Old 09-24-2012, 10:25 AM   #22861
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by CFR View Post
Tekin RS (not Pro) faulty?
It'll take settings for 212 & 223, either 'Blinky' or timed/boosted via the hotwire but the esc won't let the motor get rev out. Runs about 2/3rd's the pace of when running 13.5 blinky.
Changed power cap, sensor lead, batteries to no avail
It won't work in 2s but with a booster wired in it'll do 1s
Any ideas?
If it's coming out of the corner only I'd ask you what servo are you using?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-24-2012, 11:17 AM   #22862
el salvador's Avatar
Lightbulb
Any ideas?
I'll go "Out on a Limb" here and dare to suggest that your BEC has become Non-Functional, that is if, as you say the ESC is fine with a Booster.
Without explaining how I know this, I'll just say I have an RS that does the same thing and I'll not bother having it fixed as it's just fine for 1s WGT Racing.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 09-24-2012, 01:17 PM   #22863
CFR
CFR's Avatar
KO 949 ICS
motor doesn't rev out the track or the work bench
on track it may rev out for say 3rd of a lap then just crawl
CFR is offline   Reply With Quote
Old 09-24-2012, 01:46 PM   #22864
Team Tekin
Randy_Pike's Avatar
KO 949 ICS
You posted this on Oople also right?
1s or 2s ? Booster or Rx pack?
Old 09-24-2012, 03:31 PM   #22865
CFR
CFR's Avatar
o0ple = yes
1s with Booster from RCDyanmics. Have one hooked up to a RS Pro and that is OK. Voltage from booster is 6v.
Old 09-24-2012, 04:48 PM   #22866
Team Tekin
Randy_Pike's Avatar
o0ple = yes
Please try a 2s supply battery as a test. Let me know the result.
Old 09-27-2012, 10:35 AM   #22867
evostyle's Avatar
Trader Rating: 102 (98%+)
Any new news on when the GEN 2 motors are going to be available?
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 09-27-2012, 02:50 PM   #22868
Originally Posted by Autod View Post
Hi!
starting to get this car working good now, but the problems is now that after maybe 3-5min it will loose power. temps are good,esc have 4led, motor is about 50-60c, battery is cold. (outside temp is also low,10-15c) is it the battery that is the problem? ( 5000mah 40c) it has been used for some time...
motor timing 0
Fdr 8.3
start 14000
end 30000
boost 28
turbo 15
ramp 2
delay .2
Hi again!
have been testing some more today. got a new battery, 6000mah 60c
more or less the same result. after 2-4 min it will loose power on top, maybe better then the old battery but not wery good.. almost like turbo is gone. sensors are ok..
in 5 min it will use about 1800-1900mah
any help with the settings to make this work better? the car is great to drive for the first 2-3 min, top speed is good and good power.
Tekin. LRP X12. Futaba. Xray T3. Xray NT1. Serpent S120
Autod is offline   Reply With Quote
Old 09-27-2012, 03:15 PM   #22869
Hi again!
I had this same problem running boost with a 10.5 motor. I'd like to know the answer too
DOTMAN is offline   Reply With Quote
Old 09-27-2012, 03:16 PM   #22870
Hi again!
your not useing a x12 are you ?
i had several x12s do the same thing, they go well, then "fade", I tried a reedy, murfdogg, speed passion and a tekin, none of them had this problem and ran the same tekin settings
ed
Edwin Pibal is offline   Reply With Quote
Old 09-27-2012, 04:35 PM   #22871
This is a Tekin 5.5 motor in my friends car. i`m running X12 10.5 in my car, but i don`t have the same problem, it will fade some, but not to much. my boosted 10.5 is also faster than this boosted 5.5 so far..
Old 09-27-2012, 04:37 PM   #22872
Team Tekin
Randy_Pike's Avatar
Gen 2 mod winds have been out for nearly a month now. Spec winds are due out shortly.
Old 09-27-2012, 04:39 PM   #22873
Team Tekin
Randy_Pike's Avatar
Guys please use the RS's sensor checker feature to make sure your sensors are working. It's easy enough to do:
+ YouTube Video
If the car doesn't feel right, it's likely not so a few minute testing it will help sort it out.
Sensors can be hit or miss so systematically eliminating the sensor harness,motor and then esc shouldn't take all that long.
Old 09-27-2012, 11:43 PM   #22874
I always use the sensor checker. But that is not a problem in ny case..
Old 09-28-2012, 11:08 AM   #22875
ed
May be the temperature sensor esc cutting current to lower the internal temperature.
Pickthall is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
