Old 06-20-2012, 07:18 PM   #22726
Default RS Pro Starting setup with 5T motor
touring car:
2s lipo 90C
LRP X12 5T
Large outdoor track
Starting setup would be appreciated as I don't want to burn anything out.
I read on this thread that with low turn motors (such as the one that I am planning to use), one should not use any turbo, or boost. True?
Recommended setup please?
Thanks!
mhavlena is offline   Reply With Quote
Old 06-20-2012, 10:46 PM   #22727
Pro10noob's Avatar
My opinion is that any motor below 6.5 turns is a overkill for TC as it rips your drive train to shreds.
I wouldn't use turbo but a very little amount of timing can be done.
Go with a high FDR and check motor temps every 2 to 3 minutes as the X12 can run very hot but start to loose brakes and torque if they becomming to hot.
Smoked a X12 a few weeks back due to a to high setting on the ESC and that was a 10.5 and in a Pro10 2WD
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-21-2012, 02:53 AM   #22728
regards Roy
So, should I use sensored only mode? or dual-mode?
Thanks!
Old 06-21-2012, 07:23 AM   #22729
Pro10noob's Avatar
I would suggest dual mode.
This because you want to run with timing and not break down if anything happends with the sensorboard of the motor or you sensor cable
regards Roy
l===/o\===l
Old 06-21-2012, 10:48 AM   #22730
regards Roy
hey Roy ,
i have been running a 4.5 with stock profile , thats quick !!!! if you gear it right and get the correct throttle profile your drive train should be ok ;-)
sidecarphil1 is offline   Reply With Quote
Old 06-21-2012, 10:55 AM   #22731
Pro10noob's Avatar
He Phil,
I know it can be done
At the ZAC races, you can hear what i mean.
At the start of the heat the mod TC guys have a nice quiet car but when you hear them a few minutes in the heats you hear the belts skip when they brake or accellerate out of the corners.
From what i heard, Hara had to rebuild his drive train after every heat at the worlds or ETS last year.
regards Roy
l===/o\===l
Old 06-21-2012, 06:06 PM   #22732
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
im sure this information is in here somewhere, but 1500 pages is a lot to read through lol.
just picked up a reedy sonic 13.5 to run in worldgt. heard good thing about the motors, though not sure where to begin with my boost profile. I tried to treat it like a duo1, boost through the whole rpm range and i tried treating it like my lrp, that only seemed to like boost mid-high rpm range but both seem a little sluggish.
running new tires out of box, rolling out high 60's.
our track is a typical parking lot outdoor 12.5-13 second lap average.
i dont get a lot of tracketime, so its not that im lazy, it is just a matter of trial and error on the unprepped street, not in race conditions lol.
valk is offline   Reply With Quote
Old 06-21-2012, 10:27 PM   #22733
Pro10noob's Avatar
@Valk.......What rollout are you running with those tires??
12 to 13 sec track screams for a low rollout.
Had a national race last weekend on a fairly short track and we were running with a 10.5 and boost,turbo and timing a rollout of 37.
I think you need to start with about 45 and work your way from there.
Let the motor rev a bit and you will see it accelerates better.
regards Roy
l===/o\===l
Old 06-21-2012, 10:50 PM   #22734
valk's Avatar
most people seem to rollout between 65-70 at our track, though most of those cars are d3 based.
I could try lowering the rollout a little too as im pretty close to 70, might be overgeared for the timing im trying to push.
Old 06-21-2012, 11:10 PM   #22735
Pro10noob's Avatar
@Valk...By WGT you mean the cars like the Asso10R5, Xray X10 and the Serpent S100??
If so, with the older type motors you need to gear them lighter then the newer motors like the D3 or the X12.
This because of the torque of the newer motors.
The older motor have les and like to rev
regards Roy
l===/o\===l
Old 06-21-2012, 11:59 PM   #22736
valk's Avatar
Then maybe i should just set higher static timing and gear for that, add a little turbo for the straight?
Almost wish i could just run blinky 10.5 instead. Car was fast and smooth.
Old 06-22-2012, 01:04 AM   #22737
Pro10noob's Avatar
What i said Valk run it with a lighter gear ratio and you will found out that it will accelerate better and has enough top speed.
Last weekend spur 81, pinion 16 and tire diameter 58MM.
This with a 10.5 with timing,boost and turbo.
Laptimes of the fastest guys where in the low 15, high 14 seconds.
Should be a nice starting point for you and work your way from there.
I had a LRP X11 in the car, others GM and Corally
Regards Roy
l===/o\===l
Old 06-22-2012, 09:35 AM   #22738
regards Roy
Man, I should take my 4.5 out! Lol
Jeremy Otis is offline   Reply With Quote
Old 06-25-2012, 09:43 PM   #22739
waOscar's Avatar
Originally Posted by mhavlena View Post
touring car:
2s lipo 90C
LRP X12 5T
Large outdoor track
Thanks!
I boost every X12 motor the same, start with boost 35 and turbo 15 (although I do use more), then adjust gearing to suit track.
Adjust RPM range for how agressive you want to be out of corners.
Also remove fans from motor and point at the speedy, the motor will be fine, but the speedy will thermal if not cooled by fan.
I run a X12 5.0t, geared at 9.18 FDR on the track linked below.
www.wcmrc.asn.au
pm if you want more info.
toby
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 07-02-2012, 11:39 AM   #22740
Hi All & Randy,
I recently put in a brand new align ds620 servo into my futaba 3pm mx with 603ff diversity rx and rs pro with 10.5T. now i am experiencing momentary cut off of power to the receiver - the green light on the receiver would go red indicating drop in power, the leds on the tekin rs pro would dim down then the center led would light up momentarily then it would be good again. this happens (when the car is stationary) if i were to just move the steering quickly left and right (I dont even have to do it many times just twice and the problem above occurs), however, if i run a 4500uF cap into the receiver, it is fine, no problems at all. i want to know if there is anything i can do so that i can avoid running the cap into the receiver? there is nothing wrong with the servo, tested it in other radio/rx units and its good, and my 3pm and rx are also working well with other servos. i dont think there is anything wrong wit the tekin unit either. i read the bec in the rs pro is 6v at 3amps, which should be plenty for the servo right?, how can i test that i am getting this as i think the servo seems to be drawing a lot of power but it is only rated for 6v. i recall that spektrum has this problem, but i have not heard of futaba having this problem with tekin esc. should i run another cap (already have one cap on the esc) on the esc? would this do anything to prevent this momentary power loss? appreciate any thoughts on this or if anyone has any similar problems to this.
thanks.
rshair is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
