)
later
Dayton
Walmart also sells the same stuff as the Parma tape. They have clear and grey. I usually pick up two rolls for about the same price that one roll of the Parma tape costs. It's located in the same section as the HVAC filters, close to all of the house paint.
jdearhart is offline   Reply With Quote
Old 01-31-2009, 04:18 PM   #2285
miller tyme's Avatar
Mass Volume, retail chains are great.
If nothing else the layout is the same everywhere
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-31-2009, 05:12 PM   #2286
my personal preference is shoo-goo, I will put a piece on servo tape in the center of whatever i'm glueing down, and then shoegoo around th edges and apply when it dries it aint going any where until you peel it off. comes off with no mess.
shaggy1 is offline   Reply With Quote
Old 01-31-2009, 05:56 PM   #2287
CCristo's Avatar
Trader Rating: 55 (100%+)
1.89 has it
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 01-31-2009, 06:07 PM   #2288
rsperson's Avatar
Default ver 1.89
now we just need to get it from the website
rsperson is offline   Reply With Quote
Old 01-31-2009, 06:33 PM   #2289
Tekin Prez,
So in 1.89 - the push actually works in BL mode? What will it do to a BL motor?
We are running on a short bullring track and I can't get my tekin RS to add brake as I slow down. I do have 1.89. It only seems to slow if I take my finger way off the throttle. What settings would you suggest? (I am running a futaba 4PK radio)
robracer is offline   Reply With Quote
Old 02-01-2009, 05:39 AM   #2290
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're NW is too narrow you can work your way right out of your drag brake. You can increase your DB setting too.
Push adds what we use to call "creep" to the car. However the Push Control will add creep that is reactive to how long you are on throttle for. You can set it up for a little or a lot to where it carries the throttle for quite a bit...it's like a storage tank of sorts. The longer you're on throttle the more push you'll get.
Jeff Cuff's wins 17.5 TC Rubber class at the birds from tone to tone!
Jeff Tq'd 17.5 Rubber & 17.5 Foam!
More results to come...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-01-2009, 08:50 AM   #2291
Team Tekin
Randy_Pike's Avatar
Tekin Dominates the 1/12 17.5 Class at the Birds. Donny Lia Tq'd takes the win! Fellow teammates JB Catricalal, Eli Ezrow, Mark Smyka, and Sal Amato(privateer).
Half the field running the Tekin RS!
Congratulations to Donny Lia and the rest of the Tekin Team!
Old 02-01-2009, 10:53 AM   #2292
Trader Rating: 35 (100%+)
Josh Keller is offline   Reply With Quote
Old 02-01-2009, 11:30 AM   #2293
P2
P2's Avatar
Randy, Is it safe to remove the solder posts and solder the motor wires directly to the PC board??? Old stlyle
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 02-01-2009, 11:33 AM   #2294
Regional Moderator
CarbonJoe's Avatar
I wouldn't... the posts serve as the heatsink for the internals. Probably voids your warranty as well.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-01-2009, 11:40 AM   #2295
morris's Avatar
Trader Rating: 40 (100%+)
i just recently bought a nip rs...this past friday to be exzact.how do i know what version it is...?
and is there amything i should do/not do.
i am currently running an lrp sphere comp...i like the esc...just to big for the losi type-r...
so the sphere will go in my xxxt...and in with the rs in the type-r.
lmk any helpfull info.....thx guys....
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
