Old 07-02-2012, 06:00 PM   #22741
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Been trying to get onto tekin's website for a few days now, on different computers.... No luck. Any know problems?
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 07-02-2012, 06:52 PM   #22742
Same problem here....I guess the site is down...
mhavlena is offline   Reply With Quote
Old 07-02-2012, 07:12 PM   #22743
YoDog's Avatar
Trader Rating: 26 (100%+)
No problem for me...
What browser are you using? I'm on the latest Firefox.
YoDog is offline   Reply With Quote
Old 07-02-2012, 07:16 PM   #22744
YoDog's Avatar
IE worked for me as well.
Old 07-02-2012, 09:42 PM   #22745
Sith Lord's Avatar
It's baaack! I did notice there was another thread started in the electronics section... Obviously a problem, but apparently fixed now.
Old 07-03-2012, 05:17 AM   #22746
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
offtopic I have one for sale. brand new in package! pm me.
This is a great esc! great customer service!
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 07-07-2012, 01:24 PM   #22747
Default v223 problems
I updated both of my Tekins to v223 and they no longer act like they've got timing advance. Acceleration is very mild. RPMs eventually increase, almost as if the Turbo function is working, but boost isn't. I even tried loading v212 back in one of them (from a different computer), but it didn't help. I switched my gearing back to a "blinky" range and set the ESC to timing profile 1 and it accelerates faster than with boost. Has anyone else seen this problem? Is it even possible that downloading v223 could screw something up that reloading v212 wouldn't fix?
Kevin Marcy is offline   Reply With Quote
Old 07-07-2012, 01:42 PM   #22748
stiltskin's Avatar
Trader Rating: 102 (100%+)
Make sure that you recalibrate your radio to the speedo. I believe that they fixed the issue, but I still dial my throttle EPA back to 90 when calibrating and then bump it back to 100% when complete.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 07-07-2012, 04:34 PM   #22749
I did the re-cal. The ESC is definitely seeing full throttle. The problem only appears to effect the C1 & C2 profiles. The factory preset ones seem to accelerate quickly (testing on the bench, not the track). On the RS, C2 seems OK but C1 revs up to maybe 1/2 of the final speed (faster than blinky, but not close to the 40 of timing it's set for), then after the turbo delay elapses, it accelerates up to a very high speed, waaay more than the 10 of turbo I've got it set for. On the RS Pro, both C1 & C2 seem to do the same 1/2 speed - hold - then ramp up slowly deal.
Old 07-07-2012, 06:32 PM   #22750
YoDog's Avatar
It sounds like you may have a setup issue still. You may want to use a known set up from one of the team drivers and be sure to save the settings to the speedo. As a start I would run no additional timing in the motor to at least rule out over timing. Make sure you don't have any negative exponential set in the radio.if the boost doesn't seem to kick in, you may have the rpm range set too high for your motor. What wind are you running? If you post your settings , we can at least determine if it's just a problem with your settings. Do you hit ok during or after the timer counts down when saving?
Old 07-07-2012, 07:06 PM   #22751
17.5T motor on 2s (touring car)
motor timing set at zero
Timing boost = 40 (C1) or 50 (C2)
Start RPM = 5443
End RPM = 20016
Turbo = 10
Turbo delay = 0.5 sec
Turbo ramp = 1
Current limit = off
Sensored only
All these settings worked fine until I updated the firmware.
Old 07-08-2012, 10:21 AM   #22752
YoDog's Avatar
Start RPM = 5443
End RPM = 20016
Turbo = 10
Turbo ramp = 1
Current limit = off
Sensored only
Is there a chance that the speedo is switching into dual mode? ( bad sensor or cable)
Your end rpm seems a bit high for 17.5 and the turbo delay could be shorter.
Old 07-08-2012, 07:05 PM   #22753
Suspended
Trader Rating: 86 (100%+)
i m using 212 software does 223 make any different in on road blinky 17.5 stock touring?
littlealex is offline   Reply With Quote
Old 07-08-2012, 07:08 PM   #22754
Trader Rating: 19 (85%+)
ok guys i am having an issue with my rs and maybe someone can help. i was at the track yesterday i plugged my battery in after charging turned my speedo on and first thing i noticed wa there was no sound at all second of all as soon as i turned it on the 1,2 and ,6,7 lights were flasing.i had no throttlewhat so ever but i had power to my servo. i tried resetting my speedo and then after that didnt work i hooked it to hotwire and checked all my settings and everything was normal.i dont know what to do .this speedo is less than 6 months old and raced maybe 10 timesand has always worked flawlessly . i have 4 other rs and this type of issue has never happened maybe someone has an idea to help before i ship it back to tekin and wait like a month to receive it back.any imput woyuld be greatly appreciated...
ChRIs MeNeAr TLR 22 2.0 ,22-4 AiRtRoNiCs M11x TEKIN TRINITY
SPONSORED BY MY CREDIT CARD LOL
AEcarpetracer is offline   Reply With Quote
Old 07-08-2012, 07:20 PM   #22755
NolanP's Avatar
Just double check your setting again I know that at one point I had the same issue due to the fwd setting. Make sure its towards the bottom on the 2s setting with BL-FW. Mine was set at a brushed motor for some reason and it started blinking 1,2,6,7. Otherwise download a known good setup and give it a whirl.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
